 Old 06-23-2014, 02:16 PM   #1
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Default To replace or not to replace the throwout bearing that is the question?
I've got an 07 speed3 getting close to 80k. I have the dogbone tranny mount, which is pretty stiff and transfers a lot of tranny noises to the cabin. My throwout bearing is loud, it kind of sounds like the engine is knocking but it completely goes away once the clutch pedal is fully pressed.
So, I've researched and some say not to worry about it. My stock clutch is still good. Should I replace that throw out bearing? Am I risking anything?
 Old 06-23-2014, 03:03 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Another TOB thread...How useful!
Bro, do you even search?
Johnasaurus (06-30-2014)
 Old 06-27-2014, 07:09 AM   #3
MSMS3's Avatar
Posts: 2,826   (View Stats)
OP, just roll with it. Normal. And, yes, stiffer mount(s) make it louder. And please search before posting. While you claim to have done so, must not have read much.
 Old 06-30-2014, 07:23 AM   #4
Zipper's Avatar
Posts: 53   (View Stats)
Zipper is a splendid one to beholdZipper is a splendid one to beholdZipper is a splendid one to beholdZipper is a splendid one to beholdZipper is a splendid one to beholdZipper is a splendid one to behold
Owned my 08 speed since new, has 81k on it. my throw out bearing has always done it. in fact come to think of it, every manual vehicle i've owned did it to an extent.
leave it alone, save your $$. when its time to do the clutch, do the bearing too!
Zipper is offline   Reply With Quote
 Old 06-30-2014, 07:29 AM   #5
btstarcher's Avatar
Posts: 4,852   (View Stats)
If it's REALLY loud, it might be the dual-mass flywheel coming apart.
SnailTune in progress
Noisy Throwout Bearing urville 2010 MS3 - Engine, Transmission & Driveline 58 11-24-2015 03:23 PM
Lube in place throwout bearing wolph69 MazdaSpeed 3 - Engine, Transmission & Driveline 5 10-01-2013 08:20 AM
Clutch install, is my throwout bearing/ thrust bearing fork dead? Mad_Aussie MazdaSpeed 6 - Engine, Transmission & Driveline 2 04-22-2013 04:40 PM
Think my wheel bearing needs to be replace? contreras MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-08-2012 09:11 AM
should i replace my struts before getting springs? and another question mazdaspdmike MazdaSpeed 3/6 - Suspension & Brakes 24 06-16-2011 01:27 PM
Page generated in 0.25422 seconds with 24 queries
