  • 1 Post By Fstrnyou
 Old 06-15-2010, 11:28 AM   #1
stikiller's Avatar
Posts: 28   (View Stats)
stikiller will become famous soon enough
Default I got P2187
I been reading on this code P2187 for a while I will start checking my lines, turbo inlet, MAF sensor and so on, but if it come to the purge valve does anyone have a picture or the part number? does it have another name (purge valve)?
stikiller is offline   Reply With Quote
 Old 06-15-2010, 01:04 PM   #2
Kdawg207's Avatar
Posts: 2,389   (View Stats)
i had that... purge valve
but dealer did it for me in 20 mins so i dont know too much and i searched for the part # for ya but no luck
but it was a 79 dollar part if yur not under warranty
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
 Old 02-21-2011, 02:12 PM   #3
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
purge valve is a diff code
p0445 or something like that "evap system minor leak"
p0442 "evap system gross leak"
i may have them mismatched but you should throw another code if it is the purge valve
 Old 02-21-2011, 02:27 PM   #4
Alpha's Avatar
Posts: 3,711   (View Stats)
2187 is a lean idle code. Sounds like you have an intake tract leak
 Old 02-24-2011, 06:55 AM   #5
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Consider that the 02 sensors are used to test if the vapors are being purged correctly into the combustion process. If the ECU anticipates a richness from the combusting purged vapors from the EVAP system, but it is not present, it makes sense a lean condition would be detected.
 Old 02-24-2011, 07:23 AM   #6
mdd5148's Avatar
Posts: 303   (View Stats)
mdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the world
I had this for a while and tried everything from fooling with o2 sensors to cleaning MAF to messing with intake.
As with most things the last thing you try works... it ended up being a simple boost leak for me.
2005 Porsche 911 - Pure Sex
Staggered 19" HRE P47's
2007 Mazdaspeed6 GT - #10318 - Sold
AWR Passenger Side Mount | AWR Transmission Mount | CPE RMM | CPE Intake | CPE Inlet | CPE Downpipe | CPE Catback | CPE Fuel Pump | CPE Manifold | TIAL 44mm Wastegate | Grimmspeed EBCS | Custom FMIC | HKS BOV | GT3076 | Cobb AP | Labonte Stage 2 meth | TWM Stage 2 Short Shifter | VEI boost gauge | CPE Tow Plate | LED Tail Lights | LED Mirrors | CX7 Antenna | 18x8.5 Rays Gram Light 57F
2006 Miata Sport - She took it...
Stock For Now...
mdd5148 is offline   Reply With Quote
 Old 02-24-2011, 07:37 AM   #7
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
For me it was as easy as cleaning the MAF sensor. Not even the sensors themselves, but the "temperature bulb" that is visible on the sensor was covered in soot. Cleaned it off with a q-tip and that was my fix. But there are a number of things it could be, good luck.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
The Following User Says Thank You to sallyspeed3 For This Useful Post:
mikeb101.ab (03-22-2017)
 Old 02-24-2011, 09:16 AM   #8
It can also be a dirty MAF, a vac leak, unmetered air leak, or a little less likely, a fueling issue.
 Old 03-16-2011, 09:35 PM   #9
vuth1226's Avatar
Posts: 7   (View Stats)
vuth1226 is an unknown quantity at this point
i had this problem i took it to the dealer and they say its my upstream o2 sensor which is not under warrenty fml
vuth1226 is offline   Reply With Quote
 Old 04-19-2011, 03:56 PM   #10
rockn4's Avatar
Posts: 23   (View Stats)
rockn4 will become famous soon enough
I have this code, but had many others
P2177,P2187,P2097,P2195
Replaced O2 sensor and it fixed all but 2187. Still around.
MAF is clean
intake pipes are tight
purge valve is good
I'm thinking I'm leaking boost? Not quite sure how to test that. Or... it seems I only get this when it rains out, I checked my Mazdaspeed CAI and it was damp (not very wet). Time for a prefilter to see what happens.
rockn4 is offline   Reply With Quote
 Old 05-04-2014, 01:19 PM   #11
JuSteve's Avatar
Posts: 2   (View Stats)
JuSteve is an unknown quantity at this point
I have the same code and I can't narrow it down. Mine also feels like its "choking" on WOT. I guess I'll clean the sensors.
On a side note, here's a great write up on making your own compression tester for leaks. I did it and it at least tests the intake side.
HOW TO FIND A BOOST LEAK - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
JuSteve is offline   Reply With Quote
 Old 03-31-2016, 12:15 PM   #12
seabass157's Avatar
Posts: 5   (View Stats)
seabass157 is an unknown quantity at this point
Read this and checked for any leaks coming from any hoses, found that the hose that goes to the bov/bpv had a big leak. Apparently it's common for these hoses to go bad. So thanks man!
seabass157 is offline   Reply With Quote
 Old 02-07-2017, 11:24 PM   #13
Benafflac's Avatar
Posts: 1   (View Stats)
Benafflac is an unknown quantity at this point
Hi am a new to Mazda forms I have 06 Mazdaspeed 6 it has p2187 can not figure what is causing it I have put new mass air flow sensor in new purge valve all my clamps are tight any other ideas what could be causing it
Benafflac is offline   Reply With Quote
 Old 02-08-2017, 05:53 AM   #14
MikeBavaro's Avatar
Posts: 269   (View Stats)
MikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant futureMikeBavaro has a brilliant future
I know that you wont want to hear it but check again for boost/vacuum leaks. Id recommend getting it smoke tested.
and yes, I know this is a zombie thread
2007 MS3
True Red
HKS BOV-K&N CAI-APV3-CS TMIC
CS Short Throw-Whiteline Bushings-CS Rear Bar
1968 Mustang
Built 289 w/ factory heads
Built C4
Bulit 8" posi
Runs low 14's at 100 flat
MikeBavaro is offline   Reply With Quote
 Old 07-21-2017, 05:40 PM   #15
ProjectMS6's Avatar
Posts: 8   (View Stats)
ProjectMS6 is on a distinguished road
clean maf and o2 also check OCC routing make sure everything is set up correctly had the same issue and thats how i solved it
ProjectMS6 is offline   Reply With Quote
The Following User Says NO Thank You to ProjectMS6 For This Un-useful Post:
Thor Hammer (07-21-2017)
 Old 06-17-2019, 07:17 AM   #16
TonMS6's Avatar
TonMS6 has a little shameless behaviour in the past
Default I got a p2187, p2177 and p0442.
Hello everyone. I am new to this site and I ha e 3 problems with my Mazdaspeed 6. I have a p2187, p2177 and p0442
TonMS6 is offline   Reply With Quote
The Following User Says NO Thank You to TonMS6 For This Un-useful Post:
Db09ms3 (06-17-2019)
 Old 06-17-2019, 08:11 AM   #17
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Good luck.
Jeff23spl likes this.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 06-18-2019, 03:55 PM   #18
MSMS3's Avatar
Posts: 2,827   (View Stats)
It would be best to:
1. Search this site for each of those codes.
2. If you don't get the issue resolved from the results of those searches (just Google "mazdaspeedforums" followed by the code) then post a new thread rather than resurrecting a dead thread that you probably have not read all the way through.
3. Carefully follow the leads in the threads. There should be threads here on each of those three codes. Read and learn.
 Old 06-19-2019, 08:17 AM   #19
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
IT sound like an evap problem, not the easiest ones...you need to check for leaks in general
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-07-2019, 07:13 PM   #20
Choyt's Avatar
Choyt has a little shameless behaviour in the past
Default P2097
Hello everyone,I am new here..if anyone can give advise on a p2097 on 08 mazda 3 2.3 .changed both downstream 02s still pops the 2097 code voltage on both lower o2s are hitting .09 volts any ideas would be great.i myself think the cat is bad but not sure which one.
Choyt is offline   Reply With Quote
The Following User Says NO Thank You to Choyt For This Un-useful Post:
Db09ms3 (07-08-2019)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/i-got-p2187-59125/
p2187 mazdaspeed 6 This thread Refback 03-04-2015 04:52 AM
CEL P2187 Raglem MazdaSpeed 3/6 - Troubleshoot/Diagnostics 56 01-08-2013 09:46 PM
cel P2187 darkm6 MazdaSpeed 6 - Engine, Transmission & Driveline 9 03-11-2010 03:37 PM
CEL P2187 and P0300, Please Help!! 11cruzito11 MazdaSpeed 3 - Engine, Transmission & Driveline 23 08-03-2009 10:17 PM
Running Lean - P2187 8.5MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 29 07-23-2009 04:47 PM
p2187? running to lean? kraz3y MazdaSpeed 3/6 - ECU Computer Tuning 2 06-28-2008 05:13 PM
Page generated in 0.40581 seconds with 38 queries
