| Banned ![]() Join Date: Apr 2013 Location: haverhill ma
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 34 Times in 21 Posts
(Thread Starter) | Not Ranked : 0 score I am getting internals soon but what size is the cobb tip? Whats the biggest tip for the ko4? Same with intake? Would I benefit getting a bigger one like maybe 10 more hp? |
| The Following User Says NO Thank You to cocoleveo7686 For This Un-useful Post: | Agent_Orange (03-01-2014) |
![]() Join Date: Jun 2013 Location: Orange County NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 383
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score Visit Cobb and JBR web sites for the info you seek. Tip/SRI combos run from 2.5"- 4" w/ reducers to K04 and are silicon or metal I just bought a HTP 3" in for sale section. For my K04 set up. w/ bigger intakes you need to MAF CAL
__________________ ![]() 99 JEEP WRANGLER SPORT 4 liter- 5 speed- RCD BILTEIN 4" lift -32X12.5" tires-Xtreme 15"x12" wheels-JET Stage 2 ECU- K&N Intake-TB Spacer -Banks Power Monster Header back exhaust-Hurst short throw shifter-Fender Flares w/ clear corners -brush guard -Fog kit-8500lbs winch -tail light guards-Sound bar 2007 Sunlight GT Crash Smash Boom ZOOM ZOOM = HTP Full Metal 3" // CS SRI FMIC // Cobb AP // Autotechs // CS TP & CBE // Stock Block // Stock Turbo // Ralco RZ Shifter // JBR 88 RMM + 80 PMM + Spherical Knob + SSP + WEIGHT + Bushings // Saiko Michi OCC // Cobb Springs // KYB FRONT & BACK // Tri-point rear links // Redline hood shocks // Gen2 VC // RICE = Rally Armor // 20% Tint All Around // Weather Tech // JDM Goodie Visors // CF Eyelids // Red/Black CF Dash Kit // Bumper Covers // Extra Sub Mod //Stuby Antenna//Red&Blue Interior L.E.D. // 50w 10 L.E.D. Cree Reverse lights ![]() |
| The Following User Says Thank You to spdtrux For This Useful Post: | stanley0910 (02-26-2014) |
(Thread Starter) | Not Ranked : 0 score I contacted cobb but haven't gotten any response. |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score A bigger tip doesnt help much if there is still at bottleneck at the intake. Either get a bigger intake and tip or just leave your setup as is. I bet a bigger tip only would give you like 1 hp...lol |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score I like the larger intake, HTP 3.0" definitely made the engine feel more responsive. Just remember you'll need to scale the MAF sensor to install a larger than stock intake. You didn't list an Access Port? You need that to scale the MAF.
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 |
Yes sorry I do have an accessport already on a stage 1 map. Someone posted the difference between a 3" and. 3.5" Intake that gained 8whp. I think the k&n sri is 2.5" so there definitely has to be a difference. When I put a 3" on my vr6 gti vs a 2.5 the difference was noticeable Last edited by cocoleveo7686; 03-01-2014 at 10:51 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() Join Date: Aug 2008 Location: Birmingham, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score HTP 3.5" Intake System + 51R Battery Tray Combo Kit (MS3) - Hi-Tuned Performance Products There's your sign.
__________________ 2013 CWP Mazdaspeed 3 |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
I ran a 3.5 incher on my car for a few months just for the hell of it. After tuning it i found gains of 5-8hp at about 5k and about 3hp at 6k. They were consistent gains comparing logs on VD but i felt no difference while driving and 40-100mph times were about the same compared to the Cobb SF i was running. So yes, in my experience there are small gains to be had with a bigger intake on the K04. Is worth the money? Not to me. I sold it to a fella going BT as he would be better served by it. | |
I am goin to get fuel pump internals before I go custom map. I personally don't wanna get a tune until all my mods are done. Maybe if I find an intake cheap enough ill get it | |
![]() Join Date: Dec 2012 Location: Portland, OR
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 800
| Not Ranked : 0 score since you have a MS6, the BIGGEST TIP you can run with the OEM battery is a 3". And that will rub just a lil. You can modify your battery tray to prevent this. But there is NO difference power between a 2.5" or 3" TIP. Look at any TIP, it's just a funnel from the small 2" turbo inlet to the larger dia of the MAF. As for a intake on the K04, you can run stock OEM MAF to a 4" MAF. its all about how you tune. I currently run a 3.75 intake on my K04 turbo. ANYTHING larger than the OEM 2.68" MAF will REQUIRED A change in tune. |
Thank you. What if I get the jbr 3.0 intake but for the gt series. Can I use a reducer to the stock k04, will there be enough room? Just incase I decide to go gt series? | |
Also consider just buying a HTP 3" or 2.5" TIP, and run a SRI that best fits your budget or current power goals. Since you don't have internals, a 2.5" TIP would be fine with an OEM size MAF SRI. Then move up to a 3" SRI once you get internals. | |
(Thread Starter) | Not Ranked : 0 score I have a cobb tip and k&n sri right now but I wanted to go full 3". The price on the jbr is pretty good. I would go 3.5 but dont wanna mess with battery tray. I have a d34 optima in there now |
You don't need the tray on the 3.5. Warps the battery box a little but that's it might be different on a 6 though.
__________________ 2013 CWP Mazdaspeed 3 | |
Buy my SRI then.... http://www.mazdaspeedforum.org/forum/foru...filter-165155/ on a MS6, the largest TIP you can run is a 3" | |
| Bigger Turbo on CX-7 | speedcig | CX-7 > Turbo Induction & ECU Tuning | 35 | 12-05-2017 07:48 AM |
| Bigger intake/exhaust or new turbo? | KevMS6 | MazdaSpeed 3/6 - Turbo Induction | 19 | 08-22-2013 11:40 PM |
| Video: Fórmula Truck - The bigger they race, the bigger they crash | Haltech | Automotive News | 0 | 08-02-2010 09:50 AM |
| Bigger is better! | Hectik1 | MazdaSpeed 3/6 - Suspension & Brakes | 13 | 07-01-2010 07:35 PM |
