![]() Join Date: Aug 2015
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score has anyone changed an alternator on an 07 speed 3 ? |
| Not Ranked : 0 score Moved out of the sticky. Please search. |
![]() Join Date: Oct 2013 Location: Sebastopol, Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Sure, pull the old one out and throw the new one in.
__________________ Corksport stage 2 sri/tip, Autotech Internals, RSB, CBE, Forge bpv, Koni FSD, Mazda Sport Springs, ITV22, JBR PMM, JBR TMM, JBR RMM, Damond SSP JBR SSB, CX piping with TR6, DM OCC Dizzy Tuned " I just don't need a stage 6, 16 puck, teflon diamond plated clutch that can snap a femur downshifting." -Raider |
| The Following 3 Users Say Thank You to Orangatang For This Useful Post: |
![]() Join Date: Dec 2013 Location: San Diego, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score I put it back in when I was swapping the engine. Kind of a pain in the ass. Theres a lot of shit down there. I think I remember not being able to make it out the top and when I lowered it it hit the dp so I removed the dp cus it wasnt bolted up yet. Probably a better way. Good luck. |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
| Not Ranked : 0 score Fuckity fuck fuck. It's just 3 bolts and an electrical connector. Then why in the fuck is this thing such a pain in the dick to get out? I can't seem to get the connector off; bitch is covered in oil.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
![]() Join Date: Aug 2015 Location: Schaumburg, IL
I found a replacement, but the pigtail wire colors don't match the vehicle harness. Does anyone have a pinout of this connector that shows which wires go where?
__________________ | |
| Not Ranked : 0 score Nevermind.
| The Following User Says Thank You to DMANbluesfreak For This Useful Post: | Db09ms3 (02-06-2020) |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
__________________ Stockish |
| Stock turbo replacement Costs and Alternator question | Dasleeper | Mazdaspeed3/6 General Discussion | 26 | 02-04-2013 05:14 PM |
| Alternator going bad? | urbansurfer | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 07-11-2012 10:12 AM |
| Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al | Haltech | Automotive News | 0 | 03-27-2009 02:30 PM |
