 Old 09-27-2009, 12:47 PM   #1
KeysMS3's Avatar
Posts: 341   (View Stats)
KeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the worldKeysMS3 is the leader of the world
Groaned at 8 Times in 3 Posts
Default Turboback is squeaking
Ok this is a little lenghty so bare with me. Got my cpe turboback installed thursday on the way home I hear some vibrating but figure its just my stock exhaust in the box. Go out all night to break it in and notice the vibrating is loud and constant that's also when I first noticed the squeaking. I looked under and figured its hitting the heat shield causing it to virbrate. Take it to the shop they say its the heat shield so they push it back less vibrating. NOW it still does both but squeaks allll the time and I was screwin around and noticed if I push the exhaust a certain way it squeaks. Anybody elese have a problem like this??? I'm gonna try and get under and see if I can put in a bracket or something to keep it from moving.
Anybody have any ideas or solutions?
KeysMS3 is offline   Reply With Quote
 Old 10-16-2009, 11:44 AM   #2
mo4130's Avatar
Posts: 118   (View Stats)
mo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant future
Groaned at 13 Times in 4 Posts
is it the coupling between the two pipes that are sqeaking or the assosiated bolts?
mo4130 is offline   Reply With Quote
The Following User Says NO Thank You to mo4130 For This Un-useful Post:
 Old 10-16-2009, 11:59 AM   #3
atenza_freak's Avatar
Posts: 613   (View Stats)
atenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the world
My buddie had this prob with his 240 the downpipe was rubbing against the firewall. But i would think that a bracket would fix that for ya.
2010 ford focus
andy
atenza_freak is offline   Reply With Quote
 Old 10-16-2009, 12:04 PM   #4
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
dont use a bracket, ut exhaust needs to move around to prevent cracking. keys. its most likely comign from the heat shield. go under ur can and looka round to make sure it has clearance. then if it does uts problty the DP to catback connection. if not that then its definitly the flex joint on the DP. my flex joint squeeks when i manualy move the exhaust
jack up your car and lay under it and move the exhaust around. till you pinpoint it
Last edited by 18psiWhiteMS3; 10-16-2009 at 12:06 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-16-2009, 12:17 PM   #5
KeysMS3's Avatar
shit if forgot to update this i got it done fixed a couple weeks back 18 i thought it was the heat shield so i told the shop across the street and sure enough it was so the cut it out for me and also i told em to check my last exhaust hanger and they said they way it was it was rubbing on something (cant remember what they said) but i got it fixed lol
 Old 10-16-2009, 12:19 PM   #6
18psiWhiteMS3
Lurkers
Posts: n/a
ok
Cobb Turboback Exhaust xandrake MazdaSpeed 3 - Engine, Transmission & Driveline 72 10-16-2011 09:06 PM
Cobb F&R Sway Bars + AWR F&R End Links = SQUEAKING hnda etr MazdaSpeed 3/6 - Suspension & Brakes 32 10-10-2009 11:13 AM
got the turboXS turboback exhaust and have questions johnsonroda27 MazdaSpeed 3/6 - Turbo Induction 19 07-27-2009 09:23 PM
Page generated in 0.25796 seconds with 22 queries
