![]() Join Date: Nov 2015 Location: Walworth, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Not Ranked : 0 score I've been having this problem for over a year and have not been able to figure it out. I have read through soooooo many threads on clutch engagement and problems similiar to mine, but I don't know which course of action will fix my car. Basically, 80% of the time I shift from 1st to 2nd, and 2nd to 3rd, the engagement is rough, making my passengers head bob back and forth. It feels like the engagement point changes all the time, or like it engages twice, its hard to explain the feeling, its real clunky. Basically no matter what I do, its pretty random whether or not the ride is smooth. At first I just assumed I was shitty at driving the car(I came from a civic, the clutch engagement on this car is way different as is). But after a few months it would still do it, so I tried throwing parts at it. I replaced the rear diff mount with the cpe xflex first, the problem seemed to improve a little but still very persistent. I also replaced the pmm,tmm,and rmm, oem pmm and tmm damond rmm. The rear and passenger mount were shot, so driving again improved but still having the problem. I don't know where to go from here. I want to get the problem fixed but don't want to waste time/money replacing things. As far as I've read possible fixes are: Tranny fluid flush Clutch/flywheel replacement Pedal adjustment (I don't think that is it, I'm comfortable with the high engagement point, but if someone thinks it'll help I'll give it a shot) Transfer case replacement The car really drives great and I love it other than this awful problem the wont go away hahaha. Only other issue it has is its a bit grindy going into 5th unless I take it real careful (which I do every time). The car does have 145k miles on it, and I have no maintenance history on it, so its hard to decide what to do with it. Thanks for reading this -Brandon
__________________ 2006 Titanium Gray Metallic Mazdaspeed 6 GT ~144k Miles AP V3 with Freektune, BNR S2, Autotech Internals, Catless ebay dp, Cobb TIP+SF, HKS BOV, JBR RMM, CPE xFlex Rear Diff Mount, JBR EBCS, Bosch 3 Bar Map Sensor |
| Neutral : +1 score Have you tried bleeding the clutch or checking out the hose to the slave, etc? Sounds like you might just need some new fluid and bleed it
__________________ Max Bolted and Built Stock K04 |
![]() Join Date: Jan 2012 Location: Milwaukee, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 975
| Not Ranked : 0 score Same issue here. Best way to describe it is movement of the engagement point. I change my clutch line to a SS one and bled the system. I noticed a complete resolution to the issue. However, over the past week it began to go back to how it was. There are no noticeable leaks. I'm now suspecting the slave cylinder as I bled it again and it was resolved yet again. Start with just bleeding the slave cylinder and see how it reacts. Then proceed with a new clutch line ($20).
__________________ Black Mica 2006 Speed6 GT | 62,000 Miles Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1 ms6db.com I'm Registered. Are You? |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Let me know it how works out.
(Thread Starter) | Not Ranked : 0 score Just ordered new fluids for the tranny, transfer case, rear diff, and clutch/brakes. Shipment should be in tomorrow, will change all fluids within the next few days. Will let you guys know how it goes.
![]() Join Date: Mar 2012 Location: Waterford, MI - America's High Five
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,451
| Not Ranked : 0 score Another fun cure for this can be the clutch in and out tables; make them the same?
__________________ Silver 2007 Speed3 GT Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power. Titanium Grey Mazdaspeed6 GTX3071, DD |
(Thread Starter) | Not Ranked : 0 score I got a tune from freektune, would they have done that for me? Never have looked at anything for my tune before but I could try hahaha.
| Not Ranked : 0 score Fluid flush of brakes and clutch with motul dot 5.1 did not help me. My issue must be related to the actual clutch components. Guess Ill live with it until clutch needs replacement. |
(Thread Starter) | Not Ranked : 0 score I flushed and replaced the tranny, transfer case, rear diff, and break fluid. It seemed to feel better a little bit, but did not solve the issue. My engine then decided to throw a rod through the block 2 days later...
| Clutch pedal engagement changes every drive | Absolut1l | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 09-17-2015 07:47 PM |
| Clutch Pedal Engagement | radioflyer | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 01-24-2015 01:02 PM |
| Clutch engagement point? | Dat8687 | 2010 MS3 - Engine, Transmission & Driveline | 20 | 12-02-2013 09:03 PM |
| Raising the Engagement Point on my Clutch | riott | MazdaSpeed 3 - Engine, Transmission & Driveline | 30 | 02-15-2011 07:56 AM |
| Raising the Engagement Point on my Clutch | riott | MazdaSpeed 6 - Engine, Transmission & Driveline | 0 | 02-11-2011 06:15 PM |
