![]() Join Date: Dec 2013
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I searched a lot for an answer butr couldn't find anything really helpfully. Regards |
![]() Join Date: Dec 2012 Location: Richmond, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 31 Times in 14 Posts
| Not Ranked : 0 score Um get an AP
__________________ ΜΟΛΩΝ ΛΑΒΕ 2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's 2015 F150 Platinum 2012 MS3 Liquid Silver Autotech HPFP Cobb AP & CBE Corksport FTB Enkei Raijin 18x8 et45 JBR 3.0WP, RSB, RMM & SSP II Stratified Tune TrackMasters hood prop and ecu reloc. TurboSmart BOV |
| The Following 2 Users Say Thank You to RACER_X For This Useful Post: | ASHMS3 (12-12-2014), Easter Bunny (12-14-2014) |
(Thread Starter) | Not Ranked : 0 score I'm just wondering because the UR Downpipe did not throw a CEL |
![]() Join Date: Jul 2012 Location: Clifton Springs NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,398
Groans: 51
| Not Ranked : 0 score Is it catted?
__________________ I used to go zoom zoom with my speed.... Now i drive a slow stockish Focus ST... |
(Thread Starter) | Not Ranked : 0 score Yes, it's catted |
![]() Join Date: Mar 2013
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 123
| Not Ranked : 0 score Check the Downstream O2 Sensor.
__________________ [size="2"]2003 MSP Spicy Orange #1151- "Zoom freakin' Zoom" Injen CAI (black), Yellow Calipers G2 System, Carbon Fiber Tower Brace, Red Line MT-90 Tranny Fluid, Custom FMIC-Big 3 Racing , Motegi F-7 Wheels , wrapped in Yokohama Parada Spec II's 215/40/17, SU Complete set of Motor Mounts, BC Coilovers, Adjustable End Links (front & rear),Power Slot Rotors, Techna Fit SS Brake Lines, Cobalt Friction XR-3 and XR-5 Pads, Russell Speed Bleeders, Mishimoto Radiator, Haltech Platinum Sport 1000, Disco Potato upgrade ATE Super Blue Brake fluid, (Kosei K-1 TS (painted yellow) w/ Kumho V710's 225/45/17) & Enkei RPF-1's 17 X 8 Black w /Toyo 888's 235/40/17 or B F Goodrich R-1's-NASA Time Trials, Apexcone 6000K HID's, AEM UEGO Wideband, AEM Tru-Boost and Electronic Controller & Boost Guage & AEM Digital Oil Pressure Gauge , Turbosmart Black Dual BOV, Custom 3" turbo-back exhaust (Patel Engineering), Findanza Lightweight Flywheel and Exedy Stage 1 Clutch, SS AFC, Wiseco Pistons, K-1 Rods- NASA TTD #327 2003 MazdaSpeed Protege 2013 MOCO Mazdaspeed 3-Crystal White Pearl-Bi-Color w/Tech Package-JBR Stage II SRI, Mishimoto OCC, JBR .250 RSB w/ Tri-Point end links, XPEL Clear Bra, JBR PMM & RMM, JBR MOCO Mud Flaps, Yellowspeed Coilovers, JBR Adjustable Rear Camber Arms, JBR Stage 2 Black Adjustable Short Shifter Plate and Bushings, JBR Shift Knob, EGR Delete, COBB AP, CP-e Flex II RMM, CP-e Triton CBE |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
| Not Ranked : 0 score Install a bung at the second o2 sensor. Sent From a Galaxy, Far Far Away... |
Rep Power: 0 ![]() ![]() Thanks: 35
| Not Ranked : 0 score yeah my UR did it like two nights ago. what kind of bung?
__________________ 13' MS3 Tech Package Velocity Red Power: Cobb: AP V3, SRI & TIH Ultimate Racing: DP, TP CPE:TMIC HKS: BPV JBR: RMM AutoTech: Internals Show: Cork Sport: LED Kit and LED Fogs |
Groans: 438
| Not Ranked : 0 score Just get an AP, if you already have internals and a DP, there is no reason not to tune...
![]() Join Date: Feb 2010 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 324
| Not Ranked : 0 score @AhSaol; any word on how the bung extender worked? I also Installed a brand new catted DP from COBB recently, running stage 2 OTS map on the AP (see sig for other mods) , and am getting a p0241 code as well (catalyst warm up efficiency below threshold). It seems to pop up once or twice every few days. . I checked all of the connections and bungs for signs of leakage (carbon), nothing that I could see. Tried reseting the ECU, to no avail. I called and spoke with Adam at @Cobb;. He said it could be a bad cat, but highly unlikely given it being brand new. He said it could also be bad spark plugs or improper gap, and instructed me to check the plugs (brand new NGK Iridium 1 step colder, gapped to .026), and then if that doesn't work, to try replacing the secondary 02 sensor. I'll check the plugs and report back. Might be a good time to check compression as well (95,xxx miles on the clock). Best price on the secondary 02 sensor seems to be at Rock Auto for around $70 for OEM NGK unit. The other alternative would be to just ignore it as a fluke if everything else checks out okay and untick the code in the AP. Thoughts?
__________________ 2010 Liquid Silver Mazdaspeed 3 Cobb AP v3, tuning by Stratified Automotive Controls, Autotech HPFP internals, one step colder NGK Iridium plugs, Cobb DP, Magnaflow 3" CBE, Corksport SRI/TIP, Corksport Race RMM 80A, Synapse Synchronic DV in push mode A+B, Treadstone TR6 FMIC, JBR FMIC piping kit, JBR Silicone recirc hose, JBR rear sway bar, Bilstein B14 coilovers, SPC adjustable rear camber arms, Stoptech SS brake lines and brake pads, 17x9" et+45mm Enkei Racing RPF1's, 245/40/17 Hankook RS3's, JBR 5mm hub/wheel spacers in front. |
(Thread Starter) | Not Ranked : 0 score It did not happen again to me, but it's warmer outside now. Maybe it will return in winter I don't know, I did not use the extender. |
| The Following User Says Thank You to AhSaol For This Useful Post: | GregScuba (05-06-2015) |
Groans: 111
| Not Ranked : 0 score I went through the same issue and there's no clean way around it unless you simply deactivate that error from the Cobb AP or versatuner. This spring I replaced the 400cel ceramic cat with a 200cel metallic cat with 60g load that are usually used around here for Porsche 991/996 sport exhaust systems and now I pass emissions and also reactivated that catalyst efficiency error checking when flashing the tune. All is great, emissions control system works like the factory.
| The Following User Says Thank You to mituc For This Useful Post: | GregScuba (05-06-2015) |
| Not Ranked : 0 score Check the plugs, perfect gap and appearance, did a compression test, all cylinders between 195 and 200psi. Went ahead and unticked the code in Accesstuner. Something interesting I noticed, was that p0241 is already unticked in all the OTS maps for 91 octane fuel from Cobb. This leads me to wonder if maybe fuel quality may be a factor.
Groans: 111
| Not Ranked : 0 score It's not the fuel, it's not the plugs, it's not the compression. It's the cat. You can use a bung for the secondary O2 sensor and make the error appear a lot less often or not at all, you can suppress that error code in the tune or you can replace the cat with a proper one.
| Not Ranked : 0 score Yeah, that's kinda what I figured ultimately. Just doing as Cobb instructed, that way if any major issues come up, I've covered myself and followed through properly. The whole thing just kinda took me by surprise, given the otherwise outstanding build quality and reputation of this DP. I'm pretty much over it though, and am content to just untick the code in AP and not look back or worry about it ever again... unless, of course, I move to a state with strict emissions testing in the future, then I'll look into a bung extender or changing out the cat at that time. Thank you for your insight. It's very much appreciated.
| Not Ranked : 0 score Just a quick update... Since finishing up tuning with Stratified Automotive Controls last month, the problem no longer occurs at all, no codes, and no pending codes either (as one would see if it were unticked in the programming). All emissions systems pass my scan tool's testing. To those our there with a Cobb OTS map, please, do yourself a favor and get it properly tuned. It will run so much better, and will be far safer in the long run. The tune is well worth it, and a sound investment in your car's longevity.
Groans: 111
| Not Ranked : 0 score Once you get a code you get a code, it's crystal clear, there's no way of tuning around it unless you disable the code from the ATR/Versatuner.
![]() | | #19 | ![]() |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() Thanks: 20
Groaned at 74 Times in 53 Posts
| Not Ranked : 0 score @mituc; , what exact part is that catalytic converted for Porsche you mentioned?
__________________ ------------------------------------------------------- |
![]() | | #20 | ![]() |
![]() Join Date: Jun 2009
You do realize you are responding to a four year old post expecting a reply? You might try PM’img him. I think he is still around.
| The Following User Says Thank You to MSMS3 For This Useful Post: | mituc (01-17-2020) |
![]() | | #21 | ![]() |
Groans: 111
So They didn't actually get a Porsche OEM, but something they replace the OEMs with. In the meanwhile I shattered that one, it was pretty weak. The high frlow cats the guys from Ultimate Racing are using in their DPs and TPs work fine for me. They are magnaflow 59959. However I noticed that the exhaust smell becomes more and more noticeable with time with these cats, so now I'm going to buy an EURO6 cat which will cost me about $900. From my knowledge I still have the record for the most powerful and quickest 2.3DISI-T powered car fully emissions compliant and I intend to keep it, so for me it worth the money. Otherwise the Magnaflows will be just fine.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
| Cobb Tuning $25 off Coupon Code | MazdaspeedKills | Mazdaspeed3/6 General Discussion | 29 | 07-24-2013 01:30 AM |
| P0421 | speedms6 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 6 | 03-06-2011 06:04 PM |
| P0421 CEL | RichB | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 12-30-2009 07:51 AM |
| P0421 on my CP-E Catted downpipe | steven88 | MazdaSpeed 3/6 - Turbo Induction | 11 | 07-11-2009 09:43 PM |
| How to get rid of a P0421 CEL...? | AutoXRacer | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 04-15-2008 05:45 AM |
