 Old 09-10-2009, 12:13 PM   #1
armarine04's Avatar
Posts: 294   (View Stats)
armarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the worldarmarine04 is the leader of the world
Groaned at 20 Times in 5 Posts
Default Check Engine Light is on
After reading a thread on here about boost leak I checked all my boost tubes took the IC off tighted down all conectors I could practicely pull the inlet tube off with minimum effort. After everything was tighted down took it for a quick spin and came home. This morning shortly after leaving for work my check engine light comes on... any thoughts? I know I put everything back right and tight so I don't know what it could be. The car runs fine I can't tell anything is wrong personally.
Boooosh!
][ 2007 MS3 GT ][MAZDASPEED cai ][ MAZDASPEED cat-back ][ CP-e dp ][ Turbosmart Dual Port ][ SU rear motor mount ][ ITV-22 ][ RallyArmor mud flaps ][ MS6 wheels ][
armarine04 is offline   Reply With Quote
 Old 09-10-2009, 02:31 PM   #2
ALL-IN.
AndyMS3's Avatar
Posts: 671   (View Stats)
AndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the worldAndyMS3 is the leader of the world
Groans: 30
Get someone to read/clear the code (Pepboys I think) and work from there. Getting the code read will help you aim your efforts instead of blindly looking for problems.
mmkay?
AndyMS3 is offline   Reply With Quote
 Old 09-10-2009, 07:04 PM   #3
darth vader's Avatar
Posts: 665   (View Stats)
darth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the worlddarth vader is the leader of the world
Groaned at 9 Times in 9 Posts
Or you could just disconnect the battery for a few minutes, clearing the code, then see if it returns. That indicates a continuous problem.
darth vader is offline   Reply With Quote
 Old 09-10-2009, 07:10 PM   #4
armarine04's Avatar
I disconnected the battery and see if that did it but it came back after a few minutes.. I know that the best way to see whats up is to get the code read but I was just trying to see if anyone had any ideas as to what maybe common error that I may have made what I was under the hood. I will take it tomorrow to see what is actually wrong.
Boooosh!
 Old 09-11-2009, 07:58 PM   #5
armarine04's Avatar
pepboys said I have a bad o2 censor, they don't carry them but did seem to think that they are expecive.. Anyone know how much they, where I can get one (except from the obvious more expensive dealer) and would it be hard to install myself?
Boooosh!
 Old 09-11-2009, 08:11 PM   #6
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
I think they run about $200+.
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline   Reply With Quote
 Old 09-20-2009, 11:29 PM   #7
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
im simply gonna ask, do u got a downpipe aftermarket ? i would surely hope you would have mentioned having one installed when reffering to o2 sensor, if u got an aftermarket downpipe you might need to invest 3 dollars and some wrenching and add an spark plug anti fouler to your o2 sensor bung. it makes the o2 not stick soo far into the downpipe and cel issue is fixed(if this is an aftermarket downpipe we are talkign about)
 Old 09-20-2009, 11:33 PM   #8
glocK23's Avatar
Posts: 1,753   (View Stats)
glocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the worldglocK23 is the leader of the world
Groans: 701
Groaned at 655 Times in 620 Posts
I believe the code will still be stored in the ECU as "pending", it will not be cleared from the ECU, I think the only way of clearing it would be with the AP or dashhawk or an OBD-II reader.
glocK23 is offline   Reply With Quote
The Following User Says NO Thank You to glocK23 For This Un-useful Post:
 Old 09-21-2009, 07:33 AM   #9
armarine04's Avatar
I do have an aftermarket DP... After taking it to pepboys they guy there all he did was clear the code then inspected the o2 (moved the wire connected it farther away from the dp and checked its fitment) and it the check engine light came back on the next day but then went off all by itself while I was out one day and hasn't been back on since. So I really don't know... I stood next to the guy while he was going over the car the entire time so I know he didn't do anything shady. I put about 400 + miles on it this weekend and nothing to be concerned about.
Boooosh!
 Old 09-21-2009, 11:37 AM   #10
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
sometimes they need to be cleaned. And maybe by him touching it he removed enough crap where it reads properly again. If its not complaining leave it alone.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline   Reply With Quote
89 Octane = Check Engine Light? lengbros MazdaSpeed 3/6 - Troubleshoot/Diagnostics 72 11-28-2009 03:37 AM
Check Engine Light on '09 MS# FXT&MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 05-17-2009 08:45 AM
Oh No Check Engine Light! thabigo MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-04-2009 01:57 PM
PLEASE HELP! Trouble with engine light and check oil! spd6rcr08 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 10-01-2008 10:00 AM
Check engine light??? supergoose MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-20-2008 07:42 AM
Page generated in 0.30296 seconds with 26 queries
