 Old 02-19-2010, 07:56 AM   #1
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Default MM inserts
Who makes motor mount inserts ?
07 MS3
The original Genpoo Hater
 Old 02-19-2010, 08:08 AM   #2
wankular's Avatar
Posts: 4,343   (View Stats)
CORKSPORT Rear Motor Mount Insert For Mazdaspeed 3
2009 MS3 sport MGM
 Old 02-19-2010, 08:21 AM   #3
Will fuck up ur day
Chimmike's Avatar
Groans: 433
bitchin. Thanks for the link bro.
07 MS3
 Old 02-19-2010, 08:32 AM   #4
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Chim. dont bother using them...they arent' as durable as a whole new mount. TRZ,CPe and SU all make nice ones.
What a lovable bunch we are!!
The Following User Says Thank You to predapio For This Useful Post:
flyrevs2 (02-20-2010)
 Old 02-19-2010, 08:43 AM   #5
wankular's Avatar
Yeah, as long as you're going to be under the car taking the mount off you might as well get a whole new one. You can usually find a decent used one in the F/S section.
2009 MS3 sport MGM
 Old 02-19-2010, 05:30 PM   #6
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
As someone who went from stock to CS inserts to CP-e's 75 duro, I wouldn't waste time with the inserts myself either. Go with CP-e or TRZ's rear mount.
Frequentflyer is offline   Reply With Quote
 Old 02-19-2010, 06:16 PM   #7
dphm's Avatar
Posts: 64   (View Stats)
dphm is just really nicedphm is just really nicedphm is just really nicedphm is just really nice
I agree with pretty much everything here. I have the Corksport inserts on my car now and I don't feel like they make that much of a difference. I'm in the market for a full rear mount now.
dphm is offline   Reply With Quote
 Old 02-19-2010, 06:20 PM   #8
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I just don't want insane vibration translating to the cabin, hence why I asked about inserts.
07 MS3
 Old 02-19-2010, 06:30 PM   #9
Honestly, just stick with stock then because installing them is more trouble than it's worth unless you're under there doing an oil change or something. The vibes are really not bad at all with the 75 duro. They're definitely there, but not bad at all, so I'd expect the 60 duro to be even less noticable. Nothing I'd consider "insane" at all.
 Old 02-20-2010, 04:12 PM   #10
wankular's Avatar
I have the Street Unit one (62A duro I think) and the vibes aren't bad, I haven't even finished the break-in yet. When I first start the car I can feel it, but when moving and even stopped at a redlight it's barely noticeable.
2009 MS3 sport MGM
 Old 02-20-2010, 05:03 PM   #11
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I will give the other side.
I bought the inserts and like them a lot.
I didn't at first, there was a noticeable bump when starting the car, and vibes at idle, but after a few weeks the bump and vibes went away.
I would not like any added vibes at all, I would have got rid of the inserts if the vibes had not gone away after a little break in.
Suspension:
The Following User Says Thank You to FreeFlyFreak For This Useful Post:
Blackspeed (02-22-2010)
 Old 02-20-2010, 06:39 PM   #12
ericm979's Avatar
Posts: 165   (View Stats)
ericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond reputeericm979 has a reputation beyond repute
I had the inserts and have the CPE (60 durometer). The inserts give almost as much "tightening" of the drivetrain feel with only half as much of an increase in noise and vibration. Starting my car this afternoon after two weeks of driving a VW eurovan I'm thinking holy shit this car is rough. I know I'll get used to it again soon enough that it wont' seem worth it to switch back to the inserts. But having had both, I'd recommend inserts unless it's not your daily driver or you think that the rougher a car is, the faster it is.
ericm979 is offline   Reply With Quote
The Following User Says Thank You to ericm979 For This Useful Post:
FreeFlyFreak (02-20-2010)
 Old 02-21-2010, 12:42 PM   #13
mike8748's Avatar
Posts: 396   (View Stats)
mike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the worldmike8748 is the leader of the world
I too initially put the inserts in but 2-3 months later I was looking for a real MM.
TRZ had too much vibrations but besides that it was great.
I suggest going with CPe or StreetUnits new Mount.
07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map
Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold
mike8748 is offline   Reply With Quote
 Old 02-21-2010, 02:44 PM   #14
HLR Element's Avatar
Posts: 2,477   (View Stats)
Groans: 109
you barely feel the vibes, i have a SU mount i got from someone here for cheap and it's great. I hardly realize the vibes are even there anymore unless i'm alone in the car, at a stop light and can feel it a bit... i like it, more like the car is really alive
Mk7 GTI
 Old 02-21-2010, 07:19 PM   #15
speedtwee's Avatar
Posts: 30   (View Stats)
speedtwee is an unknown quantity at this point
75 duro cpe rmm. love it.
speedtwee is offline   Reply With Quote
 Old 02-22-2010, 08:26 AM   #16
Biggu's Avatar
Posts: 120   (View Stats)
Biggu has much to be proud ofBiggu has much to be proud ofBiggu has much to be proud ofBiggu has much to be proud ofBiggu has much to be proud ofBiggu has much to be proud ofBiggu has much to be proud ofBiggu has much to be proud of
they work quite well when you get them but they will eventually ware out and get soft.
Biggu is offline   Reply With Quote
 Old 02-22-2010, 08:37 AM   #17
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
I live in SW florida, and I run my ac almost all year long, night and day. I went with the inserts for that reason. All the guys saying the vibes aren that bad, are refering to non-ac vibes.
My old car, i had poly mount, tranny mount , and inserts on the side mount. the vibes werent bad at all, but i removed the ac, so i never knew what it was like with ac on.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
Corksport MM inserts: Now Available for the CX-7 MZRDISI4 CX-7 > Engine, Transmission & Driveline 13 11-19-2010 09:00 AM
Intake and MM inserts installed - now a beliver vegas79 MazdaSpeed 3 - Engine, Transmission & Driveline 14 11-22-2008 12:33 PM
Page generated in 0.35580 seconds with 31 queries
