 Old 02-09-2011, 04:54 PM   #1
Speed PR's Avatar
Posts: 7   (View Stats)
Speed PR will become famous soon enough
Groaned at 6 Times in 1 Post
Default Engine Mounts
Zup Guys, I just bought an 07 Speed 3... and just want to know what do you guys say about the Engine Mounts. Between the CP-E and SU. Should I buy only the RMM or should I buy the set of three to reduce the wheel hop. Thanks!
Speed PR is offline   Reply With Quote
 Old 02-09-2011, 04:55 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
idk
 Old 02-09-2011, 05:00 PM   #3
ScarMS3's Avatar
Posts: 2,088   (View Stats)
Groans: 97
By idk he means search for your self, it has been discussed much....and don't forget trz mounts while you are looking
*** my bad, I don't claim to know what Philly knows or wants, only guessing***
 Old 02-09-2011, 05:06 PM   #4
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
trz combo from pg.
 Old 02-09-2011, 06:56 PM   #5
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
I'd start with the RMM because its a cheap and pretty easy to install. Helps with the 2nd gear engagement IMO. I bought the CP-e mount because they had the winter sale going on which I think they still do. I don't have any experience with the side mounts but they are on my to do list after some power mods I've got pre-ordered.
ak_spray is offline   Reply With Quote
 Old 02-09-2011, 08:13 PM   #6
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
Thank god, finally a thread on motor mounts! I've been looking for a thread like this for months! Yes!
 Old 02-10-2011, 07:59 AM   #7
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
They hold your engine in.
 Old 02-10-2011, 04:16 PM   #8
Speed PR's Avatar
Thanks Spray....
And what about the Tranny mounts from TRZ does it worth it?
 Old 02-10-2011, 06:09 PM   #9
08.5MS3's Avatar
Groans: 89
Originally Posted by Speed PR View Post
Thanks Spray....
Yes.
Buy all the mounts from cp-e. A kit designed to work together.
ak_spray (02-10-2011)
Engine mounts.. whats the Best!! dr.swoop MazdaSpeed 3 - Engine, Transmission & Driveline 35 12-02-2010 02:10 PM
Engine mounts? Mcopping MazdaSpeed 3 - How-To's 45 06-10-2010 06:03 PM
Best engine mounts??? 18psiWhiteMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 21 11-11-2009 07:19 PM
TRZ TM and SU engine mounts ms3boost MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-27-2009 07:56 PM
Page generated in 0.28184 seconds with 26 queries
