 Old 07-07-2019, 09:21 AM   #1
reisusjesus's Avatar
Posts: 7   (View Stats)
reisusjesus will become famous soon enough
Default Clunk/jerking in neutral
Prior to the issue manifesting the car drove normally.
Clutch, flywheel, and slave cylinder have just been replaced 50 miles ago.
Transmission and PTO have fresh fluid.
When sitting at idle, the car starts to jerk and clunk. I lifted the front end and let it sit in neutral. Parking brake on. When it jerks the wheels move. In spite of not being in gear. When the pedal is depressed the clunking stops. This started after I drove the car with the front wheels not torqued properly and persists after tightening them to spec.
Any ideas?
reisusjesus is offline   Reply With Quote
 Old 07-08-2019, 07:35 AM   #2
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
have you checked your wheel and brake disc for being torn by wheel studs. it usually uneven wear the holes....if the hole is slotted by wear, regardless how hard you will torque them, the wheel would rock and need to be replaced.
i also got a similar noise problem over a year, i let it goes until it vib so much that i removed the transmission to find a destroyed main bearing and a worn out dual mass flywheel.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 09-11-2019, 08:23 AM   #3
The issue doesn't occur when moving forward in gear. Only when in neutral with the clutch engaged.
Jerking under boost Mazda2012 Gen2 MS3 General Discussion 52 06-04-2018 05:51 PM
major jerking brooklyncx7 CX-7 > Issues & Troubleshooting 20 06-23-2016 11:43 AM
Bogging and jerking Jbullard MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-22-2015 02:35 PM
Jerking and stuttering in second Darth_Nuruodo 2010 MS3 - Troubleshoot/Diagnostics 8 05-01-2012 08:15 AM
jerking below turbo DCLXVI MazdaSpeed 3/6 - ECU Computer Tuning 3 08-25-2009 05:30 PM
Page generated in 0.25147 seconds with 21 queries
