 Old 05-05-2011, 01:18 PM   #1
XLT_66's Avatar
Posts: 850   (View Stats)
XLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the world
Default Knock Sensor Removal
Anyone know if you can remove the knock sensor without removing the intake manifold like it says to do in the manual?
I just replaced the injector seals yesterday so I'm not real excited to pull the IM again to get at the knock sensor.
Any input would be great.
I need to swap mine out for another one to see if mine is just bad or if I'm actually getting 5* of KR at WOT with retarded timing, higher octane, and lower boost....and new seals...and new plugs...
2009 CWP MS3 Sport
Built Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno
Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
XLT_66 is offline   Reply With Quote
knock sensor Boosted Beluga MazdaSpeed 3 - Engine, Transmission & Driveline 14 06-05-2017 03:15 AM
First O2 Sensor Removal Albertogti117 MazdaSpeed 3/6 - Turbo Induction 26 07-13-2010 10:06 AM
reading knock sensor on gen2 phillyb 2010 MS3 - Engine, Transmission & Driveline 15 05-15-2010 08:44 AM
Knock sensor location and logging GQ_WhiteMS3 MazdaSpeed 3/6 - ECU Computer Tuning 0 08-23-2009 08:12 PM
setting my knock sensor guage warning light? dixie789456 MazdaSpeed 3 - Engine, Transmission & Driveline 5 08-04-2009 08:25 PM
Page generated in 0.28902 seconds with 27 queries
