  • 1 Post By FreeFlyFreak
 Old 03-09-2010, 12:38 PM   #1
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
Default coolant
i have been running straight distilled water for a while now.
i understand there's no antifreeze and at high temps, it'll boil.
i understand there are no rust inhibitors and all that.
talk to me about this please.
benefits of running water?
benefits of going by the book and using coolant?
bykeryder4life (03-09-2010)
 Old 03-09-2010, 12:51 PM   #2
rfomzr's Avatar
Posts: 19   (View Stats)
rfomzr is a jewel in the roughrfomzr is a jewel in the roughrfomzr is a jewel in the rough
I have some experience with drawbacks of using only distilled water in coolant circuits. Do not do it...
One with a car in higher temps your going to run into the water boiling off.
Two you always want a corrosion and rust inhibitor in there.
Three coolant also protects against bacteria. in the colder months you can run the risk of getting a slime in your system caused by bacteria. Going unchecked it can cause problems with your temp sensor.
I would suggest putting coolant in minimum 20% to benefit from the corrosion and bacteria inhibitors. If your in colder climates like me use 50% to prevent freezing.
2010 Silver Mazdaspeed new on 02/15/10 - 5K DDM Low Beams and Fogs
rfomzr is offline   Reply With Quote
The Following User Says Thank You to rfomzr For This Useful Post:
phillyb (03-09-2010)
 Old 03-09-2010, 01:16 PM   #3
johnsin55's Avatar
Posts: 59   (View Stats)
johnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud ofjohnsin55 has much to be proud of
I took some Caterpillar technician training classes up here in nor-cal and he pretty much hit the nail on the head...
We spent several days just cover cooling systems, and running straight distilled water will give you the maximum heat rejection from your system, however it also helps keep seals from drying out/leaking, prevents corrosion of all the aluminum, and helps keep the water pump from cavitating at higher temps/pump speeds. The boiling point can be raised by installing a higher pressure radiator cap, but then you risk blowing lines, radiator or headgasket...
Id agree and say run a minimum of 20% just for protection, and you'll be running as cool and safe as possible for the long term...
Modified CP-E Xcel CAI with 3" ATP MAF housing--CP-E TIP--ATP GT2871R--CP-E FMIC--FORGE BPV--PTP Internals--COBB AP & DP--3" Vibrant Exhaust--SU Motor mounts rear and sides--Volk Te37 18"x7.5" +47
johnsin55 is offline   Reply With Quote
The Following User Says Thank You to johnsin55 For This Useful Post:
 Old 03-09-2010, 12:53 PM   #4
phillyb's Avatar
Groans: 1,940
i live in socal. it's never 32 degrees.
and the water rarely goes to 212, so rarely boils.
but yeah. keep it coming.
cause i've been doing research about this for a week or so and have gotten mixed information.
 Old 03-09-2010, 01:11 PM   #5
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
If the cap reads FL22 then that's what I'm using. You shouldn't fuck around with cooling systems. Can anybody say "can of worms"?
this forum serves 2 purposes
 Old 03-09-2010, 02:38 PM   #6
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
a) benefits of running water?
b) benefits of going by the book and using coolant?
a) short term slightly cheaper, long term can be much more expensive for reasons listed in other prior posts.
b) short term slightly more expensive (we are talking $5 here), long term probably much cheaper for reasons listed in prior posts.
Saving pennies now, will cost you dollars later.
Let me rephrase in language you can understand.......
Philly you fucking cheapskate, put some fucking coolant in there before you encounter more FAIL..........
Plus you cant fool me with your talk of "distilled" water, we all know you wouldnt spring for distilled water when water from the faucet is free.
Let me refresh your memory of some previous efforts to save pennies which then lead to expensive failure:
Suspension:
The Following 8 Users Say Thank You to FreeFlyFreak For This Useful Post:
Dash08 (03-09-2010), gtlaw (03-09-2010), karl-hungus (03-10-2010), kgb (03-12-2010), phillyb (03-09-2010), PoMan (03-13-2010), trickytwelveinch (03-11-2010), wankular (03-10-2010)
 Old 03-09-2010, 02:47 PM   #7
phillyb's Avatar
Groans: 1,940
lol
FreeFlyFreak (03-09-2010)
 Old 03-09-2010, 03:01 PM   #8
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
I always run water or mostly water when I get a chance. Water cools better than coolant and if your system is sealed I dont see corrosion being an issue. rust happens when metal contacts air (oxygen) yeah water has some oxygen in it but much less. I ran water in my integra for 200,000 miles with no corrosion. Also if you want extra protection you can pick up water weter for like $10. Its design to lube and protect when running 100% water but I wouldn't worry about it.
 Old 03-09-2010, 10:54 PM   #9
Doc
Doc's Avatar
Posts: 526   (View Stats)
Doc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the worldDoc is the leader of the world
Groans: 35
Rust is one thing its referring to iron and its alloys..
Corrosion is what can fuck philly.. our block is aluminum.. it'll corrode.. not rust
And I pose one more question for you... what happens when you boil this pure water? What elements are you left with? Well.. water is H2O..when you boil it your breaking it down... into.....?
Bingo.. theres your oxy
Doc is offline   Reply With Quote
 Old 03-09-2010, 11:02 PM   #10
The Kamikaze King!
Groans: 754
Doc = Chemistry Fail.
When you boil water you make water vapor.
Water is not unstable, it highly stable........... it does not breakdown into its constituent elements when heated...... if it did you would have more problems than corrosion, H2 is highly explosive.
There is however O2 dissolved in the water that comes out of solution as the water gets hot. Think kettle hissing as it starts to warm up but before it boils.
Corrosion of the various metals is possible, but it is not from the breakdown of water into its constituent elements. It would be from natural present oxygen or possibly any minor electrolysis action that may be present from dissimilar metals.
breakfstincluded likes this.
Suspension:
The Following User Says Thank You to FreeFlyFreak For This Useful Post:
Dash08 (03-10-2010)
 Old 03-09-2010, 11:05 PM   #11
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Ive been running distilled water and water wetter for around 7,000 miles. I dont foresee any issue with this method of cooling. Water Wetter specifically states it is for "Rust and corrosion protection allows for use of straight water"
MattJackson86 is offline   Reply With Quote
 Old 03-09-2010, 11:10 PM   #12
The Kamikaze King!
Groans: 754
Distilled water + water wetter = win
Distilled water + coolant = win
Phillyb + tap water = FAIL
Suspension:
The Following 2 Users Say Thank You to FreeFlyFreak For This Useful Post:
bykeryder4life (03-10-2010), phillyb (03-10-2010)
 Old 03-09-2010, 11:09 PM   #13
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
coolant lubricates the pump.
 Old 03-09-2010, 11:10 PM   #14
So does water wetter....
I would not just suggest distilled water. I think water wetter is a must if you use water.
Good Point.
 Old 03-09-2010, 11:57 PM   #15
Doc
Doc's Avatar
Groans: 35
Ahh I prob should delete that shameful stupid thought.. but I wont.. Ill leave my stupidity flag flying.. Chemistry was a long time ago.. but faaark.. wtf was i thinking, I wish I could groan at myself
Note: Dont drink when youve had zero sleep for days, and type... you'll just fail at thinking like me.. sorry guys im going to bed
The Following 2 Users Say Thank You to Doc For This Useful Post:
breakfstincluded (06-04-2011), phillyb (03-10-2010)
 Old 03-09-2010, 11:58 PM   #16
wankular's Avatar
Posts: 4,343   (View Stats)
That video is fucking hilarious.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
 Old 03-10-2010, 12:00 AM   #17
phillyb's Avatar
Groans: 1,940
fuck it. i'll get some water wetter then
FreeFlyFreak (03-10-2010)
 Old 03-10-2010, 10:08 AM   #18
The Kamikaze King!
Groans: 754
Just dont go up the mountain skiing, buying pot, or whatever and forget you have no coolant in there........ that is where the FAIL lies.
Suspension:
 Old 03-10-2010, 10:14 AM   #19
phillyb's Avatar
Groans: 1,940
yeah...
i live in the san fernando valley. it gets really hot, but it never freezes.
 Old 03-10-2010, 03:38 PM   #20
fjames's Avatar
Posts: 1,058   (View Stats)
This thread in general has me confused. Is there some deep set prejudice against antifreeze?
With extended life pre-mix readily available, isn't it a no-brainer to just grab some and be happy? I picked up a gallon of Prestone at Wal-Mart last week to top off my fl22 - the label is pretty funny, it basically says "this shit'll mix with anything, so don't worry about your manual." So I didn't, especially after finding out fl22 is some kind of super double secret Mazda stuff, which has to be bullshit.
The Following User Says Thank You to fjames For This Useful Post:
 Old 03-10-2010, 08:05 PM   #21
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
Groans: 38
dammit philly go get coolant not water wetter. get some cheap shit like peak 50/50 mix and fill your shit up. Make sure to flush all the old shit out real good...
bykeryder4life is offline   Reply With Quote
 Old 03-11-2010, 11:54 AM   #22
I <3 your mom
Dash08's Avatar
Groans: 293
So, i did a little comparing between regular anti-freeze and Mazda's FL22. The only differences that I can see are that Mazda uses a 55/45 mixture and a couple different ingredients. It also states that the FL22 is designed specifically for aluminum engines.
That could have some value, but as far as FL22 being some super special anti-freeze is highly doubtful.
 Old 03-11-2010, 01:12 PM   #23
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
since it never gets cold there, run like a 60/40 or 70/30 water/antifreeze mix and throw in a bottle of water wetter for good measure.
 Old 03-12-2010, 11:42 PM   #24
jv92red's Avatar
Posts: 319   (View Stats)
jv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the world
In SoCal you'll be fine running Distilled water + Water Wetter. It RARELY drops below 40 here so no worries of freezing. Also, water is more efficient in transferring it's heat off than anti-freeze. To make water more efficient with heat transfer you can decrease it's surface tension by making the water "wetter" Water Wetter also gives the rust and corrosion protection you wouldn't get by running straight water. Of course In any other colder climate than SoCal I would always want to run some kind of a anti-freeze mix with water.
By the way, water doesn't boil at 212F in a sealed pressurized cooling system. Boiling point is higher, not sure what that # would be. Guess it depends on a few different factors.
Here are some #'s to look at to see the science behind water's cooling ability (adding in Mercury and olive oil for comparative purposes only):
Thermal conductivity in W/m K (higher is better):
Mercury = 8.3
Water = 0.67
Glycol, Antifreeze = 0.25
Olive Oil = 0.17
Heat Capacity in kJ/kgK (Higher is better):
Water = 4.184
Glycol, Antifreeze = 2.38
Olive Oil = 1.97
Mercury = 0.14
So in a nutshell, Water is the best liquid for holding heat. Practically, it is also the best for transferring it.
Oh yeah... disclaimers:
Don't use Olive Oil unless it's Extra Virgin. (Don't be a cheap ass)
ALWAYS USE DISTILLED WATER. Not garden hose water like my dad taught me.
jv92red is offline   Reply With Quote
 Old 03-13-2010, 06:24 PM   #25
Groans: 38
for every 1 psi of pressure you add to the system it raises the boiling point approx. 3*F
 Old 03-13-2010, 04:15 AM   #26
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
fuck water wetter.
u wanna break surface tension put a couple drops of dishsoap.
philly use 50% fl-22 or any approved coolant (that is already a 50/50 mix )and then the other 50% distilled water.
this will yield a 75/25 water/coolant mix and will be best ovarall
 Old 03-11-2010, 01:09 PM   #27
I <3 your mom
Dash08's Avatar
Groans: 293
Originally Posted by pat bateman View Post
yeah, like blue and yellow dye.
Yeah, I'm no chemist. I could barely pronounce the names. Just throwing it out there.
Coolant smell cpspeed6 MazdaSpeed 3 - Engine, Transmission & Driveline 4 05-24-2015 04:56 PM
draining coolant rodrigo MazdaSpeed 3 - How-To's 16 07-27-2009 09:46 PM
Coolant Leak for me Derek88 MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-23-2008 05:33 PM
Type of coolant fluid bova MazdaSpeed 3 - Engine, Transmission & Driveline 6 04-30-2008 09:08 PM
Page generated in 0.50433 seconds with 33 queries
