  • 1 Post By ms3boost
 Old 05-01-2009, 12:00 PM   #1
ms3boost's Avatar
Posts: 400   (View Stats)
ms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to behold
Default everything neded to build motor?
since people are starting to blow there fully bolted reowrked turbo speeds on meth, that is really starting to make me wanna just say fuck it go big or go home and put a gt30 on the car
i was wondering what is all need to do a built motor?
-pistons
-rods
-arp head studs?
what gaskets are needed and is there any bearings needed?
2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot
Future Mods[/B]auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal!
ms3boost is offline   Reply With Quote
 Old 05-01-2009, 12:05 PM   #2
Grim's Avatar
Posts: 2,395   (View Stats)
Groans: 70
yes you will need main and rod bearings.you might as well get a full gasket set.
Grim is offline   Reply With Quote
 Old 05-01-2009, 01:58 PM   #3
andre0121's Avatar
Posts: 347   (View Stats)
andre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond reputeandre0121 has a reputation beyond repute
ill sell you my whole kit brand new
andre0121 is offline   Reply With Quote
 Old 05-01-2009, 02:29 PM   #4
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
Clutch. Do the clutch while the engine is out of the car. With a built motor you're gonna want a clutch and its a 45 minute job with the engine removed vs. an 8 hour job with the engine still in.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 05-01-2009, 03:00 PM   #5
ms3boost's Avatar
dont worry i had another thread about that made and would be doing it at the same time
JMullins7 likes this.
 Old 05-01-2009, 03:07 PM   #6
MarkyMark's Avatar
Posts: 1,624   (View Stats)
Groans: 62
Rods
Pistons
Rod/Main bearings & thrust washer
ARP main and head studs
Clutch/Flywheel
Flywheel Bolts
Crank pulley bolt
Full gasket set
I stock all of these on a regular basis.
MarkyMark is offline   Reply With Quote
The Following User Says Thank You to MarkyMark For This Useful Post:
phillyb (05-26-2009)
 Old 05-01-2009, 03:16 PM   #7
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
Don't forget machine work.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 05-01-2009, 03:20 PM   #8
NEC
FWIW I don't think shon did any machinework on his motor, but when I asked him what he would have done differently he said he would have done it instead of skipping it.
 Old 05-01-2009, 04:36 PM   #9
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Do the machine work...If your not going to do it right then dont do it at all.Your going to want to bore it .020 over also just to get rid of mazda crappy machine work they done to the car.
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 05-01-2009, 11:02 PM   #10
ptperformance's Avatar
Posts: 4,123   (View Stats)
Better yet, get a built motor with the proper parts in it all ready. Simple. Sure it will cost more, but in the long run and after the assembly time and machine shop work, your going to be just as far into it as if you would have bought one from a vendor.
We will have motors for your cars here very soon, that are properly built.
 Old 05-02-2009, 12:31 AM   #11
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
I'd also consider doing any and all modifications to the engine at that time as well.
For example, getting the ring gear cut off the crank prior to being balanced. Installing a windage tray, or a baffle tray. Installing a lightweight pulley prior to timing anything...clutch/flywheel. Whatever manifold you choose for the car. If you're doing cam's, now's the time! Valve jobs, etc.
If your car has a lot of miles on it, I'd consider replacing the water pump, thermostat. (Heck if the car has a real lot of miles, might inspect the oil pump)
Of course replace all seals, gaskets. If you have the money, I'd get a silicon radiator hose kit...why bother putting the rubber junk back on there if you don't have to....far easier to install those hoses while the engine is being put back in, then afterwords.
On that point, I'd also replace all the pcv valves, and replace all vacuum lines with silicon instead of rubber.
To really do it right, you want pretty much every single wear item replaced...that way you'll be good for another 100k+ miles after the rebuild. It always sucks to spend all that time, all that money replacing and rebuilding an engine, and then have some cheap ass wear item part break and have to take all this crap apart to replace it...when you could have done it at the same time in a few minutes.
Crossbow is offline   Reply With Quote
 Old 05-02-2009, 09:38 AM   #12
ms3boost's Avatar
my car is a 08 bought in October of 2007 and still doesn't even have 4,000 miles on it!
 Old 05-03-2009, 09:07 AM   #13
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
no no no
i did "minimal" machine work. did not do balancing.
if i were to do it again, i would do things alot different. id go all out. i would have left the compression stock.
 Old 05-03-2009, 09:15 PM   #14
smokedyou19's Avatar
Posts: 17   (View Stats)
smokedyou19 is a splendid one to beholdsmokedyou19 is a splendid one to beholdsmokedyou19 is a splendid one to beholdsmokedyou19 is a splendid one to beholdsmokedyou19 is a splendid one to beholdsmokedyou19 is a splendid one to beholdsmokedyou19 is a splendid one to behold
sleeves balanceshaft removal
smokedyou19 is offline   Reply With Quote
 Old 05-04-2009, 11:05 PM   #15
mrjoshyman's Avatar
Posts: 238   (View Stats)
mrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to behold
jeezel i put on 4k miles nearly every 2 months. neway, guess you wont have to worry about changing a lot of that stuff
mrjoshyman is offline   Reply With Quote
 Old 05-04-2009, 11:14 PM   #16
danesti's Avatar
Posts: 4,186   (View Stats)
Groans: 137
damn... with me being in the shop 5 hours a day for 16 days this summer with tools and a bitchin` new engine building room, with nothing to do but "keep occupied", its kinda tempting to buy a beater and go big with the help of the instructor and a group of students.
fuck me.
(Danems6 currently looking on autotrader for cheap truck)
2008 STi
Intake
Turboback
AP
Catch CAn 101, this is how you build them. ptperformance Mazdaspeed3/6 General Discussion 13 04-07-2009 11:57 PM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Sq build Strytnyne MazdaSpeed 3/6 - Car Audio & Electronics 10 12-18-2008 03:19 PM
Page generated in 0.35974 seconds with 32 queries
