 Old 01-01-2015, 02:56 PM   #1
Rob84's Avatar
Posts: 598   (View Stats)
Rob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the worldRob84 is the leader of the world
Default Boost issue
So I am in the process of tuning my ms6, I am somehow pressurizing my vc. I noticed this when doing a boost leak test. I have pressure building and finally escaping from the oil cap if all places. Could it be a bad pcv valve? I am removing the breather from the vc to the tip. Where do I start with figuring this out? I did do a search and did not find much.
Thanks for the help
06-MS6-Cobb AP- Corksport SRI and TIP- Custom Exhaust- KMD Internals- Turbosmart BPV- Test Pipe- ETS Top Mount- JBR Boost Tubes- Cobb 3 Port EBCS-
Freektune on corn
Rob84 is offline   Reply With Quote
 Old 01-01-2015, 03:13 PM   #2
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
I was under the impression that when doing a boost leak test you will lose a little bit of pressure past the rings into the crankcase especially if the engine is cold.
 Old 01-01-2015, 03:22 PM   #3
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Yup, there's always open valves somewhere.
Over Boost Issue, Boost leak? vincentspeed3gogh MazdaSpeed 3/6 - ECU Computer Tuning 23 12-27-2014 02:31 AM
Boost issue Moosheep Gen2 MS3 General Discussion 6 07-26-2013 07:04 AM
Need Help with a possible Boost Cut issue??? EddyV1987 MazdaSpeed 3/6 - Big Turbo Builds 7 04-24-2013 04:24 PM
Boost issue sriser66 MazdaSpeed 3/6 - Turbo Induction 4 03-19-2013 10:40 PM
Issue with hpfp/boost?!?! please help maf07003 Mazdaspeed3/6 General Discussion 15 02-25-2013 09:18 PM
Page generated in 0.25200 seconds with 22 queries
