  • 1 Post By 06Speed6
  • 1 Post By Raider
 Old 12-23-2011, 07:17 PM   #1
riderice's Avatar
Posts: 4   (View Stats)
riderice is an unknown quantity at this point
Default Clutch Vibration in neutral?
Howdy, first post, not quite a member of the MS6 family yet, but maybe soon...
I went to look at a 2007 MS6 today to buy on a used car lot. Car has 33k miles. CARFAX report is pretty normal looking, lots of scheduled service and whatnot. So I started it up and pushed the clutch in and out a few times in neutral and I was getting a vibration through the pedal. So then I got on here and started researching and found all this junk about bent rods and crap, so now I'm pretty paranoid about buying it. Does this sounds like the broken/bend rod thing? I've never felt this through any other clutch pedal, stopped, in neutral... Thanks for the help!
riderice is offline   Reply With Quote
 Old 12-23-2011, 07:22 PM   #2
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Need some more info. Does the vibration get worse if you rev up the engine? Does it vibrate when engaged (pedal out) or does it start when you depress the pedal a little? My guess is a bad pressure plate or maybe it just needs to be tightened. I am not a mechanic, just basing my response on what happened with my 94 mustang gt.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 12-23-2011, 08:21 PM   #3
riderice's Avatar
I didn't notice it just resting my foot on the pedal, only when the pedal was being depressed, most of the way through the travel. I actually didn't even get to take the car for a drive cuz they were about to close (lame, I know), so that's all I know. When I go back and actually drive it, what should I be looking for in terms of horrific potential issues?
 Old 12-23-2011, 08:26 PM   #4
In the Mazdaspeeds, a vibrating clutch pedal is definitely a red flag. In the cases where people have bent rods, and soon after threw a rod through the block, the first thing they report is a vibrating clutch pedal.
Raider (12-23-2011)
 Old 12-23-2011, 08:27 PM   #5
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Yes it does.
Ask to test drive it for an hour and pound on it when up to operating temps. It might blow but may be not.
rfinkle2 (12-23-2011)
 Old 12-23-2011, 08:54 PM   #6
speed23's Avatar
Posts: 1,480   (View Stats)
Dont buy it...not worth the risk...
The Following 2 Users Say Thank You to speed23 For This Useful Post:
Raider (12-23-2011), rfinkle2 (12-24-2011)
 Old 12-23-2011, 09:02 PM   #7
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
Run while you can, or offer them 5k.
Death-From-A-Mile is offline   Reply With Quote
The Following 2 Users Say Thank You to Death-From-A-Mile For This Useful Post:
 Old 12-23-2011, 09:07 PM   #8
Don't buy. Post up a link and vin here to help the next guy.
If you get a bug in your ass to get the pretty car, take it to an independent mechanic for complete insection. Compression test, timing chain slack test rattle at cold start, pto leaks, signs of heavy modification.
rfinkle2 (12-24-2011), Tomas (12-23-2011)
 Old 12-23-2011, 09:21 PM   #9
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
RUN FOREST, RUN
What a lovable bunch we are!!
adlpb (12-24-2011), rfinkle2 (12-24-2011)
 Old 12-23-2011, 09:28 PM   #10
riderice's Avatar
ugh, well, so much for that then. I was really looking forward to a MS6 - only $14k with 33k miles, coulda been fun... Too good to be true though, haha. I might still take it for a test drive, I'll make sure to bring the salesguy with me so if the engine explodes he won't blame me! Back to my LegacyGT I guess...
 Old 12-23-2011, 09:49 PM   #11
Where is the link to the car?
 Old 12-23-2011, 10:58 PM   #12
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Tell the dealer to fix it, then buy it for 14k.
2006 Mazdaspeed 6
 Old 12-23-2011, 11:00 PM   #13
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
on my speed 3 the upgraded rmm makes it feel like a vibe but the floor shakes a hair so it can trick you if you dont know.
The Following User Says Thank You to skeeter149 For This Useful Post:
 Old 12-23-2011, 11:14 PM   #14
SweetJP's Avatar
Posts: 157   (View Stats)
SweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the worldSweetJP is the leader of the world
Do not buy that car. While its possible there is a motor mount that increases all vibrations, if the clutch is giving out of synch or moreso than the rest of the cockpit, gtfo. Don't think twice. Search zoom zoom boom on here.
COBB AP // JBR SSP // Sure AERO SRI // CPE RMM 75 Duro // O.Z. Racing Wheels // Test Pipe// Autotech Internals // Forge V.1 BPV //
SweetJP is offline   Reply With Quote
 Old 12-23-2011, 11:17 PM   #15
With low miles, gotta know why it's at some ghetto lot, and not on a Mazda showroom. Link please?
 Old 12-23-2011, 11:23 PM   #16
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
car was most likely purchased from auction...that's where most car lots get their inventory.
cesaros is offline   Reply With Quote
 Old 12-23-2011, 11:28 PM   #17
And dealerships tend to keep low mile late models. Junk and high mile cars are auctioned. It's prolly a pile of shit with 20's and crap.
 Old 12-24-2011, 07:19 AM   #18
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
when i was looking around for a ms6 i ran into the same problem. one dealer told me "it has a warranty they will take care of it" bull shit i said. warranty wont cover a pre existing condition, been down that road before. find another one, i finally found a private seller with a unmolested 06 ms6 with 60k on it and its been good. except for the vvt and a leaky transfer case which my aftermarket warranty covered. keep searching or find an ms3, those are simply everywhere.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
 Old 12-24-2011, 08:17 PM   #19
riderice's Avatar
Linky...
 Old 12-24-2011, 09:00 PM   #20
Holy shit! Bumpers don't match, or fit for shit, and hailstorm damage. Easy guess windows got broken, so I would see electrical gremlins too. What a piece of crap!
Carfax shows that piece has traveled. Sorrento, FL. Been in Orlando too, back to Colorado. I'd run fast.
Here is the details so Google can log this vin.
2007 MAZDA MAZDASPEED6 AWD
VIN: JM1GG12L171108140
SEDAN 4 DR
Google the vin! That fucker is salvaged! Carfax clean...my ass!
Mazda Mazdaspeed6 Salvage Cars for Sale | 512297
Last edited by Raider; 12-24-2011 at 09:00 PM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (09-27-2012), MS6FL (12-28-2011), predapio (12-25-2011), xtasy (12-24-2011)
 Old 12-25-2011, 11:16 AM   #21
Speeeeeed
06Speed6's Avatar
Oh fuck no, thats a $8000 max car with a good engine.
2006 Mazdaspeed 6
 Old 12-25-2011, 12:04 PM   #22
predapio's Avatar
Groans: 309
Smells like a future problem for someone. Hopefully no one on here.
Good work Raider
Sticky this thread with DONT BUY THIS CAR.
The Following User Says Thank You to predapio For This Useful Post:
Raider (12-25-2011)
 Old 12-25-2011, 12:42 PM   #23
MSF: we find scammers and expose them. We also find out your test drive is a salvage titled shitbox.
Death-From-A-Mile (01-03-2012), ElectroShock (05-21-2013), MS6FL (12-28-2011), predapio (12-25-2011), rfinkle2 (12-25-2011)
clutch vibration at top of clutch PLEASE HELP livetoskate06 MazdaSpeed 3 - Engine, Transmission & Driveline 84 03-06-2010 06:53 PM
clutch vibration? maybe? Jessed87 MazdaSpeed 3 - Engine, Transmission & Driveline 6 08-14-2009 01:38 PM
Mazdaspeed 6 Clutch Pedal Vibration/Noise Help!!!!!ASAP!!! 2k6speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 24 04-24-2009 09:06 PM
Clutch pedal vibration Overboost3 MazdaSpeed 3 - Engine, Transmission & Driveline 59 04-13-2009 02:48 AM
Mazdaspeed 6 Clutch Pedal Vibration/Noise Help!!!!!ASAP!!! 2k6speed6 MazdaSpeed 3 - Engine, Transmission & Driveline 16 04-08-2009 11:25 AM
Page generated in 0.42429 seconds with 32 queries
