  • 1 Post By jeopardy98
 Old 04-22-2014, 04:07 PM   #1
C9H13NO3_rush's Avatar
Posts: 6   (View Stats)
C9H13NO3_rush has a spectacular aura aboutC9H13NO3_rush has a spectacular aura aboutC9H13NO3_rush has a spectacular aura about
Default Blown engine...
I need some help... Last Wednesday, 16Apr14, I was headed back to work from lunch break at my house, and as I am coming to a stoplight, I downshift from 6th to 4th going 55mph. No big deal, I've done it a thousand times to slow down and no problems...until then. I had no throttle input, eased into 4th, and slowly let my foot off the clutch. The engine revs (obviously) and once it hits 3200rpm, I heard a pop and a lot of vibration. At first I thought it was the transmission, but as soon as I pressed the clutch, the engine shuts off and nice long trail of oil goes everywhere. I get it to the shop, and turns out, cyl #4 blew a hole in the side (front, above starter) of my block. Now, I can understand throwing a rod under WOT, or shifting into too low of a gear, but on something like that? Its an '06 GT with less than 110k miles.
I should also mention, back in January, I had an accident in the snow. Someone was sliding up the road, sideways, in my lane. Out of instinct, I turn the wheel to avoid a head on collision and narrowly miss my back in from getting smashed. When I corrected, I hit a patch of ice underneath the snow and it slid me into a curb at ~15mph, impacting the front left full on, then the rear left. As a result of that, insurance had to pay for 2 new rims, a new tire, upper and lower control arms, a wheel bearing, and other little things. Ever since then, my car has not been properly fixed and I have been arguing with insurance for 2 months now because they did not fix it correctly the first time. Now this happened. I believe that what happened with my motor is a direct result of that.
If the mechanic cant prove that it was a direct result from the previous accident, then my insurance isnt going to pay for anything. The dealership already quoted me $6800 for a new long block and installation, of which I dont have (not to mention 3/4 of the price I paid for the car). I need help/suggestions/advice and I apologize in advance if there is already another topic like this somewhere else, I just dont have time between dealing with this, work, insurance, and military stuff. Thanks.
C9H13NO3_rush is offline   Reply With Quote
 Old 04-22-2014, 04:17 PM   #2
[R]usty's Avatar
Posts: 2,204   (View Stats)
Damn man sorry to hear that sucks. Do you have any mods on the car?
Also, was it $6800 for just the block or did that include instillation?
2010 Mazdaspeed3 w/tech
 Old 04-22-2014, 04:21 PM   #3
Just the MS cold air intake. And yes, it included installation.
 Old 04-22-2014, 04:25 PM   #4
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
You're pretty much fucked. Either buy a used shortblock or get rid of the car.
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
 Old 04-22-2014, 04:34 PM   #5
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
That sucks.
From what I've read, it seems most block VTA mods on this platform happen at lower rpm/loads while cruising or under light acceleration, not at WOT.
btstarcher (06-06-2014)
 Old 04-22-2014, 04:40 PM   #6
Yes, I know about WOT in 6th at low speeds and the possible outcomes. But not this situation.
 Old 04-22-2014, 04:42 PM   #7
Big Dog's Avatar
Posts: 730   (View Stats)
Groans: 89
Groaned at 9 Times in 9 Posts
I have to agree with what agent orange said. Most of the time it seems to be part throttle. Sucks but it's the nature of the beast. Where are you located?
The Following User Says Thank You to Big Dog For This Useful Post:
 Old 04-22-2014, 04:54 PM   #8
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Sorry man, hope you can get it sorted.
What a lovable bunch we are!!
 Old 04-22-2014, 05:09 PM   #9
The rod was bent earlier in the day. It took a while to fatigue and break this why it went decelerating.
 Old 04-22-2014, 05:23 PM   #10
plak424's Avatar
Posts: 298   (View Stats)
plak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the worldplak424 is the leader of the world
Don't know what you have done, or if you have any intention of rebuilding but if you do check out these guys.
Speed Perf6rmanc3
You might be able to have a block build and then install it for cheaper than the dealership will charge you. Do some research on your options and check out the Speedperf6manc3 section on the forum.
Mods: JBR 3" WP, Cobb AP, JBR SSP, JBR 88d RMM, JBR Rear Sway, JBR Camber Arms, Autotech's, UR DP/TP, CS OCC, DO STG1 soon...
plak424 is offline   Reply With Quote
The Following User Says Thank You to plak424 For This Useful Post:
InkedInspector (04-22-2014)
 Old 04-22-2014, 06:59 PM   #11
Charlotte, NC.
Im weighing my options right now. This is what I believed to have happened: From my previous accident back in Jan., when the front left wheel hit the curb, it sent a shockwave through the axle, through the transmission, into the back of the crank at cyl #4 ; the rod being the weakest [vertical] component in that direct system (if you dont count the minimal endplay distances on the shafts). It must have been very minimal until time finally got the best of it, and it failed. As far fetched as it sounds, its about the only logical conclusion that I can come to because any other way would have catastrophically failed way sooner, if not instantaneous.
 Old 04-23-2014, 08:09 PM   #12
Originally Posted by C9H13NO3_rush View Post
Charlotte, NC.
no
MechEnix (04-23-2014), Roddiy (04-23-2014)
 Old 04-23-2014, 08:18 PM   #13
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
SuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond repute
Maybe it is because your car has 110k. Time for a race engine.
SuckSqueezBangBlow is offline   Reply With Quote
 Old 04-23-2014, 08:22 PM   #14
azarashi's Avatar
Posts: 709   (View Stats)
azarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the worldazarashi is the leader of the world
Sucks man, this is always a fear of mine even though I have very light mods on my car this just scares me more bleh.
Did you have a tune on it at all?
2008 Mazdaspeed 3 GT - Cobb SRI, HKS BOV, Cobb AP V2, Sure RMM, EBC Front Rotors, Hawk HPS, ROCA PMM, Yokohama YK580, SenSen Rear shocks
Planned: Cobb TIP, Autotech HPFP, MattD RMM, Koni Street Shocks/struts
azarashi is offline   Reply With Quote
The Following User Says Thank You to azarashi For This Useful Post:
jtday (04-23-2014)
 Old 05-05-2014, 10:35 AM   #15
Tubescorcher's Avatar
Posts: 52   (View Stats)
Tubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the worldTubescorcher is the leader of the world
#4 went VTA on me at non boost low RPM with under 5k miles on a replaced new long block. I purchased a brand new long block through my buddy's shop for $3150. I got brand new clutch and new oem flywheel for under $1200. $1200 for install labor. I was quoted almost $8k from Mazda for just engine! Long story to just say Shop Around! Choose to go stock oem or for that price do a Full on Build with the best of everything! Or find used LB and gamble with same shit to happen in the future.
http://www.gearheadengines.com
Have remanufactured MZR 16V Turbo engines for about the price of what used LB's are fetching. Never used them so can't comment on their service. They did call me back quick with a quote.
While motor is out replace clutch & Flywheel either OEM or aftermarket. I know it sucks!!! I've been through ZZB twice in two years. My car is completely stock now and I won't bolt anything on or flash till I'm ready for the proper upgrade path. 1st step being HPFP, 2nd AP, third bolt all my mods back, 4th E-Tune! Good Luck and know your not alone in what your about to go through! Hopefully you can convince the insurance company to pay. Not likely as they're really good at getting out of not paying!!! But Good Luck all the same!!!
Tubescorcher is offline   Reply With Quote
 Old 05-05-2014, 10:47 AM   #16
jeopardy98's Avatar
Posts: 1,920   (View Stats)
jeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the worldjeopardy98 is the leader of the world
Charlotte, NC.
You are kidding, right?
taf0422 likes this.
Bone Stock 2012 BM Non-Tech for 2500 miles. (250 whp/265 wtq Moore Auto). Currently: K04/Cobb AP/AT internals/Magnaflow CBE/M2 DP/Cobb SRI/HTP TIP/CS boost tubes/CS recirc hose/TS BPV/SU TMIC/GS EBCS/JBR EGR delete/Coolant bypass/Thermal TB gasket/NGK 6510's/JBR SSP/JBR Knob/JBR 88 RMM/JBR SSB/DDM 35w 5000k HIDs/PAC Gateway iPod integration and Sirius. (301whp/360wtq Moore Auto). Finklefied Hypnotic tune. 14.1@106 Mason Dixon- Driver mod needed.
jeopardy98 is offline   Reply With Quote
 Old 06-06-2014, 12:39 AM   #17
green99's Avatar
Posts: 2   (View Stats)
green99 is an unknown quantity at this point
i feel your pain. my ms3 just had a similar experiance. only going about 20 miles an hour downshifted to second to turn a corner and boom. nice new ventalation for the cylinder to breath through. now i have to make a decision get a built motor or sell car? Just curious what do you think i could get out of my 08 ms3 black on black with leather bose and about 160k miles. only bolt-ons are cai and ap. also my wife hydrolocked the engine last month on a flooded highway, do you think this could have been the cause of this failure almost a month later?
green99 is offline   Reply With Quote
 Old 06-06-2014, 04:37 AM   #18
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
yes
The Following 2 Users Say Thank You to pzr2874 For This Useful Post:
chaser27 (06-06-2014), Easter Bunny (06-06-2014)
 Old 06-06-2014, 06:08 AM   #19
MSMS3's Avatar
Posts: 2,827   (View Stats)
Yes. Hydrolock will do it. Water does not compress. It probably hammered the top of #4 piston and bent a rod. Or maybe put a hairline crack in it at a weak point like just below the pin. But, usually you would feel some vibration in the clutch pedal. Not so for a crack that worked gradually into a stress break. The final break frequently does occur under light load.
When this engine is torn down, pay particular attention to documenting, with photos, the piston, connecting rod and crackshaft. A stress crack or break looks different, because the surface part of the break will be shiny bright, but underneath it will be dull, evidencing that the crack progressed over time.
Some insurance policies cover Hydrolock damage since it is caused by road conditions and not wear to the vehicle.
How did you address the Hydrolock at the time to get the car running again?
 Old 06-06-2014, 06:34 AM   #20
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
Hydrolock would def cause that. Just plastic deformation to fatigue failure, sorry man.
Lesson learned stay away from cai on turbo cars.
If you do decide to go for a built motor I have a brand new built engine from speedperf6manc3 for sale.
1990 Nissan Skyline GTR
1991 White BMW 325ic
 Old 06-06-2014, 06:31 PM   #21
green99's Avatar
msms3 i pulled pugs sucked out all water in cylinders drained any water i could find in the intake and changed the oil. i did feel the vibration in the clutch pedal that you where talking about but i thought maybe that was a bad plug since i did drop one of them while i was clearing the water out. so i ordered new ones put them in and my wife drove her car from houston back the the dallas area. she said it ran better but then the next day this happened. its good to hear the insurance may cover this i didn't think they would.
lakespeed6 would kind of price are you wanting for your build engine?
 Old 06-06-2014, 07:22 PM   #22
JgamB's Avatar
Posts: 2,566   (View Stats)
Originally Posted by Agent_Orange View Post
That sucks.
I'm at WOT a lot, so this reduces my chance of ZZB. Thanks for the inspiration!
Cheapspeed (06-06-2014), HawkeyeGeoff (06-06-2014)
 Old 06-06-2014, 07:46 PM   #23
Groans: 665
I like your style.
JgamB (06-06-2014)
 Old 06-06-2014, 08:21 PM   #24
pzr2874's Avatar
Groans: 146
I still think that's a pile of shit waiting to be proven wrong....
 Old 06-06-2014, 08:33 PM   #25
aviator79's Avatar
Posts: 3,934   (View Stats)
Hard to find a working engine for under $2000. IMO buy a new one for $3-4K if cannot find one for under $2k. Add a few hundred for fluids. $100 for engine lift. $200 for tools if you dont have any. Replace it yourself. Find a deal for a rental for like $10/day if you have to.
If you have no way to buy engine then sell it as is and bend over but likely wont be option as you probably still owe on it.
Sorry for bad luck.
 Old 06-06-2014, 08:40 PM   #26
aviator79's Avatar
I dont think it will ever be figured out. Only thing we will ever know is that OEM rods (can) fail...probably an air bubble that fatigues it over time. My new theory for today, along with resonance vibration making rods explode.
pzr2874 (06-06-2014)
 Old 06-06-2014, 08:42 PM   #27
memin's Avatar
Posts: 994   (View Stats)
aaaaaaaaand where are you op! update your sh#$
 Old 06-06-2014, 08:54 PM   #28
pzr2874's Avatar
Groans: 146
I once thought that too.... but I have no usable mirrors since a LONG time ago.... Monday vs. Friday car... my thought
MS6 Blown Engine jslade11 MazdaSpeed 6 - Engine, Transmission & Driveline 37 08-02-2013 12:37 PM
blown engine... Val MazdaSpeed 3/6 - Troubleshoot/Diagnostics 32 02-03-2012 08:56 AM
Page generated in 0.46842 seconds with 38 queries
