 Old 11-24-2013, 03:08 PM   #1
RogerH's Avatar
Posts: 68   (View Stats)
RogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond reputeRogerH has a reputation beyond repute
Groaned at 3 Times in 1 Post
Default fuel pressure issues
I have a 06 ms6. I'm running autotech internals. I'm also running a 5 gallon mix of e85. My prv went bad last week and I was getting huge drops in pressure under boost. I replaced the prv and the problem went away. Last night under full throttle in 3rd gear I noticed fuel pressure was dipping into the 1300psi range then going back up to 1650+ psi. The dips are happening in the 3-4k rpm range. Is it possible my internals coukd be bad? They have about 20k miles. Also could it be the spill valve? I thought when the spill valve failed you just got in tank pump pressure around 60psi. What about the x ring in the pump? Has anyone had it fail? I've done some searching and I can't figure it out. I'll post a log this evening. Thanks for the help.
Fwiw I checked the new prv and it holds pressure when the car is off. So I'm sure the new prv is good.
Last edited by RogerH; 11-24-2013 at 03:08 PM. Reason: MSF Database - Automerged Doublepost
RogerH is offline   Reply With Quote
 Old 11-24-2013, 03:21 PM   #2
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
Take the pump apart, clean the spill valve, clean/relube the internals and change out the x-ring. McMaster-Carr
RogerH (11-24-2013)
 Old 11-24-2013, 04:39 PM   #3
RogerH's Avatar
Ok I'll do that. Any idea on fuel filter life on our cars?
 Old 11-26-2013, 01:59 AM   #4
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Fuel filter is a part of the in tank fuel pump assembly and is designed to last the life of the car.
2006 Mazdaspeed 6
 Old 11-26-2013, 06:03 AM   #5
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Is that the outside o ring?
TEAM LUXURY
 Old 11-26-2013, 10:17 AM   #6
Etipp98's Avatar
Internal one that the piston slides on.
Sid3wayS (11-26-2013)
 Old 11-26-2013, 10:37 AM   #7
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
if someone in the states could get me a pack of those orings, i'd greatly appreciate it and pay for shipping.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 11-26-2013, 12:38 PM   #8
Etipp98's Avatar
I bought a pack of 100 how many you want?
 Old 11-26-2013, 12:46 PM   #9
Tokay444's Avatar
Groans: 793
i would have taken the whole hundred as well at that price, but i'm sure 5 or 6 would suffice.
Demodded.
The Seals
 Old 12-02-2013, 08:05 AM   #10
shnouz's Avatar
Posts: 276   (View Stats)
shnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the world
My 6 was doing this exact thing a few days after installing my KMD internals. Turns out the guy who did the install for me didn't use a torque wrench and over tightened the top cap. The piston would eventually smack the top of the pump causing pressure to drop to around 1200psi. Try a re install w a torque wrench and definitely clean the spill valve.
07 VRM Speed6 Sport
Cobb AP V2//HTP 3.5"//CPE Catless DP// Corksport CBE // KMD v2s//HKS VTA//Denso ITV22
H&R Springs//Koni Yellows//Corksport RSB//Megan Ladder Brace//UltraRacing Trailing Braces//Michael Rey Rear Camber Arms// CS + SURE rear diff mounts // JBR RMM/TMM/PMM//JBR SSP//JBR Shifter Weight//JBR Shifter Bushings//JBR Heavy Knob//Optima Red in the trunk//GT Leather seat swap
Tuned by boostcreeep + 9/3 E85 mix
shnouz is offline   Reply With Quote
 Old 12-05-2013, 02:27 PM   #11
RogerH's Avatar
The cam lobe wore a groove in it where the autotech internals were riding and the keepers fell out and tore the lobe up. Shit happens. This weekend I'm replacing the intake cam and installing a cpe pump. Autotech was awesime. They replaced the internals for me. The above is just a guess. I don't know how it happened, I just pulled the pump and the spring was loose, and the keepers were gone and the cam had a groove worn down the center. A deep groove. I seem to be the only one to have this issue as far as I can tell. Maybe my stock cam was defective. My car has 140k miles, and my internals had about 25k miles on them.
 Old 12-05-2013, 02:45 PM   #12
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Ummm.. where is the cam follower bucket?
Tokay444 (12-05-2013)
 Old 12-05-2013, 02:58 PM   #13
RogerH's Avatar
It came loose some how and got torn up inside the housing. I found it in pieces.
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 08-02-2019 11:09 PM
Need Help: Intermittent fuel pressure issues. speed31982 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 06-30-2012 04:18 PM
Need Help with Fuel Pressure Issues!! CCC Gen2 MS3 General Discussion 60 09-23-2011 05:36 PM
Oil Pressure Gauge... issues.. pls help :: Gusto :: MazdaSpeed 3/6 - ECU Computer Tuning 16 04-18-2011 07:07 PM
No fuel pressure slo4now MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-31-2009 05:17 PM
Page generated in 0.35841 seconds with 26 queries
