Like Tree115Likes
 Old 02-10-2012, 01:39 AM   #1
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
Cool man looks like a good solution.
What are the symptoms going to be when the seals are starting to go bad?
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
 Old 02-10-2012, 05:31 AM   #2
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
They either are OK, or get blown. If they are blown, you'll notice the knocking/chattering sound and jerking under boost.
arcowlin likes this.
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
 Old 02-10-2012, 06:05 AM   #3
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
im gonna order these next week. its cheap enough to gamble. thanks i love oem style fixes.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
The Following User Says Thank You to 671 grains of reason For This Useful Post:
rfinkle2 (02-10-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/injector-seals-solution-version-104815/
AP stage question - Page 4 - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 04-13-2014 02:21 PM
2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums - View Single Post - AP stage question This thread Refback 03-14-2014 10:30 PM
<![CDATA[OzMPSclub - Australia's fastest growing Mazda MPS forum]]> This thread Refback 02-20-2014 04:36 PM
Injector seals, my woes, and apparently Toyota to the rescue? This thread Pingback 02-20-2014 07:32 AM
Thoughts on the Toyota Injector Seals This thread Refback 02-02-2014 03:27 AM
Injecteur Mazdaspeed 3 2007 et mécanicien - Mazda 3 Quebec This thread Refback 05-22-2013 11:22 AM
? View topic - wanted injector seals This thread Refback 01-23-2013 02:23 PM
Mazda MPS Owners Club • View topic - Thoughts on the Toyota Injector Seals This thread Refback 06-13-2012 04:02 PM
AP stage question - Page 4 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 04-29-2012 08:12 AM
Cheap Injector Solution? This thread Refback 03-26-2012 04:58 PM
CPE Safe Seal - Replacing Injectors - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-26-2012 09:55 AM
VersaTune • View topic - Knock issue This thread Refback 02-15-2012 03:39 AM
Possible Injector Seal Alternative? This thread Refback 02-10-2012 10:59 AM
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 03:39 AM
Injector seals solution. Version B paveltol MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 463 11-12-2016 09:30 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 08:34 PM
Injector seals solution - Gen 2 paveltol MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 397 09-19-2012 02:50 PM
Injector seals solution. paveltol MSF KB - Mazdaspeed 3/6 - Fuel 401 09-19-2012 01:49 PM
Page generated in 0.69653 seconds with 24 queries
