 Old 06-11-2008, 09:53 AM   #1
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
Default HKS spark plugs installed *2 steps colder than stock
the NGK 1 step or heat range colder than stock I installed last summer served me well but it was time for a change
and here's why
although the NGK's "work" by closing the huge factory gap down to the Mazda spec
NGK suggests not to gap irridium plugs due to how fragile they are plus this rather large downsize in gap to .030-.032
the gap downsize creates an undesirable angle on the ground electrode
Again, you can do this....I've done it on two different sets (one set gapped at .032 and one at .030)
and they were fine...worked great as a matter of fact
as an aside, I did not notice much if any difference performance wise in the .032 to .030 gap differences between my two sets of 1 step colder NGK's
which leads me to this new set of plugs
HKS
they list them on their site(HKSUSA.com) for the speed 3
in a heat range of 7 which is identical to the NGK 1 step colder plug(only in terms of heat range) and they offer the plugs in a heat range of 8 which is 2 steps colder than OEM (OEM is a heat range of 6)
so far the car has responded well to the new plugs
I do not notice any difference in idle quality which I expected but suprisingly has not been affected
These HKS plus come correctly pregapped at .030 and can be installed right out of the box which is huge for some of you guys that aren't comfortable gapping plugs, especially irridium plugs
I checked all 4 and they were right on the money
So now we have plugs designed for the DISI MZR which DO NOT need to be gapped prior to use - Great!
I personally like this since the angle of the ground electrode remains correct vs. angled down too much when gapping to Mazda spec for the NGK 1 step colder plugs
the price may be an issue but doesn't seem all that bad in comparo to any other Mazda parts
you'll see them range from $23.00 - $27.00 per plug
the pics are not great but represent the statement of the NGK plugs, when gapped down to .032>the ground electrode is angled down and actually is sticking out past the center electrode
the NGK plug is even ground to center w/no angle issue
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
The Following 3 Users Say Thank You to whoosh@Realtune For This Useful Post:
Crossbow (06-11-2008), Lymerock (09-11-2008), subparpunk03 (06-11-2008)
 Old 06-11-2008, 10:37 AM   #2
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
nice! sub
 Old 06-11-2008, 01:19 PM   #3
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
If you want the same setup, just 1 step colder...
HKS
50003-M35LF - 1 Stage Colder Heat Range
That's from woosh on the 6club forums. Thought it would be useful here.
Crossbow is offline   Reply With Quote
 Old 06-11-2008, 01:51 PM   #4
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
it looks like your running lean as hell on one cylinder and boarderline on another....
Laloosh is offline   Reply With Quote
 Old 06-11-2008, 04:39 PM   #5
Yes, it does, very lean for sure on one of those cylinders.
 Old 08-28-2008, 05:43 PM   #6
Lymerock's Avatar
Posts: 1,436   (View Stats)
Lymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the worldLymerock is the leader of the world
been needing to go a step colder on my plugs and I came across these HKS which seem nice, but at more than twice the pice of the Denso ITV22's is it really worth having a perfect factory gap?
also, I see that some people feel the NGK's arent good because they need to be regapped quite a bit, again, does the longer ground electrode screw stuff up? I read about electrode vibrations and other odd bits today that has me thinkin the HKS is the way to go, but spending 100+ on 4 plugs is a hard pill to swallow.
Lymerock is offline   Reply With Quote
 Old 08-28-2008, 06:08 PM   #7
Look at the base ring, he is running plenty rich under boost. A little lean at idle and part throttle.
whoosh@Realtune (08-29-2008)
 Old 08-28-2008, 06:43 PM   #8
MazdaMan13's Avatar
Posts: 532   (View Stats)
MazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to beholdMazdaMan13 is a splendid one to behold
i think i'm goin to be switching over to hks spark plugs too
MAZDAMAN13 - 2.221, 9.378 @ 78.89, 14.309 @ 99.72 (CBE) no power-shifting
DON'T SLEEP ON THE MAZDA...:phillyb:
JDM PARKING LOL
MazdaMan13 is offline   Reply With Quote
 Old 08-29-2008, 05:11 AM   #9
thank you - good plug read buddy!
 Old 08-29-2008, 05:59 AM   #10
kraz3y's Avatar
Posts: 193   (View Stats)
kraz3y has a spectacular aura aboutkraz3y has a spectacular aura aboutkraz3y has a spectacular aura about
hmm imma try out the 1 step colder
kraz3y is offline   Reply With Quote
 Old 08-29-2008, 06:07 AM   #11
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
i have the ngk's as well with no issue
Piasini Tuned
power mods=SRI/Autoexe TMIC
312whp/336 tq
NYpest is offline   Reply With Quote
 Old 08-29-2008, 12:55 PM   #12
mrjoshyman's Avatar
Posts: 238   (View Stats)
mrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to beholdmrjoshyman is a splendid one to behold
how many miles do you have on your cars that your changing the plugs already?
mrjoshyman is offline   Reply With Quote
 Old 08-29-2008, 01:07 PM   #13
ztuner's Avatar
Posts: 554   (View Stats)
ztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the worldztuner is the leader of the world
Correct way to read plugs is the following.
1. Start with a new set of plugs (clean set will do)
2. Fire up the car make the pull, shut down the engine immediately
3. Pull plugs for inspection
Letting the car idle after the pull will give you false readings. Cruzing for extended periods will also give you a false reading.
thanks
Harry
Z32 Specialist
07 Sport
Cobb AP - V103f map
Cobb Sri
ETS 3.25 TMIC
Vibrant Catted midpipeback exhaust
Forge BPV
CS inserts
Dashhawk logger
Soon to follow
SSR Wheels and wider tires
CS downpipe
Check out
http://ztuner.com/newdyno.htm
ztuner is offline   Reply With Quote
 Old 08-29-2008, 02:45 PM   #14
Lymerock's Avatar
to my knowledge, none of us are switching due to mileage.
We are trying to combat pre-detonation aka knock
Im still on the fence, but im leaning strong toward the HKS plugs. Figure its not an item that needs often replacement, so 100 is a solid investment for a proper working plug out of the box.
<edit> lookin around I found a place to get em for 90.66 shipped, emailed em to see if they have any in stock
 Old 10-02-2008, 08:36 AM   #15
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
Don't mean to revive a dead thread, but how did those HKS work out for you Whoosh?
I just ordered a set of Denso 1 step colder plugs (I'm still running stock); I was told these are pre-gapped...? Can anyone confirm? I don't have anything to check gapping with. I used to have one of those little disc gappers, but for Iridium plugs, thats a NO-NO.
Anyway, what would warrant going 2 steps colder?
I'm no the fence here...some say colder plugs won't help knock, others say it solved their issues.
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline   Reply With Quote
 Old 10-02-2008, 10:08 AM   #16
Lymerock's Avatar
hks plugs are pregapped at .30 i think, might be .32, too lazy to check
after installing my 1 step colder hks plugs I havent seen the weird 5.9 readings I used to get, i do still get the small .7, .9 and occasional 1.9 weirdness
 Old 10-02-2008, 10:29 AM   #17
AutoXRacer's Avatar
Man, I would love results like that!!!! Anything less than 2.0 and I'd be a happy camper!!
 Old 10-02-2008, 02:15 PM   #18
Lymerock's Avatar
they arent cheap by any stretch, but ive been very happy so far
then again, most people with the denso's been happy too
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f10/hks-spark-plugs-installed-2-steps-colder-6656/
Mazda MPS Owners Club • View topic - E - Tuning This thread Refback 01-28-2012 05:54 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 6 - Engine, Transmission & Driveline 41 05-05-2016 08:49 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 06:52 PM
1 step colder plugs - stutter in 3rd bova MazdaSpeed 6 - Engine, Transmission & Driveline 55 08-19-2008 07:02 AM
Hows my spark plugs looking? Darksun280 MazdaSpeed 3 - Engine, Transmission & Driveline 5 05-17-2008 06:40 PM
Page generated in 0.37793 seconds with 32 queries
