 Old 04-29-2013, 07:32 AM   #1
Burdoror's Avatar
Posts: 52   (View Stats)
Burdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud ofBurdoror has much to be proud of
Default Starter issue
Hi.
I need a tip: what and where should look for..
yesterday I was stopped by police.. speed... However after small chat I was released and asked to go. I turned the key and... nothing. All light on console were OK. But starter did not turned on. I asked Police (2 guys) to push me and this helped of course. Same situation was on next stop (gas station). And I already thought that it is because failed starter. But definitely no - After next gas station brake (I had to do 1000km yesterday) car started normally. Same today morning.
I'm confused totally.
So can you please help me with some tips - what should I check before visiting the service?
I have to do same trip this Friday and I'm little bit stressed
Thanks a lot!
Mazda 3 MPS 2007
Street Shadow Garage (SSG) custom: FMIC (Precision), 3" High flow cat DP, 3" CBE.
Autotech HPFP internals, Forge BPV Gen2, K&N Typhoon,CPE TIP, Sachs clutch, Fidanza flywheel, STRI oil temp and egt temp, Innovation AFR, Bilstein B14, TRZ Dog Bone RMM, James Barone Racing RSB, HEL Brakelines, Tenzo-r DC5, Bridgestone S001 235/40
Powered by DisiTune
295WHP
Burdoror is offline   Reply With Quote
 Old 04-29-2013, 09:02 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Two most popular things-
1) starter binding up
2) starter primary loose or corroded
For 1, use a socket extension or similar to reach through the Intake Mani and give it a few love taps. You'll often here a pop as the bind is released. Will start normally after that, but is often indication of wear and expect it to happen again
For 2, go up from underneath (or remove IM) and check condition of the largest wire connected to the starter. Many have reported this connection to be either loose or corroded, either resulting in poor connection.
340hp / 371tq
 Old 04-29-2013, 09:21 AM   #3
Burdoror's Avatar
Thanks a lot.
Mazda 3 MPS 2007
Powered by DisiTune
295WHP
 Old 04-29-2013, 10:14 AM   #4
leon78's Avatar
Posts: 2,595   (View Stats)
Wiggle the small white wire on the starter.
2013 Scion FR-S (Whiteout)
Less parking more racing
The Following 2 Users Say Thank You to leon78 For This Useful Post:
bigmike (07-29-2013), skiptowncat (10-13-2013)
 Old 04-29-2013, 10:33 AM   #5
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Beat it with a hammer. Seriously.
 Old 04-29-2013, 10:39 AM   #6
blackms3_71's Avatar
Posts: 2,250   (View Stats)
i installed the 3bar map sensor, and that harness runs to the starter, i guess some how it got loose when i installed the 3 bar and i had the same problem no starter, went under there and wiggled some wires around and sure enough the bitch works again so deff check that out
The Following 2 Users Say Thank You to blackms3_71 For This Useful Post:
impossible (10-14-2013), leon78 (04-29-2013)
 Old 07-29-2013, 04:00 PM   #7
bigmike's Avatar
Posts: 278   (View Stats)
bigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond reputebigmike has a reputation beyond repute
This just saved my fucking ass. I want to give every one of you my dick. Thank you so much
2/1 91 octane gasoline/E85, Stratified tuned, ~340 hp/360 ft·lb
AEM Water/methanol injection kit 550 ml/min nozzle ~5 psi/10 psi triggers 1/1 methanol/water Filter Autotech HPFP internals BrakeBest Brake pads Front Clarion XC1410 car amplifier COBB Tuning Downpipe Catback exhaust Front mount intercooler v2.0 XLE bypass valve Hybrid mode Short ram intake Turbo inlet hose Airbox Sport springs Short throw shifter Shift knob Shifter weight AccessPORT V3 Corksport Mid chassis brace Oil catch can Rear sway bar Radiator shrouds LED light kit cp-e SAFEseal injector seals Excalibur Wheel Accessories Black acorn bulge lug nuts 3/4" Echlin Ignition Parts Tire pressure monitoring system Left, right tire Firehawk Wide Oval Indy 500 tires 225/40R18 XL Ground Control Frim strut bump stops Front Interstate Mega-Tron battery James Barone Racing Rear motor mount 88 durometer Transmission side motor mount 80 durometer Passenger side motor mount 80 durometer EGR block off kit Thermal insulating intake gasket kit Thermal insulating throttle body gasket Coolant bypass kit Solid shifter bushings Bypass valve hose Kicker 40CSS684 component speaker system Front KS68 speakers Rear 11PT10CA powered subwoofer enclosure Koni Sport yellow shock absorbers Front 540 degrees LLumar ATR 35 film Mazda 2004-2008 RX-8 rims 18" x 8" FL22 engine coolant Monroe Sensa-Trac shock absorbers Rear Motorcraft XT-M5-QS transmission fluid NGK Iridium IX 6510 LTR7IX-11 spark plugs ~0.28" gap Shell Rotella T6 5W-40 motor oil SSP Primary EGR delete kit Stratified Tuning Guardian Angel ~21.5 psi trigger Visual Garage Shark fin antenna
bigmike is offline   Reply With Quote
The Following User Says Thank You to bigmike For This Useful Post:
leon78 (07-29-2013)
 Old 10-12-2013, 02:18 PM   #8
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
sorry for bumping an old thread. When you say the 3 bar harness runs to the starter. Is it just loomed together with the connector on the starter or is it hardwired?
Performance:
Stratified Tune in progress
 Old 10-14-2013, 10:00 AM   #9
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
its on the same wiring harness within the same wrap, the map sensor is after the starter section
The Following 2 Users Say Thank You to Nitr0EngiE For This Useful Post:
06Speed6 (10-14-2013), Swinger13 (10-14-2013)
 Old 10-14-2013, 09:54 PM   #10
what he said^^
Starter issues plak424 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 02-25-2013 06:40 PM
Has anyone ever replaced their Starter? omgvance MazdaSpeed 6 - Engine, Transmission & Driveline 8 12-17-2012 09:13 AM
remote starter axela2004 2010 MS3 - Car Audio & Electronics 20 02-15-2011 12:03 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 08:40 PM
Page generated in 0.31017 seconds with 27 queries
