 Old 04-01-2010, 02:01 PM   #1
RMCAT's Avatar
Posts: 170   (View Stats)
RMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond reputeRMCAT has a reputation beyond repute
Default Fuel pump internal/HPFP,really necessary?
saw ppl recommending them after adding some mods,I wanna be safe and not to blow the engine,but don't know if fuel pump upgrade is really necessary for me
Currently running Cobb SRI/FMIC/TBE(catted) w/ AP stage 2++ 93,car spikes to 22psi in high gears and sometimes having the famous irregular partial throttle KR up to 7.7 but rarely anything under WOT,only had stutter/fuel cut problem when it's very cold outside,but didn't really have low fuel pressure problem otherwise so far
for sure it's gonna be safer to have the upgrade,but is it really worth to spend $400-$800(shipped to Canada)on fuel pump with my current setup?
||Cobb AP(DJ tuned)||Cobb SRI||Cobb TIP||Cobb FMIC||Cobb SW||KMD v2.2 HPFP||Catted TBE(TurboXS DownPipe+Vibrant DPback)||TurboXS Hybrid BOV||Fortune Auto Coilovers||Powergrid Endlinks||Eibach Camber Kit||CPE RMM||Denso ITV22||STRI DSD 60mm Boost Gauge||5000K HID Fogs||Lamin-x Foglight Tints||Speedy Lite-Fin 18x7.5||General UHP 235/40/18||ADR 17x7(Winter)||Nextmod GV front Lip/spoiler Lip||AutoEXE Carbon Fiber Shifter Knob||Carbon Fiber Ebrake Cover||TWM Bushings||TWM Shift/Ebrake Boots||
RMCAT is offline   Reply With Quote
 Old 04-01-2010, 02:02 PM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
almost everyone will tell you yes.
i'm fully bolted, with an mbc set to around 17-18 psi, without a pump.
so don't take me into consideration.
 Old 04-01-2010, 02:03 PM   #3
pewpew
Sacrilicious's Avatar
Posts: 2,452   (View Stats)
Groaned at 9 Times in 9 Posts
if your logs show that your DI fuel pressure remains ~1600 under WOT through the rev range, then there's no point in upgrading. however, the fuel cut when it's cold out sounds like you are, in fact, losing FP, so you should take some logs and see what's up.
Sacrilicious is offline   Reply With Quote
 Old 04-01-2010, 02:32 PM   #4
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
I had 10k miles on my car, with just intake and dp/rp and had to upgrade my fuel pump. It was fine when temps are above 50 degrees, but cut like a mofo under that.
Fuel pressure was dropping to around 800psi when it was cold.
ChrisK is offline   Reply With Quote
 Old 04-01-2010, 04:53 PM   #5
tbot's Avatar
Posts: 2,821   (View Stats)
Groans: 40
Interesting. I have 1650 - 1750 psi at WOT and can only run 15psi, if I go any higher than that I get massive cut. How the hell are you guys running more boost than that w/o any tuning? I don't know wtf is going on w/ my car haha.
 Old 04-01-2010, 04:55 PM   #6
phillyb's Avatar
Groans: 1,940
all the cars are different.
they behave like little bitches during their period.
unpredictable, irrational, and stupid.
 Old 04-01-2010, 04:55 PM   #7
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
temp/weather plays a big part.
I was living in florida, only days where it went to 40 or lower did I have issues, fully bolted.
What that tells me is even if it's 60 out and I was seeing OK pressure, I was still on the limits of the pump. I would recommend one beyond Intake/tune
 Old 04-01-2010, 05:01 PM   #8
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Default Re: Fuel pump internal/HPFP,really necessary?
+1 on gettin pump... Small investment now can save you big time down the road.
 Old 04-01-2010, 05:04 PM   #9
tbot's Avatar
Groans: 40
Well if these cars act like bitches on periods...and I hate bitches on their periods...then I must solely conclude...I hate these cars...sad revelation
 Old 04-01-2010, 05:08 PM   #10
hnda etr's Avatar
Groans: 90
I'll still fuck a chick on her period... And eat that shit out too... No red bull needed for my red wings here!
 Old 04-01-2010, 05:12 PM   #11
tbot's Avatar
Groans: 40
I never denied any of the above ^^...
 Old 08-09-2013, 09:17 AM   #12
DomSupra's Avatar
Posts: 3   (View Stats)
DomSupra can only hope to improve
Groaned at 3 Times in 1 Post
so my question is if it is better to get the fuel pump such as:
DeatschWerks DW65c Series Fuel Pump w/ Install Kit Multiple Models (inc. 2008-2013 EVO X / 2007-2013 Mazdaspeed3) 9-651-1009 at RallySportDirect.com
or to just get the internals such as:
Autotech Hi-Volume Fuel Pump Upgrade Kit Mazdaspeed 3/6 2006-2013 / Volkswagen 2.0T FSI 2006-2008 10.127.100K at RallySportDirect.com
or do I need both?
DomSupra is offline   Reply With Quote
The Following 3 Users Say NO Thank You to DomSupra For This Un-useful Post:
Agent_Orange (08-09-2013), El_Diablo (08-09-2013), MS3G35 (08-09-2013)
 Old 08-09-2013, 09:19 AM   #13
pwdunmore's Avatar
Posts: 368   (View Stats)
You just need the Autotech HPFP not the intank... and next time check the date before you post in an ancient thread.
The forum has a google search, and read your welcome inbox message. The links and stickies give a lot of info.
The Following 4 Users Say Thank You to pwdunmore For This Useful Post:
Agent_Orange (08-09-2013), El_Diablo (08-09-2013), jm211 (08-09-2013), Quigs (08-09-2013)
 Old 08-09-2013, 09:22 AM   #14
DomSupra's Avatar
ok sweet, thanks
ptp internal pump or KMD? Sniper2606 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 36 02-14-2010 10:38 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
fuel pump Speedie6 Mazdaspeed3/6 General Discussion 8 08-17-2009 01:16 AM
MAXFLO Fuel Internal Upgrade Problem... baluums3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 49 04-18-2009 10:50 AM
Page generated in 0.33143 seconds with 28 queries
