 Old 12-15-2010, 02:27 PM   #1
Adam is so pro's Avatar
Posts: 410   (View Stats)
Adam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the worldAdam is so pro is the leader of the world
Default Custom Performance Engineering™ Side Mounts are RELEASED
Passenger Side Mount Price: $250.03
Driver Side Mount[/size] Price: $221.30
It's is finally time to get the power to the wheels! cp-e™ is proud to release the driver side engine mount for mazdaspeed3 gen1 and gen2. Our side mounts have been a long time in the making. We have been testing the cp-e™ side mounts for more than 8 months on numerous cars including i-Moto Racing’s grand am series mazdaSPEED3s. We are confident that these will be the last side mounts you will ever need.
The driver side engine mount brackets are made from 1/4” mild steel that is laser cut for precise fitment. The bushing housing is CNC machined from a solid block of aluminum. And like our rear motor mounts these bushings are made from rubber instead of urethane.
You have the power to choose your own durometer! We let you decide what degree of comfort vs stiffness you want to run. The 60 durometer is for the driver that is looking to get the power down to the ground without sacrificing too much comfort. The 75 durometer is more for those that drive their cars hard. No matter which durometer you chose the engine will have noticeably less movement from stock.
Say goodbye to wheel hop and torque steer when you combine this with our passenger side mount and already popular rear motor mount.
Adam is so pro is offline   Reply With Quote
The Following 2 Users Say Thank You to Adam is so pro For This Useful Post:
Enki (12-15-2010), super_pablo_ (12-22-2010)
 Old 12-15-2010, 02:35 PM   #2
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Awesome
There is a discrepency in prices if you buy the set.
Select the Driver Side
Both Side Mounts = $212.32
All 3 Mounts = $340.20
Select the Passenger Side
Both Side Mounts = $183.59
All 3 Mounts = $311.47
 Old 12-15-2010, 02:59 PM   #3
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
Awesome
Those values all have a "+" in front of them... do the math, shit's all the same.
Current Fail:
The Following 2 Users Say Thank You to MATT DAMOND For This Useful Post:
08.5MS3 (02-22-2011), Enki (12-15-2010)
 Old 12-15-2010, 03:20 PM   #4
08.5MS3's Avatar
Groans: 89
Which is why I am getting a Master's in Exercise Physiology...thanks! Didn't catch that!
MATT DAMOND (12-17-2010)
 Old 12-15-2010, 02:38 PM   #5
FY"IED"N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
sub'd
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
 Old 12-15-2010, 03:13 PM   #6
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Hey Adam, any idea how bad the NVH is with all three at 75 duro?
 Old 12-15-2010, 06:57 PM   #7
After about 2k miles, they really settle in. I've even thought they were super shaky at idle, but showed friends and they couldn't tell the difference. There is LITERALLY no wheel hop. It's pro.
The Following User Says Thank You to Adam is so pro For This Useful Post:
Ckmazdaspeed3 (12-15-2010)
 Old 12-16-2010, 02:51 PM   #8
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Vibrations I expect and would be great if they do die down after a couple thousand miles. But what about noise? I heard the TRZ caused you to hear the transmission whine or something a lot more. Any word on these and the noise they produce?
MattJackson86 is offline   Reply With Quote
 Old 12-16-2010, 10:01 PM   #9
The noise you're talking about is the throw out bearing (or release bearing). Mine has screamed since the car was new. I grew used to it.
 Old 12-15-2010, 03:25 PM   #10
wankular's Avatar
Posts: 4,343   (View Stats)
Why is it that whenever I click a cpe link it says "requested page not found"?
2009 MS3 sport MGM
 Old 12-15-2010, 03:27 PM   #11
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
Who's taking the plunge? i have SU mounts up front an the CPE 75duro in the rear.
I used to have SU's all around & found that switching the CPE RMM gave me considerably less vibes with no noticeable performance degradation. I'm a little torn, as this is a pricey set. I love CPE's products, but I hate switching mods out to find that I haven't gained any additional performance/benefit. I did that recently with the TWM STS -> Full replacement (waste of money, imo...unless you want an even shorter STS)
vbt101 is offline   Reply With Quote
 Old 12-15-2010, 03:30 PM   #12
ms3brendan's Avatar
Posts: 1,017   (View Stats)
ms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the world
Subbed! Very interested. TRZ tranny mount was too much for me. Need a replacement to stop this wheel hop without making the car sound broken lol.
2012 BMW 135i //M-Sport
ms3brendan is offline   Reply With Quote
 Old 12-15-2010, 07:37 PM   #13
Ill try to get a hold of Josh and get lenny a set of these and wee if these help his car.
The Following 4 Users Say Thank You to Haltech For This Useful Post:
AJ713 (12-24-2010), hnda etr (12-16-2010), NJSPEED3 (12-16-2010), rodrigo (12-16-2010)
 Old 12-16-2010, 09:29 AM   #14
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
i can haz powah to the ground?
 Old 12-15-2010, 07:42 PM   #15
rtabagaboy's Avatar
Posts: 363   (View Stats)
rtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the world
Groaned at 7 Times in 3 Posts
I would really be interested in hearing about the NVH compared to the TRZ tranny 'driver' mount. I currently use the TRZ but if I could get the same performance and less NVH from the CPE I would definitely jump on these... NOW.
Need MOAR comparisons. If anyone can compare these side by side or before after please do so and share the wealth. CPE ROX.
2008.5 BlackMica Mods:
- Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it.
AZ Status!
rtabagaboy is offline   Reply With Quote
 Old 12-15-2010, 07:43 PM   #16
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
i want, but shits expensive! not saying its not worth it, i am sure it is...unfortunately i just 20mins ago bought a duralast gold top battery for my ms3 -> $80!!
PERM TUNED
 Old 12-15-2010, 07:53 PM   #17
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
Want...the TRZ tranny mount is badass but I agree with the comments about the NVH...
$500 for the set is a lot...but I have a feeling these will be absolutely top notch quality
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 12-16-2010, 02:20 AM   #18
turboneil's Avatar
Posts: 248   (View Stats)
turboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond reputeturboneil has a reputation beyond repute
someone by the drivers side and tell me how you like it.. want someones review before I drop 240 bucks on one mm.
turboneil is offline   Reply With Quote
 Old 12-16-2010, 09:21 AM   #19
vbt101's Avatar
I haven't been keeping up on aftermarket failures - how have CPEs RMMs been holding up?
 Old 12-16-2010, 10:25 AM   #20
The first batch, like two and a half years ago had a few problems. I don't know of many since.
I've had these on my car for about 6 months. 6 HARD months. Powershifting, launching etc. I prolly got my 60's around 1.9 consistently.
 Old 12-17-2010, 06:31 AM   #21
Originally Posted by -cj- View Post
Waiting for someone to review these before sinking any money into them. (Hope they send lenny a set)
What do you wanna know?
 Old 12-19-2010, 07:28 AM   #22
-cj-'s Avatar
Posts: 649   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
Which set do you have? I was thinking of grabbing a 60 duro one, but curious how bad the vibes are. Also if you already had the cpe RMM (I have the 60/whatever is softest), did you notice an additional improvement? Can you detail what it's like to drive with the full set? Idling with the AC on, does the car come apart?
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
The Following 2 Users Say Thank You to -cj- For This Useful Post:
Ckmazdaspeed3 (12-19-2010), claytonmk (12-19-2010)
 Old 12-21-2010, 09:16 AM   #23
All three mounts I have installed on my car are 75 duro. Moreso I got noise (from my shitty throw out bearing) than vibrations. However, they're there. Again, the bushings are rubber, not urethane so don't be intimidated. There is litterally NO wheel hop. And (as many of you now know) I beat the fuck out of my car. Powershifting, launching, etc. I got my 60' down to 1.85-1.90's consistently with Star Specs.
Idling with ac has added vibs, obvi.
-cj- (12-22-2010), cld12pk2go (01-25-2011)
 Old 12-16-2010, 05:01 PM   #24
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
if u have an act clutch with light flywheel and trz mm it will act like a fucken amplifier....
 Old 12-16-2010, 10:44 PM   #25
ms3brendan's Avatar
Whatever the noise is.. It makes the car sound broke. That's why many of us have removed the TRZ tranny mount. Hope to god these CPE mounts are more graceful.. I need the powuh to the ground by spring!
 Old 12-16-2010, 11:46 PM   #26
-cj-'s Avatar
 Old 12-17-2010, 01:57 AM   #27
Post pwned's Avatar
Posts: 799   (View Stats)
Post pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the world
In before self rattling destruction.
They look sweet.
2010 Mica Black
RMM/RSB/SRI+TIP
Post pwned is offline   Reply With Quote
 Old 12-17-2010, 05:05 AM   #28
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Groans: 75
Thats a good price..did they re-engineer them or what?
The Following User Says Thank You to Fagwagon For This Useful Post:
www.cp-e.com (12-19-2010)
 Old 12-17-2010, 12:52 PM   #29
www.cp-e.com's Avatar
Posts: 1,728   (View Stats)
We just spent a lot of time on the bushing design to make sure they last.
It seems that the TRZ mount uses urethane, we feel that the vibrations won't be nearly as bad because urethane is a pretty poor material for bushings because of some of its less attractive properties.
We feel that our mounts are a good compromise of stiffness and vibration.
Website: www.cp-e.com
 Old 12-17-2010, 08:39 PM   #30
08.5MS3's Avatar
Groans: 89
New pictures have been posted of the mounts. Forgive my ignorance; how is the driver's side mount going to bolt to the transmission? My TRZ is one piece and the bolt went directly through the bushing into the transmission. I am trying to piece it together, but can not seem to figure it out for the life of me...
 Old 12-18-2010, 12:22 PM   #31
fjames's Avatar
Posts: 1,058   (View Stats)
It's upside down from what you're used to. Triangle on tranny, 8 little fasteners attach the bushing to that (which means they're holding up your motor) and the mounting plate you're used to goes in "upside down" so the wings reach down to the bushing (horizontally mounted) on the tranny. That's how it looks to me.
The Following User Says Thank You to fjames For This Useful Post:
08.5MS3 (12-19-2010)
 Old 12-20-2010, 11:04 AM   #32
ms3brendan's Avatar
I think CP-E needs to post a diagram on how this is going to work haha I don't think anyone is 100% sure how it's supposed to go together from the photos.
 Old 12-18-2010, 10:05 AM   #33
Mike, the bottom "tripod" looking bracket with the actual mount attached bolts to the tranny. the top piece is the one with the 4 square holes cut into it. Pretty simple to install.
 Old 12-18-2010, 03:46 PM   #34
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
thats not me adam. how dare you!
now gimme a set
 Old 12-18-2010, 03:31 PM   #35
mo4130's Avatar
Posts: 118   (View Stats)
mo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant future
Groaned at 13 Times in 4 Posts
These are on my next to buy list. After reading about the trz and the vibe problems.
mo4130 is offline   Reply With Quote
 Old 12-20-2010, 11:23 AM   #36
SPEEDRAC3R's Avatar
Posts: 399   (View Stats)
SPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the worldSPEEDRAC3R is the leader of the world
RMM is on the short list for spring time mods, so depending on reviews, the whole kit might be the best way to go.
2009 MS3GT - JBR 3.0" Wide Path Full Intake System | CorkSport TMIC |NATOR'd Test Pipe | Autotech HPFP | COBB AP (freek PERM in process) | NGK LTR7IX-11 (6510) | SURE Anchors | Bilstein B8's | 35% Tint
SPEEDRAC3R is offline   Reply With Quote
 Old 12-20-2010, 12:03 PM   #37
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
top notch as usual & most importantly made in the
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
The Following 4 Users Say Thank You to whoosh@Realtune For This Useful Post:
cld12pk2go (01-25-2011), djuosnteisn (01-06-2011), www.cp-e.com (12-20-2010), xcoldricex (12-20-2010)
 Old 12-20-2010, 01:35 PM   #38
turboneil's Avatar
just ordered my Drivers side mount from CP-E in 75A. from the additional pics it looks strong enough for me. hope it works well with my TRZ RMM, PTP kicker mount and my AWR PMM.
 Old 12-20-2010, 02:17 PM   #39
ms3brendan's Avatar
Awesome. Let us know how the install is when you get it!
 Old 12-20-2010, 08:58 PM   #40
Chupacabras's Avatar
Posts: 175   (View Stats)
Chupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the worldChupacabras is the leader of the world
Think I'll order this full set once we get closer to spring, since I don't have a garage. I'm going to give it a few years before going power mod crazy, but going all in on suspension and support mods.
If these can tame the torque steer, it's money well spent. If my Mustang buddy said "fuck yeah torque steer" the first time he rode in it, that's a problem.
Chupacabras is offline   Reply With Quote
SUPER CUSTOM FMIC!!! SIDE TO SIDE BITCHES!!! superskaterxes MazdaSpeed 6 - Engine, Transmission & Driveline 58 10-29-2013 05:33 AM
Who has the SU side motor mounts? reddeerspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 23 06-30-2009 06:43 AM
TRZ side mounts? kopf Mazdaspeed3/6 General Discussion 55 12-18-2008 04:45 PM
Page generated in 0.66563 seconds with 45 queries
