![]() Join Date: Apr 2014 Location: Ottawa, Ontario
(Thread Starter) | Not Ranked : 0 score First time on the forum and had a quick question for you. Head gasket went couple days ago and need to get this repair going. (07 speed6). Have a buddy that will do the work. Because I'm in Canada, I don't have access to aftermarket parts quickly so will have to have to hit up the dealer. I read through most posts however just want to ensure I have all the parts I need listed. First, do we need these Mazda SST cam tool / Mazda crank pin sst to do this job? Second the parts: Head gasket (may go some form of kit) crows foot bold x4 head bolt x 10 cam bolt x 1 At the same time, going to do the valve seals. valve seals Did I miss anything? Thanks for your help. |
| Not Ranked : 0 score Are you sure it's the head gasket? How did you come to that diagnosis?
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() |
| The Following 2 Users Say Thank You to sidekick For This Useful Post: | Black Metal (04-12-2014), [R]usty (04-11-2014) |
![]() Join Date: Sep 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,205
That's not a common thing on this car.
__________________ 2010 Mazdaspeed3 w/tech Cobb AP V3 ║ JBR Tru 3" Wide Path ║ JBR Boost Tubes & BPV Hose ║ Cobb XLE BPV ║ CP-E TMIC ║ UR Racepipe ║ Magnaflow CBE ║ AutoTech Internals ║ GrimmSpeed EBCS ║ JBR RSB ║ SPC Camber Arms ║ KW V3 Coilovers ║ JBR IM+TB TIGs & TB Bypass ║ JBR SSP ║ E - Focus RMM ║ StopTech Slotted Rotors and EBC Yellow Stuff Pads ║ Techna-Fit SS Brake Lines | |
| The Following 2 Users Say Thank You to [R]usty For This Useful Post: | Black Metal (04-12-2014), sidekick (04-11-2014) |
(Thread Starter) | Not Ranked : 0 score That's what I hear and read however everything I've see coupled with two other opinions point to it. Was on highway, merging on heavy acceleration. Car started to run rough, engine light started blinking then solid. Temp gage went to the roof. Coolant was everywhere around the bottom area of the engine (think some pressure caused another blow out) saw some gases coming up through the rad when giving it some gas. There is defiantly pressure going into the rad. Light / gray smoke from the pipes when revving it. Had a buddy look at it and say that there pressure coming through the rad However, oil appeared to be clean. Is there anything else this could be? I'm going to do some more testing tomorrow. But I can't think what else it could be. Maybe I'm out to lunch? |
| Not Ranked : 0 score Has the engine been rebuilt before? Sometimes engines aren't put together correctly and they blow the hg. If it hasn't been rebuilt, the oem build is nearly zero fail as far as the hg goes. Could be a cracked head too. If the engine dumped it's coolant and it's blowing air through the radiator then it may be toast. I'd hold off on buying parts until you figure it out because you don't wanna buy all of that and a new engine. Cracked heads are more common than warped heads and neither are very common. If the head is warped it's a paper weight because of the overhead cam design which makes the cam journals warped as well.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | [R]usty (04-11-2014) |
![]() Join Date: Feb 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,098
Groans: 78
| Not Ranked : 0 score Saw this happen on a buddy's MS3. It turned out to be a hole in one of the cylinder walls. Hope it's just the headgasket but I haven't really heard of any problems with those on our platform.
__________________ - 2006 Black Mica MS6 - - GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP - - Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught - - GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete - 12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30 12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20 - 2004 Silver Sunlight Metallic RX-8 - - 6MT - Stock - |
| Not Ranked : 0 score A hole in the cylinder wall would mix coolant into the oil which he said he didn't have. That's why I was tossing around the idea of a head crack.
Groans: 78
| Not Ranked : 0 score That's what I expected also but the oil in the coolant was very minimal. Lots of coolant in the combustion chamber though. Coolant smelled like fuel really bad. Here is that thread HELP PLEASE!!
| The Following User Says Thank You to Black Metal For This Useful Post: | 06Speed6 (04-12-2014) |
Cracked head you say. I guess really the only thing I could do is open it up and determine what's going on. I'd go do some tests tomorrow. Is there anything else I need to look for to determine if it's cracked? Last edited by ReddoG_Max; 04-12-2014 at 06:30 AM. | |
Groans: 433
| Not Ranked : 0 score If the headgasket is being replaced, you should have the head decked flat. They're almost always warped a little bit even on good engines. As for what 06speed6 said, I've NEVER heard of someone cracking the cylinder head. But you ask anyone who actually MEASURED the head surface flatness after pulling you'll almost ALWAYS find it's warped a little bit. He's wrong when he says if the head surface is warped it's a paperweight.
| The Following User Says Thank You to Chimmike For This Useful Post: | 06Speed6 (04-12-2014) |
As for cracked heads, I have heard of it but it's really damn rare. I've probably heard of less than five. Once the engine is apart it should be pretty obvious whats going on.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
Groans: 433
| Not Ranked : 0 score yeah if the head is cracked, I'd consider yanking the block and having it flattened too, or even if the head is severely warped. Get those mating surfaces as flat as you can.
(Thread Starter) | Not Ranked : 0 score After spending some more time doing diagnostics today, things don't look that good. We have milky oil and when the rad is filled and the car is idling, there is immense exhaust pressure coming out. (As seen in video...Had no idea that that much pressure could be thrown up !....tons of fun). So, the tear down begins Tuesday. Just don't think I have the time or expertise to do this job so got someone to handle it. Said he is going to go with a gasket kit and new head bolts? Anything else I should tell him to change at the same time? Any other parts I should ensure he gets? If he needs to machine the head he will do so. Really hope it's just the head gasket ... Last edited by ReddoG_Max; 04-13-2014 at 10:15 PM. |
| Not Ranked : 0 score Has the car ever been over heated? May as well change the the timing chain and guides while the head is off. Water pump, accessory belt, idler, tensioner, etc. I really hope he thoroughly inspects your head for cracks/warping though. if it is cracked and you just change the headgasket, you might be better off throwing your money in a fireplace.
Thanks! | |
(Thread Starter) | Not Ranked : 0 score Well, bigger problems. So my mechanic took the head out, inspected it and it looked fine. No other issues seen other than a wash in cylinder #3 from the leak. At this point he replaced the head gasket and most other things recommended above. Put it all back together and car is doing the same thing as before !!!! He believes now I need to replace the head ($600 used with 120kms on it). He was going to send the old head to get machined and checked over however it really looked in good shape without any visible cracks. With the amount of pressure being lost, I'd assume there would be some noticeable damage. Maybe we are dealing with a block issue??? While calling around to look for a head, two separate people said that I'd be wasting my money putting a new one on as with in 3-6 months the lower engine won't take the new head. Is this true? Just curious what you guys would recommend at this point. |
| Not Ranked : 0 score I have never heard of that. You need a new mechanic, he obviously doesn't know what he is doing. He pulled the head off, didn't have it professionally checked or cleaned, and threw it back on. Even if that did fix the original problem, it would have created new problems with the head gasket seal. Secondly he had the engine apart, obviously didn't find a (major) problem, then put it back together hoping for the best. Now he wants to start replacing random parts that in his opinion are good working parts? Hell no
| The Following User Says Thank You to 06Speed6 For This Useful Post: | ItsNox (04-21-2014) |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
Sent via Tapafail
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well I believe we have found the problem! |
![]() | | #20 | ![]() |
| Not Ranked : 0 score Lol so he missed that? I hope he's paying for it this time around.
![]() | | #21 | ![]() |
| Not Ranked : 0 score That will do it. In other news, I think your head is ok.
![]() | | #22 | ![]() |
| Not Ranked : 0 score The next question is how the fuck did that happen?
![]() | | #23 | ![]() |
![]() Join Date: Aug 2019
Rep Power: 0 ![]() Thanks: 2
| The Following User Says NO Thank You to Flying For This Un-useful Post: | SSinstaller (08-24-2019) |
| Display Modes | |
| Help: Head gasket repair and tips | speed31982 | MazdaSpeed 3 - Engine, Transmission & Driveline | 11 | 08-01-2011 02:25 AM |
| 5 layer head gasket/head stud combo's. | ptperformance | Mazdaspeed3/6 General Discussion | 9 | 12-01-2008 01:07 AM |
