 Old 12-09-2010, 10:07 AM   #1
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
Default Coolant boiling over exhaust in coolant
What would cause the coolant to boiling over into the reservoir. The shop is telling me the middle two cylinders are leaking boost into the coolant system. They did a compression test on the the cylinders. 1 and 4 are 150 nuts on and the 2 and 3 are 120. Any ideas? new head gasket and head bolts.
06 Speed6 GT- Sold
 Old 12-09-2010, 10:49 AM   #2
treyclash's Avatar
Posts: 592   (View Stats)
treyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond repute
Groaned at 321 Times in 98 Posts
head gasket IMO
2010 Mazdaspeed 3 Liquid Silver.
Performance: -K&N SRI. -CP TP. -Forge BPV.
Interior: -DashDaq.
Exterior: -Rally Armor Mud Flaps. - Xenon 35w 6000.
treyclash is offline   Reply With Quote
 Old 12-09-2010, 11:57 AM   #3
kmac's Avatar
Posts: 1,792   (View Stats)
Sure sounds like a head gasket,but it could be anything. Cracked block ,cracked head,warped head, not torqued correctly,defective gasket take your pick. Was the gasket just done? How did this come about?
 Old 12-09-2010, 12:01 PM   #4
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
Sounds like a head gasket to me
 Old 12-09-2010, 12:02 PM   #5
bcmurphy87's Avatar
Well i hydro-locked the motor back in august. I had the entire engine torn down and rebuilt. the head was sent to Dover to be machined polished and assembled. no parts were reused. What are teh odds of getting a bad gasket?
06 Speed6 GT- Sold
 Old 12-09-2010, 12:09 PM   #6
trf5000's Avatar
Posts: 2,290   (View Stats)
I have done quite a few head gaskets/head replacements on cars other than the speed. If you even have a little oil or water on the mating surfaces when you re-install the new gasket, it will fail prematurely and not properly seal.
Possbily when the motor was re-assembled this could have happened. IMO though it sounds like a head gasket.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
 Old 12-09-2010, 02:11 PM   #7
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Were studs or oem bolts used? Something prolly wasnt torqued or retorqued properly.
Edit: rofl @ cracked mzr-disi blocks...
Also get them to check the valves, if that head was surfaced it could have some major timing probs depending on how much material was taken off. There is zero reason to surface our head, and I have yet to hear about a warped disi head.
The compression on 1 and 4 is on the low side.
2006 Mazdaspeed 6
 Old 12-09-2010, 02:41 PM   #8
Noddaford's Avatar
Posts: 198   (View Stats)
Noddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond repute
Groaned at 48 Times in 7 Posts
Yea, keep it clean, Use assembly lube on the studs instead of oil. Have the head checked. Make sure you properly torque it.
'06 MS6 GT
Wild Wonderful, West Virginia
Cobb AP, Magnaflow Catback, Underbody Cat Delete, ETS TMIC, Corksport SRI & TIP, Spyder LED Tail Lights, HKS BPV, Drilled & Slotted Rotors front and rear w/Ferro Carbon pads, 35% Tinted Glass
Noddaford is offline   Reply With Quote
 Old 12-14-2010, 09:22 AM   #9
bcmurphy87's Avatar
Pulling head today, hoping i just have to put on a new head gasket. If i need another head gasket should i get a thicker one from streetunit?
06 Speed6 GT- Sold
 Old 12-14-2010, 04:55 PM   #10
Speeeeeed
06Speed6's Avatar
No on the thicker head gasket.
Yes on retorquing the head studs if they are new or using new oem head bolts.
2006 Mazdaspeed 6
 Old 12-14-2010, 06:34 PM   #11
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
id have the head checked for sure, no reason to loose a gasket unless it wasn't torqued properly, or overheated, other wise id be looking at the head very closely....
at 104000 2 bent rods
tuned by nishan
 Old 12-14-2010, 06:50 PM   #12
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
how's the belt?
super slow?
 Old 12-15-2010, 02:39 PM   #13
bcmurphy87's Avatar
Well it seems it was just the head gasket. Small hole between the compression cambers 2 and 3. it was bleeding exhaust into the coolant system. Cause is believed to be from not burping system completely. head was fine. hope this may help someone in the future.
Coolant was boiling in reservoir. Never overheated idling, Would over heat when load was on the engine as soon as you started coasting the temp would start falling again. No fluid swap between the oil and coolant.
06 Speed6 GT- Sold
Coolant smell cpspeed6 MazdaSpeed 3 - Engine, Transmission & Driveline 4 05-24-2015 04:56 PM
coolant phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 26 03-13-2010 06:24 PM
draining coolant rodrigo MazdaSpeed 3 - How-To's 16 07-27-2009 09:46 PM
Coolant Leak for me Derek88 MazdaSpeed 3 - Engine, Transmission & Driveline 11 08-23-2008 05:33 PM
Page generated in 0.32926 seconds with 28 queries
