 Old 11-07-2009, 06:16 PM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default Best engine mounts???
Since recently tuning with the 30 I feel as if the motor mounts would be a good investment since it rips tires loose pretty easy. i have no wheel hop but i know the motor is rocking a bit since the EWG is hitting a coolant line 1/2 inch away pretty good.
I dont want solid mounts but i want something thats better and stiffer then stock and uses same mounting holes and same locations for mounting battery box and what not. Who sells them?? how are they and whatnot. help me out
The Following User Says Thank You to For This Useful Post:
SpeedSixxx (12-10-2009)
 Old 11-07-2009, 06:19 PM   #2
mazdarati's Avatar
Posts: 129   (View Stats)
mazdarati is a splendid one to beholdmazdarati is a splendid one to beholdmazdarati is a splendid one to beholdmazdarati is a splendid one to beholdmazdarati is a splendid one to beholdmazdarati is a splendid one to beholdmazdarati is a splendid one to beholdmazdarati is a splendid one to behold
Groaned at 6 Times in 2 Posts
PTperformance they are working great for me.
mazdarati is offline   Reply With Quote
 Old 11-07-2009, 06:21 PM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
i have all 3 streetunit ones....awesome
 Old 11-07-2009, 07:05 PM   #4
18psiWhiteMS3
Lurkers
Posts: n/a
does the stock battery box mount to the engine mount or is it under the mount for the batter box. If it bolts to the engine mount is it pre-drilled for the 3 bolts that hold the battery box in?
 Old 11-07-2009, 08:42 PM   #5
turd burglar's Avatar
Posts: 1,895   (View Stats)
Groans: 39
The tranny mount is under the battery box bolts right up like factory. I have the trz tranny and rear mount. Some strong vibes but you get used to em
 Old 11-07-2009, 08:56 PM   #6
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
waiting waiting waiting for cp-e's
 Old 11-07-2009, 10:28 PM   #7
D-Rick21's Avatar
Posts: 257   (View Stats)
D-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond reputeD-Rick21 has a reputation beyond repute
i have the 75 duro cp-e rear motor mount and still get a lot of wheel hop going into 2nd gear
cp-e Cold Air Intake
cp-e Rear Motor Mount
Turbosmart bypass valve
SU shifter bushings
D-Rick21 is offline   Reply With Quote
 Old 11-08-2009, 12:19 AM   #8
reddeerspeed3's Avatar
Posts: 689   (View Stats)
reddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the worldreddeerspeed3 is the leader of the world
i haz the SU mounts. rear mount always, side mounts to go to the track. OEM fitment, i can change both side mounts in just over an hour with a socket set and a torque wrench. the battery box bolts to a plate that sits on top of the tranny mount. fits fine with the SU mount
reddeerspeed3 is offline   Reply With Quote
 Old 11-08-2009, 12:40 AM   #9
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i hear medieval has some pretty beefy ones
The Following 3 Users Say Thank You to rodrigo For This Useful Post:
bioevolve (11-08-2009), blackrs99 (11-08-2009), madvillain (11-08-2009)
 Old 11-08-2009, 12:46 AM   #10
blackrs99's Avatar
Posts: 314   (View Stats)
blackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the worldblackrs99 is the leader of the world
Groaned at 8 Times in 5 Posts
I've noticed you're going to have wheelhop regardless of the mounts. Some will make it seem gone for a little bit, but as soon as the mount breaks in, wheelhop will come back. What CP-e RMM did for me (60 duro) was made those 5500-6000rpm shift much more smoother and quicker. It made the gear really click as you rush it in third or fourth and so on.
I recommend cp-e, but I doubt that any mm's alone will completely eliminate wheelhop.
::: Cobb AP ::: HTP 3" Full Intake ::: Ebay DP ::: CNT CBE ::: JBR Triology ::: JBR SSP ::: JBR RSB ::: CS TMIC ::: MSD Dashhawk ::: White PC RX-8 Wheels wrapped in Continental DWS 225-40-18 :::
::: DIZZY TUNED by Boost_creep :::
blackrs99 is offline   Reply With Quote
 Old 11-08-2009, 02:20 AM   #11
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
save yourself the money and just get the TRZ tranny mount. im a huge fanboi of it. the initial vibes are a bit rough, but they soften up. the performance benefit is huge, you really will feel a substantial difference. the fitment is just like stock, you dont have to re-arrange anything to make it fit, bolts right up.
the SU mounts are awesome and all, but thats too much money for me when the trz is simple and effective for much less.
 Old 11-08-2009, 07:15 AM   #12
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
I have the trz passenger side mount it works really well but makes the tranny sound loud, and vibes r pretty strong,im thinking about changing to the street unit mounte just the sides and leave the trz rear mount
boosted3 is offline   Reply With Quote
 Old 11-08-2009, 07:17 AM   #13
18psiWhiteMS3
Lurkers
Posts: n/a
Yes they are expensive. the only reason i am thinking SU mounts now is cause they were made to be together. the way i look at it if u have 2 of the same kinda mounts the engine wil have the same play on both sides. if u do one hard and one soft the engine will wanna tq more on one side then the other. So i think im going to have to bite one more bullet and get the SU mounts. I just need to talk to mark about it first. they are out if stock and i kinda wanna get them on asap
 Old 11-08-2009, 08:46 AM   #14
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
trz tranny ftw.
 Old 11-08-2009, 10:11 PM   #15
bf360's Avatar
Posts: 2,069   (View Stats)
bf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the worldbf360 is the leader of the world
Groaned at 42 Times in 35 Posts
i would wait for cpe nothing out right now is all that impressive
bf360 is offline   Reply With Quote
 Old 11-09-2009, 07:23 AM   #16
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Been waiting on CP-E for like what feels like 1 year, probably has been a year already lol.
And one of their main guys has left them and no updates on their mounts have been heard for a long while now.
My statement along time ago still stands "that CP-E' TMM will be turned 90*, like the PTP TMM".
So anyone got any news on them?!?!?!?!
bioevolve is offline   Reply With Quote
 Old 11-09-2009, 10:05 AM   #17
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
I would recommend the ptp kicker to compliment whichever other mounts you do decide to get. Ive never heard anything negative about the trz combo, which is what ill be getting soon. If your worried about vibs go with the topspeed mounts they are as close to stock as you can get.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
 Old 11-09-2009, 11:32 AM   #18
aaronc7's Avatar
Groans: 370
i dunno, doesnt seem like many have the SU ones but i think they are great... I have not gotten wheelhop once since I put them in. Vibes are there, but its not bad w/ 900 rpm idle.
 Old 11-09-2009, 11:38 AM   #19
RacingToaster's Avatar
Posts: 426   (View Stats)
RacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the worldRacingToaster is the leader of the world
Groans: 40
I got AWR's Rear MM and Trans , looking to get the rest soon.
RacingToaster is offline   Reply With Quote
 Old 11-09-2009, 01:31 PM   #20
18psiWhiteMS3
Lurkers
Posts: n/a
whatsthe link for AWR?>
 Old 11-10-2009, 07:15 AM   #21
nyghtryder's Avatar
+1
I only thought they made a rmm
NATOR PA
 Old 11-11-2009, 07:19 PM   #22
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
They make a PMM, RMM and TMM for the speed 6 but only the RMM for a speed 3.
Your best bet is the TRZ trans mount in addition to your rear with an engine torque damper. The vibrations arent all that bad, and if youre going to bolt it up to be a racer, support the motor.
All wagon, No traction
wassup61 is offline   Reply With Quote
Engine mounts? Mcopping MazdaSpeed 3 - How-To's 45 06-10-2010 06:03 PM
TRZ TM and SU engine mounts ms3boost MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-27-2009 07:56 PM
SU Side Engine Mounts Completed & Installed Grim MazdaSpeed 3 - Engine, Transmission & Driveline 22 10-30-2008 02:29 PM
Page generated in 0.40258 seconds with 35 queries
