 Old 11-29-2013, 03:05 PM   #1
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
Default Shift Fork replacement/syncros?
Well I 'am almost positive that my 3/4th shift fork pads are damaged, I have trouble shoot all other obvious possibilities such as adjusting the cables, swapping in the ford honey....the transmission has roughly 40-45k on it's clock.
Under load, at about 5k rpm 2nd to 3rd or 3rd to 4th I get a nice loud grind, all gears are staying engaged during normal shifting and not popping out, but 3rd and 4th under load will grind and will not cleanly engage.
I 'm replacing all shift forks with the upgraded bronze pads but my questions is can these pads wearing also damage a synchronizer to the point it also needs to be replaced.....I'm kind of leery of dismantling the entire transmission, it is just a little more complicated then a meat and potato engine rebuild.
Thanks for any useful input and opinions welcomed.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
Broken gears, shift forks, and syncros 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 136 01-09-2013 08:57 PM
shift fork mxlplx71 MazdaSpeed 3 - Engine, Transmission & Driveline 17 08-05-2012 12:55 PM
Page generated in 0.29179 seconds with 24 queries
