![]() | | #121 | ![]() |
| Not Ranked : 0 score
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
![]() | | #122 | ![]() |
| Not Ranked : 0 score Generally speaking the trouble comes in with low load, low RPM, high VVT advance when mashing the gas after the engine is heatsoaked. Trouble is, to decrease spool time and add TQ that is smack dab where you run 35s. The way around it is to downshift your car before mashing on the throttle. RPMs go up and shift you to the right of the table out of the 35s zone. Bottom line, drive your stick like its supposed to be driven and you have no worries unless you totally screw up your VVT table. Tappin
| The Following User Says Thank You to Dano For This Useful Post: | atvfreek (01-13-2013) |
![]() | | #123 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
| Not Ranked : 0 score I never mashed the throttle and I still blew, twice. I gently pressed it down, slowly. What about keeping it around 35 at higher loads and tapering off at low loads?
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
![]() | | #124 | ![]() |
| Not Ranked : 0 score any mash on the go peddle induces a huge pressure spike in the cylinder on an already heated up motor if you don't down shift. not saying that was your problem but generally that's what causes the huge spike in compression thus huge KR thus over time a weak rod. you need that 35 down low to flow through the cylinder it just needs to be very strategically tweaked. here lemee show you my table. The red box indicates the area you want to be careful in for highway cruise situations especially. Lets hope nobody mashes on the gas at 2K rpms in 5th 6th gear which is outside the box. My table is even a bit too aggressive in the bottom left hand corner if you are lazy and don't down shift. Lex has done way more research and infinitely more knowledgeable than I on this so don't take my example as the gospel...it is just my understanding of it and I would consider my table somewhat aggressive for sure. This was my setup for the GT28 so it will likely get modified for the GTX30
![]() | | #125 | ![]() |
| Not Ranked : 0 score That's exactly the same group of cells I had decided to modify! After I blew LOL
![]() | | #126 | ![]() |
| Not Ranked : 0 score meaning they had higher VVT values before??
![]() | | #127 | ![]() |
| Not Ranked : 0 score Those are OTS values right? It looks like what I had before adjusting.
![]() | | #128 | ![]() |
| Not Ranked : 0 score Yeah, those were pre-blow numbers. I lowered them a bit in my next revision.
![]() | | #129 | ![]() |
| Not Ranked : 0 score This thread has inspired me to just run a map with no VVT. That 20ft/lbs isn't worth an engine ![]() Edit: @06Speed6; Wouldn't you get the same result by filling the whole VVT table with 15° of advance?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 01-16-2013 at 01:58 AM. |
![]() | | #130 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think you guys are reading way too much into the VVT table, it alone isnt going to blow an engine regardless of what value is in the cell. 15* across the board is probably too high for the cells at the end of the table. My VVT table differs significantly from oem, it is extremely agressive across all loads and rpms and I ran just fine for thousands of miles. Im fairly certain my engine bent a rod because I was doing some cdfp testing for a company and the pump was acting up and it acted up at the wrong instant. Low rail pressure ftw.
![]() | | #131 | ![]() |
| Not Ranked : 0 score I feel that overly aggressive VVT, especially at lower loads or as boost ramps up with the OEM turbo is what caused a lot of zzb in the gen1 cars on the hwy when the engine is heatsoaked and engine enters boost. Many cars blew this way and had the huge KR stutter just as they got on the gas. This was cured with custom tuning. To support this Mazda has changed this significantly for the gen2 cars and a lot less zzb occurred.
| The Following User Says Thank You to Lex For This Useful Post: | btstarcher (01-16-2013) |
![]() | | #132 | ![]() |
But if you welded the VVT actuator at 15° of advance, you would end up with the same problem, no?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 01-16-2013 at 12:30 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #133 | ![]() |
| Not Ranked : 0 score Here are the OEM values: Gen1 VVT Gen2 VVT
| The Following 8 Users Say Thank You to Lex For This Useful Post: | 06Speed6 (01-16-2013), BlueStreak (01-18-2013), btstarcher (01-16-2013), Dano (01-16-2013), DSIT995 (01-16-2013), sidekick (01-16-2013), silvapain (01-16-2013), SpeedRebirth (02-05-2013) |
![]() | | #134 | ![]() |
Has Mazda ever made any sort of statement about ZZB? Or have they just chosen to ignore it?
| The Following User Says Thank You to sidekick For This Useful Post: | DSIT995 (01-16-2013) |
![]() | | #135 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score There is a fairly big difference in those tables exactly where low load cruising would be... I might give the genpu tables a try to, or at least lower the values in the crushing zone
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
| The Following User Says Thank You to DSIT995 For This Useful Post: | rfinkle2 (01-16-2013) |
![]() | | #136 | ![]() |
| Not Ranked : 0 score My custom tables aren't like the gen1 or gen2 tables - VVT doesn't have to be set right at 0 but the gen1 tables were too aggressive in the lower load regions.
![]() | | #137 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score So are we talking specifically for K04 setups here? Cause I am a huge fan of buckets of VVT. I run 35s throughout the spool range of the turbo. My tuning goal is to get the fattest 350wtq curve possible and that allows me to extend it downwards. I dislike downshifting to second on the track and the the TQ increase from VVT allows me to run less timing so the car can still dig out of the low RPMs while feeding the turbo nice toasty retarded timing exhaust. Zigatapatalka
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following User Says Thank You to Ziggo For This Useful Post: | rfinkle2 (01-16-2013) |
![]() | | #138 | ![]() |
![]() | | #139 | ![]() |
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following 6 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (01-16-2013), btstarcher (01-18-2013), Dano (01-16-2013), Nliiitend1 (01-18-2013), rfinkle2 (01-16-2013), sidekick (01-17-2013) |
![]() | | #140 | ![]() |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | DSIT995 (01-18-2013), Nliiitend1 (01-18-2013) |
![]() | | #141 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score is KR a necessity for ZZB? let me rephrase: if I don't get KR at low rpm high gear acceleration, then I don't need to touch VVT table? |
![]() | | #142 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
It's high cylinder pressure that causes ZZB. It can come from KR, timing advanced past MBT, or simply too much torque down in the lower RPMs.
__________________ | |
| The Following 4 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #143 | ![]() |
| Not Ranked : 0 score My second motor also blew with e50 in the tank, so no KR there either.
| The Following User Says Thank You to btstarcher For This Useful Post: | sidekick (02-05-2013) |
![]() | | #144 | ![]() |
| Not Ranked : 0 score Knock causes pressure spikes in the chamber as the piston is coming up thus resulting in a ton of opposite force applied to the rod. excessive VVT can produce more in-cylinder pressure as well but may not lead to knock but will put additional stress on the rods. it has been discussed here or in the VVT thread like 15 times but low load/low RPM high VVT advance and a lazy driver can put extreme pressure on an already heat soaked motor in highway cruise situations. This can likely lead to a ton of KR and or high cylinder pressure at low RPMs. This lead to quite a few of the early ZZB scenarios. current maps have safer VVT advance settings but you can avoid any issues by downshifting to raise RPMs and get you out of any high VVT/ low load/rpm cells.
![]() | | #145 | ![]() |
I have been running the following with the GTX3071 while aiming for ~400wtq: Code: 4.00 6.00 8.00 10.00 12.00
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | ||
| The Following User Says Thank You to cld12pk2go For This Useful Post: | rfinkle2 (02-05-2013) |
![]() | | #146 | ![]() |
Groans: 136
Code: 5.50 7.50 9.50 12.00 14.25
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #147 | ![]() |
![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() Thanks: 39
| Not Ranked : 0 score Apology for resurrecting this but according to the DISI OEM Specifications post the overlap is negative so there is no overlap at all between EVC and IVO. Am I reading the table wrong? |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/dynamic-compression-ratios-blown-engines-38323/ | ||||
| Versatuner on Gen 2 Experience | This thread | Refback | 04-25-2013 06:29 PM | |
| Problem/Noise/Rattle *Video* ? Mazda MPS Owners Club | This thread | Refback | 01-17-2013 12:27 PM | |
| VersaTuner: ????????, ??????????, ????? ?????? | This thread | Refback | 03-30-2012 06:07 AM | |
| Good reading for the Speed6 guys! | This thread | Refback | 01-13-2012 02:24 PM | |
| AZMazda3.com - Your Arizona Mazda3 Community | This thread | Refback | 04-02-2010 08:19 PM | |
| Good reading for the Speed6 guys! - AZMC - Arizona Mazda Club | This thread | Refback | 04-02-2010 10:29 AM | |
| The uphill battle of the Mazdaspeed - Page 2 - College Park Tuning :: Try and Keep up! | This thread | Refback | 09-30-2009 09:41 AM | |
| My heap - Page 2 - College Park Tuning :: Try and Keep up! | This thread | Refback | 09-23-2009 07:35 PM | |
| albuquerque nm mazda 6 owners - Mazda6 / Atenza | This thread | Refback | 09-22-2009 04:44 PM | |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
| Honda Zest Sports G now more dynamic, special | Haltech | Automotive News | 1 | 05-16-2008 10:21 AM |
