 Old 05-07-2009, 05:15 PM   #1
pvms3g's Avatar
Posts: 9   (View Stats)
pvms3g has a spectacular aura aboutpvms3g has a spectacular aura about
Default downpipes
i am going to be buying a downpipe for my ms3 soon and i am thinking of going with either the turboxs or corksport downpipes. turbo xs has big power claims and i have not heard anything from corksport. the designs of the downpipes are much different too. which downpipe should i go with.
pvms3g is offline   Reply With Quote
 Old 05-07-2009, 05:18 PM   #2
AmillieMS6's Avatar
Posts: 1,700   (View Stats)
AmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the worldAmillieMS6 is the leader of the world
Groans: 365
Groaned at 594 Times in 575 Posts
cobb
AmillieMS6 is offline   Reply With Quote
 Old 05-07-2009, 05:33 PM   #3
ms3jake's Avatar
Posts: 695   (View Stats)
ms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the worldms3jake is the leader of the world
I have the cobb and am happy. Nice power no smoke or CELS!
ms3jake is offline   Reply With Quote
 Old 05-07-2009, 05:49 PM   #4
pvms3g's Avatar
why is the cobb going to be worth the extra 400 bones?
 Old 05-07-2009, 05:52 PM   #5
Speed3FTW's Avatar
Posts: 161   (View Stats)
Speed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to beholdSpeed3FTW is a splendid one to behold
A lot of people have been very happy with CPE's piece. The extra money spent is worth the quality you will get.
True Red 2008 MS3 GT, CPE Xcel CAI, SU Test Pipe/2nd cat delete, SU 62A Rear Motor Mount, SU Shifter Bushings, Cobb Shifter Counter-weight, Dashhawk on CPE mount
Speed3FTW is offline   Reply With Quote
 Old 05-07-2009, 06:27 PM   #6
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
well...the two dps op is coparing are shorties...the cobb is a full dp, meaning it replaces both cats, not just one. that's one of the major price differences.
 Old 05-07-2009, 08:29 PM   #7
Ploppity Drown's Avatar
Posts: 236   (View Stats)
Ploppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond reputePloppity Drown has a reputation beyond repute
Originally Posted by pvms3g View Post
...which downpipe should i go with.
Cobb.
Best designed/built DP IMHO
Ploppity Drown is offline   Reply With Quote
 Old 05-08-2009, 04:58 AM   #8
jeff4880's Avatar
Posts: 46   (View Stats)
jeff4880 has a spectacular aura aboutjeff4880 has a spectacular aura aboutjeff4880 has a spectacular aura about
I like the CorkSport design. I think the devorced waste gate pipe is the way to go with turbos.
jeff4880 is offline   Reply With Quote
 Old 05-08-2009, 05:38 AM   #9
dukebrown's Avatar
Posts: 264   (View Stats)
dukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the world
I have a Corksport, got it ceramic coated inside and out, and added a high flow cat to the mid pipe. Total Cost $440. Works fine.
That pic is in a Miata. Damn midget mobile. Seat was all the way back.
Mods: Turbo Inlet, Short Ram, IDRVSLO's L2AIC, TRZ RMM, Shifter Bushings, PG Mani, CS DP,HF Cat, DS Trans Mount, Stiffened Passenger MM, CDFP Internals, Saikou Michi OCC, DIY BS Delete, DIY Windage Tray. Falken 235/45 17 7.5
dukebrown is offline   Reply With Quote
 Old 05-08-2009, 08:35 AM   #10
iracer7's Avatar
Posts: 329   (View Stats)
iracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond reputeiracer7 has a reputation beyond repute
How did you add a cat to it? Weld it in yourself or get someone to?
iracer7 is offline   Reply With Quote
 Old 05-19-2009, 06:50 PM   #11
ptperformance's Avatar
Posts: 4,123   (View Stats)
PT-Performance.com
Check that one out. Perfect fit and does all that it claims to.
 Old 05-21-2009, 12:45 PM   #12
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
The Corksport is a nice piece. Its divorced wastegate design has shown to give the best continuous flow, and thus provides the best power/price ratio. The full length downpipe can be had for less than 500 dollars, and the fit and finish are awesome, not to mention they are instock and ready to ship.
Jeff at PG
All wagon, No traction
wassup61 is offline   Reply With Quote
 Old 05-21-2009, 01:04 PM   #13
iracer7's Avatar
delete
Cobb AP, CPE SRI, Cobb Turbo Inlet, Turbosmart Dual-Port BOV, ETS 3.5" TMIC, TRZ Rear Motor Mount, TurboXS Race Pipe, TWM Shifter Bushings, Dabears2k 35W 6000k HID's, Luminiacs 2500k halogen fogs, Putco brake light led bulbs, CPE tow plate, Cobb Springs, OZ Racing Ultraleggara Gold Wheels, weapon r torque damper
GB: Stainless Works Downpipes wassup61 Mazdaspeed3/6 General Discussion 29 04-06-2009 02:47 PM
CPE downpipes phailerider Custom Performance Engineering (cp-e.com) 27 11-25-2008 10:58 AM
Page generated in 0.31762 seconds with 30 queries
