 Old 07-13-2009, 11:25 AM   #1
iracer7's Avatar
Posts: 329   (View Stats)
iracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond repute
Default Bolt help
Can anyone give me a link to the bolt that goes between the stock cat-back exhaust and the stock mid-pipe? I had to hacksaw one off when I was trying to take off my mid pipe to install a race pipe. After a few days of stuggles, I think putting the stocker back in is the best option since I don't think the TXS pipe will fit. I need a new bolt. I've been to Napa, Advanced Auto, and Home Depot and they didn't have anything like I needed.
Cobb AP, CPE SRI, Cobb Turbo Inlet, Turbosmart Dual-Port BOV, ETS 3.5" TMIC, TRZ Rear Motor Mount, TurboXS Race Pipe, TWM Shifter Bushings, Dabears2k 35W 6000k HID's, Luminiacs 2500k halogen fogs, Putco brake light led bulbs, CPE tow plate, Cobb Springs, OZ Racing Ultraleggara Gold Wheels, weapon r torque damper
iracer7 is offline   Reply With Quote
 Old 07-13-2009, 11:54 AM   #2
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
dude, the turboxs race pipe will fit, make sure you're not installing it the wrong way lol...
and are you talking about the spring bolts?
glocK23 is offline   Reply With Quote
 Old 07-13-2009, 01:08 PM   #3
iracer7's Avatar
yes. How in the world does the front end of it fit over the stock donut that is on the downpipe? I could get one of the bolts to start to thread but the 2nd one on the other side wouldn't go on. I bought it used and the guy who sold it to me bought the complete downpipe with the racepipe. Could it be fitted to only fit to the TXS dp?
 Old 07-13-2009, 01:32 PM   #4
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i had txs rp with stock dp and stock cbe. it should work.
 Old 07-13-2009, 01:37 PM   #5
quickspeed6's Avatar
Posts: 202   (View Stats)
quickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant futurequickspeed6 has a brilliant future
You should NEED the spring and bolt to make it work. You can just get a long bolt and nut and two larger washer to cover the hole enough so that the bolt doesn't pull through it and you are done.
quickspeed6 is offline   Reply With Quote
 Old 07-13-2009, 02:18 PM   #6
iracer7's Avatar
My question is does just the TXS rp bought by itself differ from the TXS dp and rp combo that can be bought as one piece? Does the fitment of the rp that comes with the dp from TXS differ from the stand alone rp that can be bought?
 Old 07-13-2009, 02:24 PM   #7
glocK23's Avatar
Groans: 701
No, it's the same pipe.
 Old 07-14-2009, 12:23 PM   #8
iracer7's Avatar
Was I supposed to take the stock donut on the downpipe off?
 Old 07-14-2009, 12:25 PM   #9
phillyb's Avatar
Groans: 1,940
i actually didn't use any gasket on the dp/rp connection. you should reuse the stock donut gasket coming off of the oem rp
 Old 07-14-2009, 12:46 PM   #10
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
i just bought longer bolts than it came with that were the same thread and pitch with some lock washers and it bolted right up. The key is the longer bolts and tightening it evenly on both sides so you dont warp the donut gasket on the downpipe too badly.
09 MGM MS3
 Old 07-14-2009, 01:02 PM   #11
iracer7's Avatar
Where'd you get the bolts from? I'm from central VA and went to Home Depot, Napa, and Advanced Auto and they didn't have what I needed.
 Old 07-14-2009, 01:31 PM   #12
glocK23's Avatar
Groans: 701
Look for a Lowes or try googling a tool store that will have bolts for you, trust me, they are out there and I had to buy new bolts too for my turboxs since I hate spring bolts!
 Old 07-14-2009, 02:12 PM   #13
iracer7's Avatar
They have to be machined threaded also correct? I'm looking online. Something like this? http://www.boltdepot.com/dimension.a...20&cs=77&cm=22
 Old 07-14-2009, 02:15 PM   #14
phillyb's Avatar
Groans: 1,940
christ....just go here - McMaster-Carr - and get 10xwhatever pitch it is. either 1.25 or 1.5
 Old 07-14-2009, 02:24 PM   #15
glocK23's Avatar
Groans: 701
dont order shit online, just go to the local hardware stores and find the bolts, they dont need to be bolts used in the nasa shuttle, they just have to go through the holes, made out of good quality and long enough to bolt up.
 Old 07-14-2009, 02:42 PM   #16
I went to Lowes and got mine. Where are you at in Central VA? Shit you should have just brought your car to my house im from central va also in lynchburg.
09 MGM MS3
 Old 07-14-2009, 02:43 PM   #17
iracer7's Avatar
Midlothian. My parents are pretty pissed about me doing shit to my car so I'm not going do anything for a week or so. Let things cool down a little. My dad isn't happy at all.
 Old 07-14-2009, 03:29 PM   #18
phillyb's Avatar
Groans: 1,940
lol
06Speed6 (07-14-2009), glocK23 (07-14-2009)
 Old 07-25-2009, 11:26 AM   #19
iracer7's Avatar
I went to Lowes this morning and got some 75mm long bolts. They threaded to the dp pretty easily and I finally got it installed. Thanks for the help with the bolts.
Fully bolt SS/SC vs MS3 Bigbody250 Street Racing Stories ( Bench Racing ) 12 06-22-2009 09:24 PM
Getting new intercooler bolt? iracer7 MazdaSpeed 3 - Engine, Transmission & Driveline 11 05-18-2009 04:28 PM
Broken Lug Bolt(s) MrBig MazdaSpeed 3/6 - Wheels & Tires 4 01-20-2009 11:47 AM
Page generated in 0.35963 seconds with 24 queries
