 Old 09-23-2012, 11:55 AM   #1
tkephart's Avatar
Posts: 18   (View Stats)
tkephart is a splendid one to beholdtkephart is a splendid one to beholdtkephart is a splendid one to beholdtkephart is a splendid one to beholdtkephart is a splendid one to beholdtkephart is a splendid one to beholdtkephart is a splendid one to behold
Default Head Rebuild and Valve clearance issues
So I had to replace all 16 valves, I dont want to talk about why.... Anyways, when I got the head back from the machine shop, my valve clearances are WAY off. I put stock valves and seals in with no other changes. I put my cams on and measured the clearances, figuring I would have to replace a couple of tappets, and found that everything is really loose. Loose as in I cannot buy tappets to cover the gap.
FYI
Stock clearances:
Intake 0.22-0.28mm
Exhaust 0.27-0.33mm
IL = Intake Left, IR= Intake Right, EL= Exhaust Left, ER= Exhaust Right
Here are the clearances as measured before swapping tappets around:
Cylinder 1 2 3 4
IL 0.279 0.33 0.279 0.406
IR 0.33 0.432 0.381 0.356
EL 0.559 0.483 0.61 0.737
ER 0.737 0.686 0.686 0.737
After 84K miles, the tappets do show some wear. On average they have worn 0.05mm, not significant relative to the current clearances. After swapping some tappets, kind of futile given the clearances I have to make up, here are the new clearances:
Cylinder 1 2 3 4
IL 0.356 0.356 0.381 0.457
IR 0.356 0.483 0.686 0.381
EL 0.584 0.533 0.584 0.686
ER 0.635 0.66 0.66 0.711
I have also calculated the tappets that are required given the setup right now
Cylinder 1 2 3 4
IL 0.341 0.424 0.398 0.453
IR 0.372 0.529 0.489 0.443
EL 0.557 0.502 0.575 0.782
ER 0.714 0.66 0.674 0.709
As far as I know, the only tappets that are available are up to .382 (correct me if I am wrong). I actually have tappets that are up to .442.
So after all of this, my questions are:
1. Is the tappet range really only up to 0.382mm?
2. What else can be going on here to cause my clearances to be that far out?
3. How bad will the tapping be if I leave the clearances as they are?
Thanks for the help!
tkephart is offline   Reply With Quote
 Old 09-23-2012, 11:59 AM   #2
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
@Tomas
you can replace the tappets from what I understand, and they go up pretty high. I'll let the guy I mentioned speak more, he knows what he's talking about.
Blue Pu.
 Old 09-23-2012, 01:20 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Measure the valves, they should be 103.4mm long. I have never heard of a head coming back from a machine shop with additional valve clearance unless they swapped seats.
2006 Mazdaspeed 6
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
jracer (09-23-2012), laxplayermjd (09-23-2012)
 Old 09-23-2012, 01:34 PM   #4
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
youll need to swap out tappets
 Old 09-23-2012, 04:04 PM   #5
tkephart's Avatar
@TWOptSL0W
The problem isnt swapping out tappets, it is the fact that there are no tappets available to bring my clearance back into spec. See Cylinder 1 ER, I need a .714 tappet when the largest ones that I could find for sale are .382.
@06Speed6
The only things that I had replaced were the valves and seals.
The Following User Says Thank You to tkephart For This Useful Post:
TWOptSL0W (09-23-2012)
 Old 09-23-2012, 04:30 PM   #6
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Are you sure they used the right valves? The machine shop doing my head couldn't find the right valves through his normal channels, and I had to order them directly from Mazda to get the right ones.
Tapadatass
 Old 09-23-2012, 04:32 PM   #7
There's no way they used stock valves. Do you have the build sheet you can scan and upload?
 Old 09-23-2012, 04:53 PM   #8
tkephart's Avatar
So this might be where I have made my mistake.
Exhaust Valve
Intake Valve
I have ordered stuff from rockauto before and never had a problem. It is certainly possible that these valves dont conform to stock...
06Speed6 (09-23-2012)
 Old 09-23-2012, 05:07 PM   #9
Speeeeeed
06Speed6's Avatar
Do not run that valve, it is not the correct valve. A memeber had the same problem with those valves about a year ago. Order the oem valve.
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
charlesfist (10-05-2012), tkephart (09-23-2012), Tokay444 (09-28-2012)
 Old 09-23-2012, 05:15 PM   #10
tkephart's Avatar
@06Speed6
I was hoping that wasnt the issue but I guess it is good to know. It would have helped to know before buying them and the machining....
Thanks for your help.
 Old 09-23-2012, 05:21 PM   #11
There's a rockauto thread on here somewhere. I don't think there has been one thing ordered from them that actually fits.
 Old 09-28-2012, 03:13 AM   #12
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groans: 148
Groaned at 89 Times in 51 Posts
Because its all for the 6 not the MS6.
DiGi Faggot is offline   Reply With Quote
 Old 09-28-2012, 04:28 AM   #13
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
FYI
Stock clearances:
Intake 0.22-0.28mm
Exhaust 0.27-0.33mm
Cylinder 1 2 3 4
Cylinder 1 2 3 4
Cylinder 1 2 3 4
The tappets are available up too 3.201-3.801
It's a easy fix just buy some tappets.
SPEED6 KILLAH is offline   Reply With Quote
The Following 2 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
jracer (09-28-2012), tkephart (10-05-2012)
 Old 10-05-2012, 11:08 AM   #14
tkephart's Avatar
So I was transposing the decimal when I was looking at tappet sizes.... 3.82 not 3.382....Gotta love transposing numbers as I read them. It only took me reading your post 4 times to realize my mistake. Thanks a lot guys, sorry for the ineptitude.
 Old 10-05-2012, 12:46 PM   #15
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
or they did a valve job and cut the stems down while high on acid lol
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
06Speed6 (10-05-2012), phate (10-05-2012)
rebuild thread or not(How to pull the timing cover) qtrmile beast MazdaSpeed 3 - Engine, Transmission & Driveline 18 02-22-2014 01:27 PM
Has anyone had any clearance issues with ATP gt3076r on stock ex mani???? MurrySpeed Mazdaspeed3/6 General Discussion 5 01-08-2012 06:00 AM
Recall: 1990-1992 Daihatsu Rocky has check valve issues Haltech Automotive News 0 03-20-2010 11:10 AM
Lotus head Mike Kimberley stepping down due to medical issues Haltech Automotive News 0 07-15-2009 04:10 PM
ms3 fmic clearance issues and questions Lvis MazdaSpeed 3/6 - Turbo Induction 8 02-09-2009 01:01 PM
Page generated in 0.35849 seconds with 28 queries
