| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2120 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
(Thread Starter) | Neutral : +1 score I just took a really quick look through the data and I think I've found the upper boost limit... I saw the max boost logged at 29.97psi with many more @ 25-29psi+. The good news is the new injector seals hold up to some serious pressures(!) and I'm running the PTP version... I'll update this post with more info and the logs tomorrow... Too bad I didn't get it on the dyno before it blew. It was making some serious power and felt awesome, ...until it blew up! Edit Update! Logs attached. This event was entirely preventable. I found the problem in the map I loaded for these runs. I was working on it while tending to lots of other things at home, had the dogs crawling all over my head and the wife talking to me about her day. I had to put the laptop down and get up to do other things several times while trying to review logs and old maps to make WGDC/Bst Dyn tweaks. I obviously failed at this multi-tasking event and lost track of where I was and made a fatal copy-paste error. I pasted in a VERY aggressive Boost Dyamics table that I had tried out with the K04 a while back. As you will see in the logs and BT table, I'm still off just a bit on the WGDC, but it was "ok" and the car was pulling HARD in logs 1 & 2 until I shifted gears and brought the BD table into serious play for 3 @ 4. IMO, the motor is "almost" bullet-proof, unless the bullet is fired from stupidity! I'm also pretty impressed with the BNR as it capable of moving some serious air. The lesson here children, is that when you're tuning above 20psi, PAY FUCKING ATTENTION to WTF you're doing! Oh well, it was going to happen sooner or later as I'm commited(!) to pushing the DISI, so now I'll go ahead an install the parts I have on hand (light flywheel, clutch, front sway-bar, etc.). I haven't decided how to approach the rebuild yet, but I'm leaning more towards simply replacing the rods and the crank thrust bearing (it took a beating driving home) if everything looks good to stay the course with the OEM parts as much as possible. BTW, I'll be doing all this at Forzda's SPEED Shop... Edit 12 April: Added first photo. Hood off, ready to begin.....
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy Last edited by FORZDA 1; 04-12-2011 at 09:08 AM. Reason: pics |
| The Following 139 Users Say Thank You to FORZDA 1 For This Useful Post: | -cj- (04-05-2011), 03scgt (04-06-2011), 06Speed6 (04-06-2011), 09Speed3Z (04-07-2011), 2010Speed3 (04-07-2011), aaronc7 (04-05-2011), Abilor (05-03-2011), Aetherfury (04-06-2011), Andrew85 (07-14-2011), Aralliius6 (05-04-2011), AtTheDriveIn (04-06-2011), austin102085 (04-08-2011), AZSPEED3 (04-06-2011), Biggs (04-06-2011), BlueStreak (04-12-2011), Boosted Beluga (03-16-2012), Broxer (03-16-2012), Cataphract_40 (04-06-2011), charlesfist (04-06-2011), ChimmyChong (04-06-2011), Chriscote (04-06-2011), Ckmazdaspeed3 (04-05-2011), cld12pk2go (04-06-2011), cpolly69 (04-06-2011), D-Rick21 (05-02-2011), DaleNixon (04-06-2011), Dano (04-08-2011), darkcambria (04-06-2011), Darksun280 (04-29-2011), Dash08 (04-13-2011), Decepticon (04-06-2011), Design (04-06-2011), DingoDave (04-23-2011), djuosnteisn (04-06-2011), Docnox (04-05-2011), dougefresh_ (04-06-2011), efispeed (05-02-2011), Ehdith (04-29-2011), eliminator (07-14-2011), enkiddu (04-07-2011), Erich (04-05-2011), fishin53 (04-07-2011), flapjack (01-18-2018), Fobio (04-05-2011), forcedinduktion (04-06-2011), FreeFlyFreak (04-08-2011), frivolous_rob (04-06-2011), GTISPEED3 (05-04-2011), Hoangy (04-06-2011), Hodgii (04-06-2011), I Love Brownies (04-06-2011), i8urgti (04-06-2011), IshiKage (04-06-2011), JacksonMS30 (04-06-2011), jax ms3gt (04-06-2011), JBR (04-07-2011), jmhinkle (04-25-2011), JohnMS3 (04-06-2011), jracer (04-05-2011), Juyoung (08-12-2013), kgb (06-07-2011), kmac (04-07-2011), kunfu (04-06-2011), labikesrcool (07-01-2011), laxplayermjd (04-06-2011), LuczOr (04-07-2011), M4Nathan (07-22-2011), magicka (04-07-2011), manelscout4life (07-14-2011), Mattsy (05-18-2012), maxed_out_saloon (04-06-2011), Mchart (10-16-2012), mdl3v8 (04-06-2011), Micha (02-24-2014), Monotonous ONE (04-06-2011), MPSdriver (04-06-2011), ms3blackmica (01-02-2013), MS3inDC (04-06-2011), MSMS3 (04-06-2011), mtnrunner (04-06-2011), neotide87 (04-06-2011), Night Wolf (06-07-2011), NJSPEED3 (04-06-2011), Novej (04-06-2011), nycMS3 (04-18-2011), obijack (04-06-2011), paveltol (04-13-2011), PeeJoeRickis (06-15-2011), Poohster (04-06-2011), predapio (04-07-2011), PunjabiPlaya (04-05-2011), Realgib3 (04-06-2011), rfinkle2 (04-06-2011), rigor (05-02-2011), robry (07-31-2011), rodrigo (04-06-2011), Rokusek (08-02-2011), SarcasticOne (01-02-2013), sellers (04-06-2011), SIXual Panda (04-05-2011), SJP0tato (04-06-2011), skeeter149 (04-06-2011), SLOWHATCH (03-18-2012), Speed13 (04-06-2011), speed23 (04-06-2011), Speed3eak (04-08-2011), speedcig (08-13-2013), SpeedNess (04-07-2011), speedo (09-12-2011), spiker98 (04-13-2011), spoolin00 (04-06-2011), Stealth01 (04-06-2011), superskaterxes (04-06-2011), super_pablo_ (04-06-2011), taf0422 (04-06-2011), tddvrrn (04-07-2011), Teethkikr (04-06-2011), the_caruch (04-06-2011), Toddy22587 (04-06-2011), triplejumper18 (04-06-2011), tunersteve (04-13-2011), turd burglar (04-06-2011), vbt101 (04-06-2011), wankular (04-06-2011), wette460 (04-06-2011), wildacex187 (04-06-2011), wolly6973 (04-05-2011), Worbit (03-16-2012), xcoldricex (04-10-2011), xdm88 (04-07-2011), xfeejayx (04-06-2011), xI Leveler Ix (08-12-2013), xtasy (04-07-2011), xxdjfate76xx (04-06-2011), Ziggo (04-06-2011), zpele (07-14-2011), zx2man (04-06-2011), _Toxic_ (04-06-2011) |
| NATOR DIRTBAG ![]() Join Date: Jul 2010 Location: Murrieta Ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15,859
| Not Ranked : 0 score damn bro...
__________________ SAN DIEGO CHAPTER COBB SRI / COBB BPV / COBB AP / SLAMMED 2" / 6K HID DDM / CP-E RMM / DASHHAWK / XXR 518 / RALCO SS SPONSORED BY: STREET UNIT |
![]() Join Date: Apr 2010 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 35,474
Groans: 131
| Not Ranked : 0 score grats! level up!
__________________ Cobb SRI CPE 75 duro RMM AP - tune in progress broke ass college student |
| The Following User Says Thank You to PunjabiPlaya For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() Join Date: Nov 2009 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,225
Groans: 65
| Not Ranked : 0 score Sorry to hear man. That sucks. Time for built motor and BT |
| The Following User Says Thank You to AZSPEED3 For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() Join Date: Jan 2010 Location: Rosemount, MN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 946
Groans: 53
Groaned at 31 Times in 22 Posts
| Not Ranked : 0 score Were you targeting those psi numbers or did you have a hardware failure?
__________________ You know.... Moose stuff |
![]() Join Date: Nov 2010 Location: Lancaster, PA
Rep Power: 1111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,516
Groans: 56
| Not Ranked : 0 score Daaaaaamn. 29 psi?! |
| The Following User Says Thank You to SIXual Panda For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() Join Date: Mar 2010 Location: STL, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,038
Groans: 123
__________________ 2003 Evo VIII BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever. Old: 2009 White MS3. Fully bolted and tuned. Sold |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
| Not Ranked : 0 score sucks! that is some crazy pressure tho'... nice job keeping the motor together. sensitivity ftw!
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to tddvrrn For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 40,628
Groans: 386
![]() Join Date: Dec 2009 Location: used to be NJ, now hamburg germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,615
Groans: 140
Groaned at 116 Times in 64 Posts
| Not Ranked : 0 score evo? sti? 5.0? something else?
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45885 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score Rods bent all to hell and he would still probably kick the crap out of the rest of us on an auto-x course. |
| The Following 29 Users Say Thank You to Erich For This Useful Post: | 06Speed6 (04-06-2011), Andrew85 (07-14-2011), AZSPEED3 (04-06-2011), Broxer (03-16-2012), DaleNixon (04-06-2011), Dano (04-08-2011), Dash08 (04-13-2011), DingoDave (04-23-2011), djuosnteisn (04-06-2011), doubleflusher (04-06-2011), dougefresh_ (04-06-2011), FORZDA 1 (04-06-2011), FreeFlyFreak (04-08-2011), i8urgti (04-06-2011), JacksonMS30 (04-06-2011), Juyoung (08-12-2013), maxed_out_saloon (04-06-2011), MPSdriver (04-06-2011), Night Wolf (06-07-2011), nycMS3 (04-18-2011), predapio (04-07-2011), PunjabiPlaya (04-06-2011), Raider (04-06-2011), sellers (04-06-2011), Speed3eak (04-08-2011), tddvrrn (04-07-2011), Teethkikr (04-06-2011), xdm88 (04-07-2011), zpele (07-14-2011) |
Groans: 370
| The Following 29 Users Say Thank You to Erich For This Useful Post: | 06Speed6 (04-06-2011), aaronc7 (04-05-2011), Andrew85 (07-14-2011), Broxer (03-16-2012), Chriscote (04-06-2011), DaleNixon (04-06-2011), Dano (04-08-2011), Dash08 (04-13-2011), DingoDave (04-23-2011), djuosnteisn (04-06-2011), Docnox (04-05-2011), doubleflusher (04-06-2011), FORZDA 1 (04-06-2011), i8urgti (04-06-2011), jmhinkle (04-06-2011), Juyoung (08-12-2013), maxed_out_saloon (04-06-2011), Night Wolf (06-07-2011), nycMS3 (04-18-2011), predapio (04-07-2011), PunjabiPlaya (04-06-2011), sellers (04-06-2011), spiker98 (04-13-2011), Teethkikr (04-06-2011), triplejumper18 (04-06-2011), turd burglar (04-06-2011), wolly6973 (04-05-2011), xfeejayx (04-06-2011), zpele (07-14-2011) |
![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 493 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 666
| The Following User Says Thank You to Ferdball For This Useful Post: | 06Speed6 (04-06-2011) |
![]() Join Date: Nov 2010 Location: St. Louis missouri
Rep Power: 1310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groans: 134
| Not Ranked : 0 score Are you going to change your signature to "zoom freakin boom"? Seriously though, sorry to see this shit happen! Hope you don't give up on the platform, I pay lots of attention to your post. |
| The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post: | MPSdriver (04-06-2011) |
![]() Join Date: Dec 2008 Location: VA Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 930
| Not Ranked : 0 score Sorry to hear. GL on fixing it. Any plans on a build now?
__________________ 06 Speed 6 GT: True twin scroll T4 PTE Billet 6262, dual MVS, SP 10.6:1 pistons, K1 rods, sleeved block... 08 Speed 3|SOLD |
![]() Join Date: Mar 2009 Location: Phoenix, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 116
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score I am curious on the logs will turn out... thankfully the block is not a big paperweight... yet.
__________________ 2008.5 BlackMica Mods: - Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it. AZ Status! |
| The Following User Says Thank You to rtabagaboy For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() Join Date: Jul 2008 Location: Tucson, AZ
Rep Power: 739 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 517
| Not Ranked : 0 score Guess ill be the other ms6 kicking the shit out of other cars on track for the time being. GLWrebuild
__________________ JDMFresh.com 1990 Mazda Miata NASA Time Trials/Time Attack, Global Time Attack A miata may be gay, but its probably faster than your car around a track. That's pretty gay. |
| The Following User Says Thank You to jroc For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() | | #19 | ![]() |
![]() Join Date: Nov 2010 Location: Murrieta, CA
Rep Power: 1393 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,136
| Not Ranked : 0 score Man that sucks...now build a motor put a BT in it and rip 8th gen a new asshole...again..please
__________________ 2009 CWP Speed3 |
| The Following User Says Thank You to SleeperHatch For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() | | #20 | ![]() |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score At least you caught it before the rods decided that they didnt want to be in the block anymore. Could have been worse.
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
![]() | | #21 | ![]() |
| Not Ranked : 0 score Congrats on being the first person to bend a rod from too much power. Dustin would have probably been the first but he decided to use his car as a wet vac. Man at 30+psi you pegged that 3 bar map! I am curious how high it went before the rods bent. Do you have a upgraded MAF as well? I dont see how you could peg both of those sensors and still have a drivable car. I wonder if it leaned out prior to the rod letting go. On a positive note, we must have some really good rods because most factory forgings dont bend, they break. Also on a positive note, we must have some fairly good pistons as well since it didnt shatter around the wrist pin and let the rod go that way.
| The Following 29 Users Say Thank You to 06Speed6 For This Useful Post: | amoosenamedhank (04-06-2011), AZSPEED3 (04-06-2011), Chriscote (04-06-2011), Ckmazdaspeed3 (04-06-2011), cpolly69 (04-06-2011), DaleNixon (04-06-2011), Dano (04-08-2011), Dash08 (04-13-2011), DingoDave (04-23-2011), djuosnteisn (04-06-2011), Docnox (04-06-2011), FORZDA 1 (04-06-2011), JacksonMS30 (04-06-2011), Juyoung (08-12-2013), laxplayermjd (04-06-2011), MPSdriver (04-06-2011), nycMS3 (04-18-2011), PunjabiPlaya (04-06-2011), sellers (04-06-2011), Speed3eak (04-08-2011), spiker98 (04-13-2011), spoolin00 (04-06-2011), superskaterxes (04-06-2011), super_pablo_ (04-06-2011), Teethkikr (04-06-2011), the_caruch (04-06-2011), xcoldricex (04-10-2011), xfeejayx (04-06-2011), zpele (07-14-2011) |
![]() | | #22 | ![]() |
| Fuck sushi rolls ![]() Join Date: May 2008 Location: Los Angeles
Rep Power: 12764 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,168
Groans: 356
| Not Ranked : 0 score stock bottom end? miles? funny i see this cuz saturday i had a similar issue, i put in the 6 puck and left the mbc at the same turns as before..that would net me 21.5 psi.... except i went for a run and the fucker jumped to 30 and the peak warning beep went crazy....so i clicked the mbc 2 full turns down and the fucker would hold about 28psi wtf!!! car felt insanely fast but i couldnt do that...so i turned it half way down and back to 21-22psi... n e ways, build that shit forzda and take pics
__________________ 2007 Ms3 3071r fully bolted , retired and sold after 110k miles of abuse 2014 Black Track Pack premium , NA 4lyfe ...AED dyno tuned on E85 466.6whp / 406.8 TQ SAE |
| The Following 4 Users Say Thank You to rodrigo For This Useful Post: |
![]() | | #23 | ![]() |
![]() Join Date: Mar 2010 Location: Atlanta GA
Rep Power: 277 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,077
Groans: 137
| Not Ranked : 0 score In light of this tragedy lets all remember that.. Forzda is still the man. http://www.mazdaspeedforum.org/forum/foru...-beyond-67927/ |
| The Following 5 Users Say Thank You to Chriscote For This Useful Post: | Docnox (04-06-2011), dougefresh_ (04-06-2011), FORZDA 1 (04-06-2011), i8urgti (04-06-2011), Juyoung (08-12-2013) |
![]() | | #24 | ![]() |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| Not Ranked : 0 score Hmmm. Kinda scary. Maybe I should back off the 28psi map Dustin has me running.
__________________ |
| The Following 6 Users Say Thank You to jmhinkle For This Useful Post: | Docnox (04-06-2011), dougefresh_ (04-06-2011), FORZDA 1 (04-06-2011), Juyoung (08-12-2013), knarfies (04-10-2012), superskaterxes (04-06-2011) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score Well 28 psi may be safe still, he pegged the map at ~30psi so there is almost no telling how much higher than that it could have gone.
| The Following 4 Users Say Thank You to 06Speed6 For This Useful Post: |
![]() | | #26 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score Subbing for blow up logs. IIRC, bent rods equals classic buckling failure which could still be above the fatigue limit. The other mode of failure then would be broken rods after some number of miles running at 2X.X psi. We can all pray that 30psi isn't above the fatigue limit for the rods so we don't have to worry about ventilated blocks 10k miles after getting everything setup.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() | | #27 | ![]() |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Sorry To hear Bud! Gl with your future plans! |
![]() | | #28 | ![]() |
![]() Join Date: Jan 2009 Location: DC
Rep Power: 228 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 408
| Not Ranked : 0 score I'm still wondering how he got up to 30psi. WG reference line damaged? Incorrect PID tuning? The aftermarket MAP sensor requires some calibration to make it work with the AP, correct?Could something have been up with the calibration? |
![]() | | #29 | ![]() |
![]() Join Date: Jul 2009 Location: South Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,578
| Not Ranked : 0 score He has 5 cars, and at least one is a Miata iirc.
---------------------- Again, sorry buddy. I look forward to the build
__________________ 2012 BMW 535i Alpine White/Beige (30K miles) N55 Dinan Stage 1 w/ Intake. Tech package w/ Bluetooth audio/streaming, SAT Radio, & 12.5G HD, Navi Sys Pro w/ Back-up Cam/sensors & Park Distant Control; Auto-Trunk, TPC, LED lighting interior (doors) and exterior (door handles), & tint. [SIGPIC][/SIGPIC] | ||
| The Following User Says Thank You to dougefresh_ For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() | | #30 | ![]() |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
| Not Ranked : 0 score Sorry this happened! Hope you stick with the platform and build the motor. Good luck with everything! |
| The Following User Says Thank You to JacksonMS30 For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() | | #31 | ![]() |
![]() Join Date: Mar 2010 Location: Colorado Springs, CO, USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,160
Groans: 201
| Not Ranked : 0 score Sorry, dude. That sucks. You rebuilding, or getting something more reliable to mod?
__________________ Stealth01 2006 Mazdaspeed6 GT Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG Read my stories: https://www.smashwords.com/books/view/55318 |
![]() | | #32 | ![]() |
![]() Join Date: Nov 2010 Location: Acworth, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 387
| Not Ranked : 0 score Man your car was bad ass before..... Now it could possibly come back even more bad ass......Forzda 1 and a built, BT, MS6...........what a lethal combination. By the way awesome save when you realized what was going on...... Im sure 99% of speed owners would've lifted (maybe) and been like, "wtf was that, hmmm (shrug) oh well lets try to boost it again"....hahahaha I look forward to hearing what your next plans are......
__________________ 2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex ![]() Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN ![]() ![]() ![]() |
![]() | | #33 | ![]() |
Groans: 53
| Not Ranked : 0 score Where is this cat at... we have questions dammit!
| The Following User Says Thank You to amoosenamedhank For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() | | #34 | ![]() |
Groans: 201
| Not Ranked : 0 score Carillo rods. CP Pistons. Rebuild in time for next year's Forum Wars.
| The Following User Says Thank You to Stealth01 For This Useful Post: | FORZDA 1 (04-06-2011) |
![]() | | #35 | ![]() |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score cool congrats |
![]() | | #36 | ![]() |
| Not Ranked : 0 score I am very interested to see these logs. There is a big difference between running a controlled and tuned 28psi versus an uncontrolled spike to 30+. Spikes are what kill a lot of these motors - can't even call that power really. I am curious what allowed it to spike to those levels. |
![]() | | #37 | ![]() |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Philadelphia, PA
Rep Power: 1381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,652
Groans: 166
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp ![]() |
| The Following 13 Users Say Thank You to Blackspeed For This Useful Post: | 06Speed6 (04-06-2011), AZSPEED3 (04-06-2011), DaleNixon (04-06-2011), Docnox (04-06-2011), ELiTeNeSs (04-06-2011), JS + MS3 (05-04-2011), Juyoung (08-12-2013), MS3inDC (04-06-2011), nycMS3 (04-18-2011), phillyb (04-06-2011), PunjabiPlaya (04-06-2011), spoolin00 (04-06-2011), triplejumper18 (04-06-2011) |
![]() | | #38 | ![]() |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
In for updates. | |
![]() | | #39 | ![]() |
Groans: 201
| Not Ranked : 0 score philly says that to everyone who has a blown motor. He assumes a new, non-mazdaspeed car is on the way, and thus congratulates the owner for getting rid of the failboat for a car that takes mods better. He's still a scumbag, and he'll admit it, but he's being facetious with his remark.
![]() | | #40 | ![]() |
| Not Ranked : 0 score Sorry to hear about the blow. I do not consider this fail. Forzda uses good science, has a vast reservoir of experience and knowledge and encountered something unexpected while taking what he thought were reasonable risks with reasonable assumptions for safety. Something let him down and the data logs will show what went wrong. We usually learn more from things that go wrong than we ever do from being safe and being "right" (whatever that means). What Forzda has been doing with his progressive mods, even when he encounters problems, helps all of us. Taking smart risks and being willing and able to absorb those risks and learn from them is exactly how we make progress. I wonder how many "failures" Thomas Edison or Jonas Salk had before they achieved the successes they are known for today. Hats off to Forzda for his approach. This is not fail. This is learning. It is inspirational. We all benefit from it. (And no, I'm not gonna pony up money for the rebuild, however, lol - Forzda is on his own there).
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 04-06-2011 at 10:23 AM. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/bad-news-forzda-1-blew-up-bent-77027/ | ||||
| HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way) | This thread | Pingback | 04-19-2012 04:56 PM | |
| Forum Mazda Performance Series - Zobacz temat - Czym monitorowac | This thread | Refback | 04-28-2011 05:19 AM | |
| Forum Mazda Performance Series • Zobacz temat - Czym monitorowac | This thread | Refback | 04-19-2011 12:00 AM | |
| BT Gen2 with ecutek tune = bent rods thanks to Visconti Tuning / John@TheSandalShopCT | bwallace04 | Gen2 MS3 General Discussion | 96 | 02-09-2011 04:39 PM |
| Not News: South Korean woman passes driving test. News: On 950th try. | Haltech | Automotive News | 0 | 11-10-2009 09:10 AM |
| FYI: Carrillo Rods vs. Factory Rods | JimmyMac | MazdaSpeed 3 - Engine, Transmission & Driveline | 45 | 02-20-2009 10:07 AM |
| My Thoughts On Bent Rods | LBV | MazdaSpeed 3 - Engine, Transmission & Driveline | 27 | 02-09-2009 08:36 PM |
