 Old 09-19-2019, 12:44 PM   #1
Ced2142's Avatar
Posts: 10   (View Stats)
Ced2142 will become famous soon enough
Default Supertech 4032 pistons pwc
Hey guys,
So im currently in the process of building the engine for my speed6. Currently have brand new 88mm supertech pistons and a block waiting to be bored as soon as i get with pwc sorted. Im wondering what PWC you guys used for 4032 alloy pistons? I called supertech today and was told 0.0027 minimum for my target boost level (20 - 25 psi ... plannin on getting a bnr s4) but the spec sheet indicates 0.0035 with no indication of target boost levels?? Im inclined to believe in the 0.0027 since i read about lots of people running 0.0035 for 2618 alloy pistons. That said, this dosent make sense to me since the sheet indicates a bigger pwc then what was recommended to me on the phone ...
06 MS6; Cpe catted dp; HSK BPV; 3" Catback; K&N intake
Build in progress -> 07 MS6; Supertech 4032 pistons; Manely H beam rods; bnr s4;
Ced2142 is offline   Reply With Quote
Wiseco pistons question pistons squirters clearance JDMCRX MazdaSpeed 3 - Engine, Transmission & Driveline 6 11-27-2013 05:23 PM
Supertech valve into jracer Mazdaspeed3/6 General Discussion 28 09-25-2012 03:20 PM
Page generated in 0.21257 seconds with 20 queries
