![]() Join Date: Feb 2015 Location: Finland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24
(Thread Starter) | Not Ranked : 0 score If anyone has actually installed Darton 300 sleeves for Mazda engine, please help. Darton's product catalogue, see page 47 for information about dry sleeves: https://dartonsleeves.com/pdf/dsCatalogue2018-web.pdf
__________________ My mods: http://www.mazdaspeedforum.org/forum/forum/f511/finland-has-fast-mazdas-too-191514/ Last edited by irissanen; 01-09-2019 at 08:13 AM. |
(Thread Starter) | Not Ranked : 0 score A few photos of the sleeves. They are flanged, as you can see.
__________________ My mods: http://www.mazdaspeedforum.org/forum/forum/f511/finland-has-fast-mazdas-too-191514/ |
| Not Ranked : 0 score I helped Darton prototype sleeves for the MZR-DISI block, my understanding from the limited communication that I got back from them was that the MZR-DISI block is fundamentally different from the MZR block even though they appear virtually identical. The sleeves will work in the MZR-DISI block. However, I believe that, and this is from memory from several years ago, the problem is two fold: 1) MZR-DISI oem sleeves have a wave pattern around the outside and are cast in place in the block. So, once you mill out enough to remove them the block the block is structurally weaker than before and the mill can have difficultly milling the different metals 100% straight. 2) The MZR-DISI sleeves do not seal to the head like the Darton sleeves, so the Darton sleeves have to be 100% flush and straight to the block which is nearly impossible for most machinists to achieve. Personally, I wouldn't have anyone except Darton install them. I also remember some sort of cooling issue where the Darton sleeves didn't cool as well as OEM, but don't quote me on that as it was a long time ago.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Tomas (04-29-2019) |
| to darton or not to darton | saint340 | Mazdaspeed3/6 General Discussion | 11 | 11-16-2012 11:03 PM |
| darton sleeves - ebay | dan7225 | MazdaSpeed 3 - Engine, Transmission & Driveline | 0 | 04-27-2011 05:58 PM |
| Sleeves for MZR | obijack | MazdaSpeed 3/6 - Big Turbo Builds | 17 | 12-09-2010 09:28 PM |
| Where are the longer sleeves and bushings? | Element | Mazdaspeed3/6 General Discussion | 5 | 06-16-2009 12:44 PM |
