 Old 01-05-2010, 07:21 PM   #1
bnoon's Avatar
Posts: 1,770   (View Stats)
Default Catch can warning for cold climates!!!
The last couple of days I've had a starting issue that I've solved with stock replacement spark plugs (I was 2 heat ranges colder). I've also noticed that I was smelling smoke again the last couple of weeks. When I pulled the intercooler, it was coated with TONS of oil!!! This has never happened to my car before, even at it's worst smoking it was always out the exhaust side of the turbo. My thoughts went RIGHT to the PCV side of things since I still have my PTP and BNMotorsports restrictor banjo bolt in place and haven't smoked since both were installed.
So... back-track a little bit... I made an oil change about a week ago and went to empty the SM catch can and only a few drops came out of it. I didn't think much of it since it's not been that long since my last oil change. Well, today I thought to check the catch can a little closer because it's the only reason I can think of that I would be pushing oil into the intake and smoking... The catch can is frozen SOLID with water that it pulled from the crankcase!!!! I've not been getting any PCV suck at all through it!!! I pulled it all the way out of the car and put the stock PCV/tube back in place and also put the stock TMIC back on until I can get a chance to clean up the air/water core and pipes from all of the oil in them.
Today's lesson: Check your catch cans in colder climates!!! If I put the catch can back in place, I will be relocating the PCV valve up higher so that the catch can will be able to be located closer to the engine to make sure it melts if I do it at all.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
The Following 9 Users Say Thank You to bnoon For This Useful Post:
bioevolve (01-05-2010), chaser27 (01-08-2015), Darksun280 (01-07-2010), Dash08 (01-17-2010), djuosnteisn (01-07-2010), Fobio (01-07-2010), FreeFlyFreak (01-17-2010), TopazM3 (01-17-2010), urville (09-16-2011)
 Old 01-05-2010, 07:33 PM   #2
felt's Avatar
Posts: 1,504   (View Stats)
Groans: 1,364
Wow, that sucks, glad you caught it before it got even worse.
felt is offline   Reply With Quote
The Following User Says NO Thank You to felt For This Un-useful Post:
 Old 01-05-2010, 07:38 PM   #3
speed23's Avatar
Posts: 1,480   (View Stats)
Yeah that sucks. I have a catch can but haven't installed it since -20 is like the average temp here in canada right now. I suspected that freezing would be a problem, but I wasn't 100 percent sure. Thanks for posting, now I know for sure.
 Old 01-05-2010, 07:38 PM   #4
bnoon's Avatar
Yeah, I hope so too. I had high enough crankcase pressure that it pushed oil past the cam position sensor in the valve cover and I had light oil at the filler cap too. The main valve cover seal looks OK though. I think I got lucky with only short in town driving since I started noticing smoke. Hopefully all is well with the harder to replace seals like rear crank seal/etc that I would have to pull the engine to replace. The bottom of the engine is dry too, so that's a good sign.
Yeah, we've been getting that here in Iowa, USA as well. Last two mornings have been -1 and -6 F as I've gone into work with -20-30 wind chills. Not a whole lot of fun.
2002 BMW M3 - Sold!
The Following 2 Users Say Thank You to bnoon For This Useful Post:
FreeFlyFreak (01-17-2010), urville (09-16-2011)
 Old 01-05-2010, 07:40 PM   #5
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
its funny you should post this, just yesterday i went to try to drain my saikou michi since its been a couple thousand miles, and it usually fills pretty fast in the winter, and only a couple drops came out... I stuck a small flat head up inside the drain plug to make sure it wasnt plugged but for all i know i could have just been stabbin a block of ice because nothing came out still. I wonder if this is how mine is...
09 MGM MS3
 Old 01-05-2010, 07:42 PM   #6
soccerballz's Avatar
Posts: 596   (View Stats)
soccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the worldsoccerballz is the leader of the world
Wow good to know what temps are you seeing in your area?
08' Black Mica MS3
Mods: Vibrant 3" SRI, CP-E 3" TIP, GT3071 IWG, Manley H-beam rods, Wiseco Pistons, BSD, PG Exhaust Mani V3, CP-E Catted Downpipe, Borla CBE, CP-E FMIC, Cobb AP, CP-E HPFP, Turbosmart DP BOV, Cobb SS + Bushings, Cobb Shifter Weight.
Sponsored by NATOR VA
soccerballz is offline   Reply With Quote
 Old 01-05-2010, 07:51 PM   #7
HLR Element's Avatar
Posts: 2,477   (View Stats)
Groans: 109
damn... i just installed mine, hopefully since it's just installed it'll still work since not much should be in there, warm tonight, 21... been the low teens past few nights
Mk7 GTI
 Old 01-05-2010, 08:16 PM   #8
i wonder if there is anything we can spray up into the drain valve to melt the shit?? anybody have any ideas?
09 MGM MS3
 Old 01-05-2010, 08:23 PM   #9
Groans: 109
^ hairdryer/heatgun... lol
Mk7 GTI
 Old 01-05-2010, 08:26 PM   #10
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
hmmm I only had maybe a 1/2 ounce come out of my can after 2 months installed ... it's -20 to 30 on average here now you have me thinking ... shitty thing is i have no where to work on the car to fight with that damn stock piece to go back to stock. No way am I doing it bare handed in a non-insulated garage
GQ_WhiteMS3 is offline   Reply With Quote
 Old 01-05-2010, 08:28 PM   #11
Pour a little bit of windshield de-icer in the catch can. Not enough to fill it, but to mix some of that water with enough so that it won't freeze.
Addikted To Boost (01-06-2010), Blackspeed (01-06-2010), FreeFlyFreak (01-17-2010)
 Old 01-05-2010, 08:31 PM   #12
What about the lines? Mine are routed low and not near the engine ... is it likely something can freeze there?
That said ... getting washer fluid in the can would be a HUGE bitch too
 Old 01-05-2010, 08:34 PM   #13
YammerR1's Avatar
Posts: 109   (View Stats)
YammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud ofYammerR1 has much to be proud of
The same thing happened to someone on one of the other forums recently. I can find a link to it if anyone is interested.
YammerR1 is offline   Reply With Quote
 Old 01-05-2010, 08:35 PM   #14
Put a blanket on the catch can.
breakfstincluded (06-15-2011), MATT DAMOND (01-06-2010)
 Old 01-05-2010, 08:36 PM   #15
what damage can this do should it freeze?
 Old 01-05-2010, 08:43 PM   #16
YammerR1's Avatar
Read the posts by garymca:
HOW-TO: Installing an Oil Catch Can
 Old 01-05-2010, 08:43 PM   #17
Groans: 109
blanket isn't going to do much if it's cold out, blanket is an insulator and unless something is heating the CC not gunna help, maybe just disconnect the can and bring it inside with you? warm it up, empty... maybe leave the hose unplugged for winter and drain on the road like the old time hahah
Mk7 GTI
 Old 01-06-2010, 06:54 AM   #18
eddelgado's Avatar
Posts: 84   (View Stats)
eddelgado will become famous soon enougheddelgado will become famous soon enough
I also have one of the Saikou Michi cans. I drain it every 2500 miles and typically see about 4 oz of fluid. The issue is that I have to have the can open for several minutes to get it to drain properly and it also helps if I wiggle the hoses around. I installed it with the Cobb directions and placed it in front of the passenger tire area. The concern would be that if you do not give it time and wait for it to drain you could probably fill it up and then would freeze in cold weather.
Ed
eddelgado is offline   Reply With Quote
 Old 01-06-2010, 07:09 AM   #19
Thestaplegunkid's Avatar
Posts: 150   (View Stats)
Thestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the worldThestaplegunkid is the leader of the world
Yeah at my last oil change, I went to drain my new CC... I openned the drain, and nothing. so I unthreaded it.... and stuck a screwdriver up inside.... icey goodness. Sooooo out came the propane torch, and a while later, I had myself an empty catch can... wondering how often i'll have to drain it.
Thestaplegunkid is offline   Reply With Quote
 Old 01-06-2010, 07:17 AM   #20
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
As long as you dont have a long stretch of horizontal run, you should be fine. I would think the easiest way to add the de-icer would be disconnect the hose from the pcv and dump it in there.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
 Old 01-06-2010, 07:50 AM   #21
bnoon's Avatar
Ed
That's where I installed mine too. The thing is, since it got cold out I haven't been getting as much out of the catch can, so I thought it was normal for this time of year... WRONG! If anything it should be pulling out MORE condensation in colder weather.
With engine heat it's been maybe melting an ounce or so, but the rest would stay totally frozen. I guess the lesson is to pull the plug all the way out and check with a screw driver to make sure you're ice-free and use a heat gun if you need to (My local Harbor Freight has an in-store special for $9.99 for Chicago Electric basic heat gun).
Wow, sounds like he got more damage than I did, at least I hope so since mine was all short trips and in-town driving. Hopefully my oil smell goes away soon, or this will turn into a nightmare.
2002 BMW M3 - Sold!
The Following User Says Thank You to bnoon For This Useful Post:
 Old 01-06-2010, 08:54 AM   #22
slyguy800's Avatar
Posts: 9   (View Stats)
slyguy800 is just really niceslyguy800 is just really niceslyguy800 is just really niceslyguy800 is just really niceslyguy800 is just really nice
i would try emptying that thing weekly in the winter and the best time would be after you have run the engine for a bit to try and heat things up. i know after a week that mine empties quite a bit of water out of it so i wouldn't go much longer then that.
slyguy800 is offline   Reply With Quote
 Old 01-06-2010, 09:01 AM   #23
Spoolme's Avatar
Posts: 1,041   (View Stats)
Spoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the worldSpoolme is the leader of the world
Groans: 54
Brad, glad to hear it was just the plugs.
Parting out!
http://www.mazdaspeedforum.org/forum/forum/f229/spoolme-parting-out-76016/
Spoolme is offline   Reply With Quote
 Old 01-06-2010, 09:15 AM   #24
Hank3's Avatar
Posts: 516   (View Stats)
Hank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the world
Tried emptying mine this past weekend (I have option 1 from Matt's GB) and only a little bit trickled out. It had been maybe three or four weeks since I last drained it. Didn't think about the contents freezing. Even in FL, we've been hit with the cold snap. But it gets above freezing during the day, so is that long enough for thigns to melt? Temps have been mid 20's at night and then maybe mid 40's during the day.
5% off Redline leather goodies HERE. Pics of them installed in my Speed3 HERE.
Hank3 is offline   Reply With Quote
 Old 01-06-2010, 12:24 PM   #25
bnoon's Avatar
I don't think it was a real problem until we got into single digit highs last couple of weeks. I would think you would be fine at those temps.
2002 BMW M3 - Sold!
 Old 01-06-2010, 12:59 PM   #26
Hank3's Avatar
That's what I figured. I even took it off and shook it vigorously to see if there was anything in it. This was around mid 40's/low 50's temp.
 Old 01-06-2010, 01:33 PM   #27
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
I can see a market for catch can warmers! Kinda like a NOS bottle warmer.
Frequentflyer is online now   Reply With Quote
 Old 01-06-2010, 01:41 PM   #28
bnoon's Avatar
I'll get to work on it! LOL!
2002 BMW M3 - Sold!
mr_mazda329 (01-06-2010)
 Old 01-07-2010, 12:25 PM   #29
desertrat's Avatar
Posts: 132   (View Stats)
desertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant future
It might be the mounting location, I have my occ installed in front of the batt box. I read In a mag that one should mount their occ above the block. With this mountng location I have not seen the cloudy latte look in the fluid coming out of the occ looks like coffee/ black oil out of my occ.
desertrat is offline   Reply With Quote
 Old 01-07-2010, 01:39 PM   #30
bnoon's Avatar
If you're not getting the cloudy look, then your catch can isn't pulling out the water/fuel condensation from the crankcase. It has nothing to do with your mounting location. How does your oil look at 3000-5000 intervals? Depending on your driving habbits, you may be driving long enough to burn off the water/fuel from the oil and it wouldn't get to your catch can to begin with. Also, if you have a poor quality catch can without good filtration media, you will not pull vapors and get the milky crap out of your oil at all. Believe me, you WANT to pull crappy looking stuff out of your oil, especially with this car and it's direct injection. This car KILLS oil.
2002 BMW M3 - Sold!
 Old 01-07-2010, 02:00 PM   #31
desertrat's Avatar
It's an occ not a wcc lol
 Old 01-07-2010, 02:12 PM   #32
bnoon's Avatar
Yeah yeah, har har har. Used to remove what ever vapor contamination is in the oil. i.e. water/fuel/etc.
Also, judging by your location, you probably never would see much moisture in yours.
2002 BMW M3 - Sold!
 Old 01-07-2010, 02:29 PM   #33
Hank3's Avatar
Curious about this bnoon. I'm not too knowledged about the OCC, but could you elaborate as to when the OCC would see most liquid? I've drained mine three times now and am wondering if it's due to my driving style that there isn't as much gunk in mine as others. I've drained it in 2-4 week increments. Most I have had is 1/4 cup.
 Old 01-07-2010, 06:20 PM   #34
stormin84's Avatar
Posts: 128   (View Stats)
stormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the worldstormin84 is the leader of the world
mine froze up once already, i have the elite engineering can so all i do is unscrew it and dump it, so i don't really have to worry about the freezing. i am however checking it every week, to make sure it doesn't freeze again.
Falken FK-452 | 215-40R18 | Konig Hotswap |35% Tints| Greddy TT| Cobb Sri| Cobb Shifter| Cobb AP| Cobb Springs| Cobb RSB | Cobb Inlet Pipe |TS BOV |Dashhawk| COBB FMIC |CPE MM|CPE DP|
STILL TO COME: |Whatever I can get my hands on before she kills me|
stormin84 is offline   Reply With Quote
 Old 01-08-2010, 12:49 AM   #35
Underground's Avatar
Posts: 55   (View Stats)
Underground has a spectacular aura aboutUnderground has a spectacular aura about
Damn sucks to live where you guys do... i bitch and complain about it being cold when its 50 degrees outside... lol. Normal midday temps are about 70-80 during winter lol. We only have 2 seasons here in AZ.
Underground is offline   Reply With Quote
 Old 01-08-2010, 07:49 AM   #36
slyguy800's Avatar
technically all that water isn't being pulled from the crankcase. a lot of it actually forms in the can itself since the can is probably always cold in the winter and you get the warm engine air flowing through there it forms inside the can.
The Following User Says Thank You to slyguy800 For This Useful Post:
SharkDiver (01-11-2010)
 Old 01-08-2010, 09:08 AM   #37
bnoon's Avatar
Short drives for a full tank (or more tanks) of driving would get you the most liquid in your CC. I drive 5-10 minutes to work (depending on traffic lights) and 5-10 back, so I get quite a bit. Best thing to do is get a Used Oil Analysis (UOA) done on your oil and drain your CC into a clear plastic cup and let it stand for a week or so to settle. Then you can see yourself what is left in the oil and what you're pulling out of the oil. Water will be clear-ish, oil = dark, fuel will be yellow-ish, with various color differences throughout. If you truly want to know what your catch can is pulling out, run a UOA wihout the CC connected, then the next oil change do a UOA with it connected. Try to have the same driving habits and temp conditions on both UOA's to not skew results.
True, true. Run a UOA with and without as above to know what you're truly pulling out of the oil with the CC.
2002 BMW M3 - Sold!
Hank3 (01-08-2010)
 Old 01-08-2010, 09:11 AM   #38
Hank3's Avatar
Thanks for the info!
 Old 01-08-2010, 09:12 AM   #39
bnoon's Avatar
No problem.
2002 BMW M3 - Sold!
 Old 01-09-2010, 02:15 PM   #40
Alright.... so a bit of an update. I had a frozen solid catch can, during my last oil change (3000 km ago).... anyhow, I unthawed it with the torch, however I suspected that at some point it may have blocked the vent path from the base of the motor.
Anyhow, I had the car in the garage today, to put the normal pcv hose back on for winter.... when I noticed oil coming from between my bellhousing and my block. So I believe my rear main seal must have let some oil by during the possible PCV blockage. This would also explain the intermittent clutch slippage I've been experiencing, under hard acceleration (oil on the clutch). My question.... is it possible that the seal might not be fucked? (Oh, and I was down 1/2 litre of oil)
Also... I'm leaning towards my new SPEC clutch being toast..... since it's most likely been oiled...... any chance it could recover from this? My guess is no... but anyone with any experience in this matter, please speak up.
Otherwise... I'll be dropping the motor in the spring, and replacing the rear main seal, and the clutch.
CATCH CANS and the cold.... don't mix.
The Following 2 Users Say Thank You to Thestaplegunkid For This Useful Post:
flyrevs2 (02-07-2010), FreeFlyFreak (01-17-2010)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/catch-can-warning-cold-climates-45845/
Catch Cans in Winter This thread Refback 11-29-2010 07:15 PM
Catch Cans in Winter This thread Refback 02-01-2010 08:44 AM
Big Emergency !!!! - Page 2 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 01-31-2010 05:37 PM
Big Emergency !!!! - Page 2 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com This thread Refback 01-29-2010 07:01 PM
Catch Cans in Winter - TorontoMazda3 This thread Refback 01-08-2010 08:12 PM
Catch Cans in Winter - TorontoMazda3 This thread Refback 01-07-2010 06:51 PM
catch can... and nothing etant333 MazdaSpeed 3 - Engine, Transmission & Driveline 28 09-02-2012 02:12 AM
Oil Catch Can dizzin9 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 01-02-2010 05:27 PM
Oil Catch Can Kit PDXImportRacer MazdaSpeed 3 - Engine, Transmission & Driveline 48 09-16-2009 09:18 PM
Oil Catch Can? bova Mazdaspeed3/6 General Discussion 11 12-06-2008 09:04 PM
Page generated in 0.56801 seconds with 38 queries
