 Old 12-28-2013, 04:33 PM   #1
EvoFire's Avatar
Posts: 389   (View Stats)
Default PCV Failure
Back story: I have a CorkSport catch can, the first generation one that I got in late 2012, the current one shown on the site looks quite a bit different. I bought it used off some guy locally and it worked when he had it. The can dripped out quote a bit of residual oil so I assume it worked.
I had put it on, but shortly removed it as I needed some warranty work done due an oil leak from the valve cover and main seal. During that time it didn't catch anything and my mechanic said cause the crappy hoses ripped.
Fast forward to this November when I finally got around to putting it on again. Drove it around for a couple weeks and it still caught nothing and the hoses were all done properly. While I was getting my brakes done last weekend I pulled the undertray off again and checked the hoses. Lo and behold, nothing in the hoses either, just some clean water in a brand new hose.
My mechanic thinks my PCV is stuck closed? I haven't heard of that happening, and I was wondering if anyone here has heard of such a thing? I'm still under warranty, and if I can prove that its broken I want to get it fixed ASAP.
Can't really explain why the catch can isn't catching anything, and there is nothing in the hoses.
Thanks
 Old 12-28-2013, 04:41 PM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
chances are your rear main blew because you're no longer pulling any vacuum on the block, and that's also the same reason the pcv isn't flowing. there's no vacuum drawing through it.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 12-29-2013, 02:04 AM   #3
EvoFire's Avatar
Is it not pulling any vacuum because it was installed incorrectly? I guess I'll triple check what is going on with the can.
Is there a way to check if the PCV is doing what its supposed to be?
 Old 12-29-2013, 08:38 AM   #4
Tokay444's Avatar
Groans: 793
It's not pulling vacuum because there is no source of vacuum.
Just please explain the routing to confirm.
Demodded.
The Seals
 Old 12-29-2013, 09:08 AM   #5
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
My signs of pcv failure was excessive oil in my Vocc off of the valve cover. The can was getting full in hours of driving. It was pretty bad. Once I changed it...back to normal. I run the 2nd version of CS' occ and I routed it the tradition way. It works fine for me. As Tokay said, explain or make a crappy paint pic of how you routed your lines.
Mods: stock
SLOWHATCH (12-29-2013)
 Old 05-25-2014, 04:51 PM   #6
EvoFire's Avatar
Bringing this back. I haven't been driving the car much since my shocks were blown and haven't had time to deal with this until now.
I checked the hoses, its going from the PCV to OCC to intake manifold. I ran a clear tube to see if anything is blowing through the hoses, and nothing at all, the tube was clean after 2 weeks.
 Old 05-25-2014, 05:18 PM   #7
faeker's Avatar
Groans: 731
Don't bring back a dead thread. Make your own. It'll simplify answering
now with three times the hate
Mods: stock
 Old 05-25-2014, 05:46 PM   #8
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
This is his thread.
The Following 4 Users Say Thank You to Agent_Orange For This Useful Post:
Dralphy (05-25-2014), faeker (05-25-2014), gigliotti175 (05-26-2014), mr_mazda329 (04-23-2015)
 Old 05-25-2014, 06:33 PM   #9
jm211's Avatar
Posts: 943   (View Stats)
Lol.
 Old 05-25-2014, 07:08 PM   #10
faeker's Avatar
Groans: 731
I never read above the newest post lol. Makes being a dickbag easier.
Mods: stock
Agent_Orange (05-25-2014)
 Old 05-26-2014, 12:27 PM   #11
EvoFire's Avatar
@Tokay444; can you shed any light on the this?
@faeker; I have nothing in the can at all. My mechanic is suggesting the check valve is jammed shut for some reason.
 Old 05-26-2014, 12:40 PM   #12
faeker's Avatar
Groans: 731
I had the same issue. When mine clogged I was getting excess oil in my other can on my valve cover. Maybe check then line there to see if it has more oil than usual. How many miles?
Mods: stock
EvoFire (05-26-2014)
 Old 05-26-2014, 01:02 PM   #13
Tokay444's Avatar
Groans: 793
Is the check valve installed backwards?
Demodded.
The Seals
Agent_Orange (05-26-2014), btstarcher (06-02-2014), EvoFire (05-26-2014), faeker (05-26-2014)
 Old 05-26-2014, 03:13 PM   #14
EvoFire's Avatar
@faeker; I'll check the VC, but I just had the VC gasket done a year ago under warranty , would Mazda figure to investigate something like that?
@Tokay444; I don't believe the PCV has even been touched. Are you suggesting that it came backwards from factory?
 Old 05-26-2014, 04:31 PM   #15
Tokay444's Avatar
Groans: 793
I didn't read more that a couple posts. I thought you had the standard check valve on the manifold.
Demodded.
The Seals
 Old 05-26-2014, 05:03 PM   #16
EvoFire's Avatar
Is there a check valve on the manifold as well? I just know there is one on the PCV.
 Old 05-26-2014, 05:46 PM   #17
faeker's Avatar
Groans: 731
He means a check valve inline with the cc line I believe. If you don't have a check valve between the pcv and the can you should get one. I'm thinking your PVC is clogged.
Mods: stock
 Old 05-26-2014, 08:12 PM   #18
EvoFire's Avatar
Time to book an appointment for warranty....
 Old 06-02-2014, 05:15 PM   #19
sidekick's Avatar
Posts: 3,093   (View Stats)
What are you going to tell them though? If there are no other signs of something failing, I don't think they are going to replace anything based on your catch can not catching anything.
 Old 06-04-2014, 04:41 PM   #20
EvoFire's Avatar
I know, currently scratching my head on that one.
 Old 06-04-2014, 05:04 PM   #21
faeker's Avatar
Groans: 731
pull you're pcv plate/valve and see if it's gunked up.
Mods: stock
SURE RMM Failure clowncar 2010 MS3 - Engine, Transmission & Driveline 141 05-14-2012 06:57 PM
Clutch Failure at 5K ASHMS3 2010 MS3 - Engine, Transmission & Driveline 27 12-19-2011 11:02 AM
3rd VVT Failure JumpingJackson MazdaSpeed 3 - Engine, Transmission & Driveline 41 06-22-2011 11:12 AM
Failure Dave092 Mazdaspeed3/6 General Discussion 18 05-06-2011 09:24 AM
WTF do I have to do to fix my RMM after PMM failure. Adam is so pro MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-18-2009 08:23 PM
Page generated in 0.38826 seconds with 25 queries
