 Old 01-19-2012, 08:23 PM   #1
mutiger93gt's Avatar
Posts: 30   (View Stats)
mutiger93gt will become famous soon enough
Default CP-E Downpipe bolt question
I bought my CP-E downpipe used and need to know what size bolts/nuts I need to attach the downpipe to the catback exhaust. the catback is stock.
thanks for the help
2012 Focus SFE - Currently at 29.5MPG and climbing.
mutiger93gt is offline   Reply With Quote
 Old 01-19-2012, 08:26 PM   #2
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
Use the stock bolts from the cat back
And get a hpfp before you go boom boom
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Last edited by Boost Addict; 01-19-2012 at 08:26 PM. Reason: MSF Database - Automerged Doublepost
Boost Addict is offline   Reply With Quote
The Following User Says Thank You to Boost Addict For This Useful Post:
deadlandxtreme (01-20-2012)
 Old 01-20-2012, 03:32 AM   #3
We put that in first. We had trouble with the down O2 so I have to wait for that to get here before we finish her up.
 Old 01-22-2012, 05:25 PM   #4
For the CP-E downpipe, to bolt the downpipe to the exhaust, do you use the bolts that bolted the downpipe to the second cat pipe?
 Old 01-22-2012, 05:28 PM   #5
No you use the bolts that connect the 2nd cat to the cat-back
FREEKTUNE
 Old 01-23-2012, 11:40 AM   #6
On my car, these appear to be studs. CP-E is telling me to use a 1/2 bolt, with 2 lock washers and the length of the bolts to be 3.25". I was going to just use the bolts that connect the first and second cats, is this wrong or right?
 Old 01-23-2012, 11:51 AM   #7
They are just bolts, use whatever fits in there with room for a nut on the other side.
FREEKTUNE
 Old 01-23-2012, 08:26 PM   #8
foodtime's Avatar
Posts: 225   (View Stats)
@mutiger9gt are you getting a cel 2096 yet after the DP install? how many bungs do you have after the catalack on the DP? I'm wondering if the previous owner I got mine from installed a second bung to solve the check engine light problem.
 Old 01-24-2012, 05:05 AM   #9
I just have two and as soon as I get her up and running I will let you know.
The bolts I ended up using per CP-E customer service were a 3.5"x1/2" bolts. I used two flat washers, one lock washer and a nut.
Thanks guys for the help.
bolt size question Ozark Gen2 MS3 General Discussion 4 07-13-2011 05:53 PM
Question about Crankpulley bolt.... drknyte MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-05-2011 01:30 PM
Missing Bolt Question MOVOVR MazdaSpeed 3/6 - Turbo Induction 3 03-29-2010 01:05 PM
Urgent Bolt Size Question >> Alpha MazdaSpeed 3/6 - Turbo Induction 10 02-01-2010 11:21 AM
downpipe bolt pattern MTuning MazdaSpeed 3/6 - Turbo Induction 2 08-16-2008 10:58 PM
Page generated in 0.29145 seconds with 22 queries
