 Old 12-25-2019, 01:36 PM   #1
Pipatec's Avatar
Posts: 11   (View Stats)
Pipatec is an unknown quantity at this point
Default AWD ISSUE
Hi,
I got a problem with my MS6 awd system.
About a year ago I pulled it in a corner and i heard a clunk noise. After that almost all the lights came on and the awd shutoff. No 4wd light turn on. Im repairing other issues in order to use the car again. Attached is a pic of the lights that turned on (the airbag was there already)
File Type: jpeg FC496D56-3782-41DF-8F0A-AD2E17FAB4E8.jpeg (212.0 KB, 7 views)
Pipatec is offline   Reply With Quote
 Old 12-25-2019, 01:53 PM   #2
Tres3's Avatar
Posts: 61   (View Stats)
Tres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to behold
Originally Posted by Pipatec View Post
Hi,
ABS sensor. 100%.
_____________
2006 Platinum MS6 GT
zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI
Tres3 is offline   Reply With Quote
The Following User Says Thank You to Tres3 For This Useful Post:
Pipatec (12-25-2019)
 Old 12-25-2019, 01:57 PM   #3
Pipatec's Avatar
I forgot to tell that there is no CEL light regarding that. Also I look under for the 2 plugs and one of them was melted since it made contact with the exhaust. I’ll replace that first.
Originally Posted by Tres3 View Post
ABS sensor. 100%.
I’ll replace the abs sensor too.
Thanks
ABS sensor. 100%.
Should i replace both of them (rear ones)???
Last edited by Pipatec; 12-25-2019 at 01:57 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-25-2019, 02:03 PM   #4
Tres3's Avatar
Thanks
ABS won't make a CEL that a basic scanner or Access Port can read. It's deeper. Mechanic can scan to tell which one. The melted plug would be the place to start.
_____________
 Old 12-25-2019, 05:48 PM   #5
djern's Avatar
Posts: 1,139   (View Stats)
Groans: 27
ECU is not getting a signal from one of the wheel speed sensors, a ABS scanner will be needed, any competent mechanic will have one, replacing the sensors are easy peazy
06 VRM Speed 6 W/Navi
05 Mazda Family Truckster
twitter.com/djern
instagram.com/djern
facebook.com/djern
vvt issue? Zmcg1995 Mazdaspeed3/6 General Discussion 1 02-26-2014 07:23 PM
A/c issue USMCMAzda MazdaSpeed 3/6 - Troubleshoot/Diagnostics 29 06-08-2013 04:56 PM
Possible LSD issue? dwagner88 MazdaSpeed 3 - Engine, Transmission & Driveline 5 05-31-2011 11:48 AM
AEM CAI MAF issue Gerottimo MazdaSpeed 3 - Engine, Transmission & Driveline 3 04-27-2011 04:45 AM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 08:40 PM
Page generated in 0.26501 seconds with 23 queries
