 Old 05-03-2014, 06:48 PM   #1
Nogood's Avatar
Posts: 22   (View Stats)
Nogood has a spectacular aura aboutNogood has a spectacular aura aboutNogood has a spectacular aura about
Groaned at 24 Times in 1 Post
Default Need help, CEL lights P0134 and P0441
Hey, recently I got CEL for these 2 codes on my 08 MS3. It's all stock except for a Cobbs SRI.
P0134 Front HO2S circuit no activity detected ON 2 CCM
P0441 Evaporative emission control system incorrect purge flow ON 2 Evaporative
The car drives fine and the idle looks normal but I cleaned the MAF anyways and checked the gas cap. Still have these codes. While searching online about it, some were saying the wires to the O2 can become disconnected or the O2 fuse was blown. As for the purge valve, it could be stuck open.
Are these two codes somehow related because they both appeared at the same time.
Any help is appreciated, thanks!
P.S: mods, just realized I posted in the wrong section.
Nogood is offline   Reply With Quote
 Old 05-05-2014, 09:12 PM   #2
Nogood's Avatar
For anyone who searches this or cares.
Just changed the first (primary) O2 sensor. It was a piece of cake to change. Went for a drive to warm it up, shot it with PB blaster. Then removed it with no effort. Didn't encounter the cross threaded from factory problem.
CEL - P0441 ( EVAP ) Caldwell Mazdaspeed3/6 General Discussion 10 04-14-2014 01:39 PM
CEL P0031 and P0134 matto MazdaSpeed 3/6 - Turbo Induction 5 01-19-2012 11:56 AM
CEL P0134 & P0139 f-castrillo 2010 MS3 - Troubleshoot/Diagnostics 6 08-06-2011 02:17 PM
HIDs, Reverse lights, Liscence Plate lights Franconemo Exterior 31 06-12-2010 03:25 AM
DTC P0441??? spnkr21 MazdaSpeed 3 - Engine, Transmission & Driveline 2 03-28-2009 06:05 AM
Page generated in 0.23199 seconds with 20 queries
