 Old 07-01-2019, 02:25 PM   #1
Fermion's Avatar
Posts: 300   (View Stats)
Fermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the worldFermion is the leader of the world
Default Leaky Head
In need of some help msf.
I blew a head gasket roughly 2 years ago and finally am getting back to getting the car up and running (this is a whole other story that I don’t want to get into). I got the head off and took it to a machine shop. He said it was very warped and needed 0.012 machined in order to get it flat. I didn’t expect this much and am sure now I’ll run into clearance issues.
He also said the chambers are seeping quite a bit and that I should probably get the whole thing reworked with the cams. I need a further explanation on this matter, but that was the message I got. What do you think he means by this?
Would it make more sense to just get a new head? Hell, it might make more sense to throw a whole new engine in at this point.
2007 MS3 Red
HKS BPV, AEM CAI, COBB TIP, Eibach Pro Springs, Black RPF1's 17x9 +45, CNT Catless DP, Racing Beat TBE, JBR SSP & Bushings
Fermion is offline   Reply With Quote
 Old 07-01-2019, 04:30 PM   #2
2ndGenM$3's Avatar
Posts: 62   (View Stats)
2ndGenM$3 has a spectacular aura about2ndGenM$3 has a spectacular aura about
Define "new".
Id get a new engine. If your cylinder head is warped then you'll find other problems along the way of the rebuild. Just get a reman, wipe your hands, call it a day.
I've seen long blocks selling reman $2200 no core needed up to $4xxx for built. Found myself in similar situation just the past couple weeks.
Pm me if you feel like ranting. I got a similar story sounds like same time and like you didn't start looking into it until later...
BNRs3 Turbo--SU RMM--CS Intake w/ TIP--CS STB--CS Radiator--TurboSmart DP BOV--ATP TBE-- Autotec HPFP--CP-e TMIC--v2 Cobb AP-- Stratified Tune--JBR Boost tubes--SURE rear Sway Bar-- Tanabe Front Chassis Brace-- GT Spec H brace--
JVC Double DIN Nav-- JBL p660s front/rear-- RF P3 10" Sub--3 Amps 1200w RMS total System powa!--
2ndGenM$3 is offline   Reply With Quote
 Old 07-01-2019, 05:47 PM   #3
Fermion's Avatar
Originally Posted by 2ndGenM$3 View Post
Define "new".
It might be the smart thing to do tbh. However, I feel like all he is talking about is that it needs new valve seals though, which isn’t a huge deal. Honestly I can probably put everything back together in a few days thanks to this forum and hope for the best. If it doesn’t work out, then I’m back to needing a new engine anyway.
Nothing looks too bad other than the cylinders sitting in a little remaining coolant. Bleh.
2007 MS3 Red
 Old 07-02-2019, 08:54 AM   #4
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
These engines aren't prone to head gasket issues unless it is rebuild while keeping warped surface or maybe if someone run into serious overheat.....
i won't bother you with past details but make sure that you clear the reason why your specific engine blew the gasket first....
Yes it need to be milled, it isn,t a scam, aluminium heads almost all warp each time. check the bloc linearity just in case too.
I wouldn't bother much for 0.012'' unless you plan to use a thin gasket. (If you are afraid, you can source a thicker Cometic one...
our valves tend to get very dirty so being at it, i would get it fully re-manufactured with cleaned and grinded valves and seats with new valves and injectors seals
inspect you VVT for bad locking pin and make sure to follow the proper timing install process explained in the thread ''how to vvt'' with required new parts and tools.
I agree with the above that getting a complete rebuild isn't so far from all this just for the head gasket...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 07-02-2019, 09:08 AM   #5
Fermion's Avatar
Pretty much spot on with my thought process. I have new vvt and chain already. Timing tools are obviously purchased. Sounds like this will be worth doing with the existing head as is...I guess.
I had a thread about how I blew it 2 years ago.
Basically really dumb egr delete where I lost a lot more coolant than I originally thought and rushed getting back on the road with what I thought was a full coolant tank, but in fact was just air in the radiator lines that made it appear full on refill. The second it started blowing cold, the head gasket was already toast and the car died. No real catastrophic blowup. It just shut off. I bought a truck and family stuff came up so I’m finally getting back to putting this together to have a 2nd car to drive since the truck is racking up the miles.
2007 MS3 Red
Leaky ass tps. speed3codes Mazdaspeed3/6 General Discussion 11 08-21-2013 06:33 AM
Video: Motor Trend goes head-to-head-to-head in Cadillac ATS 3.6, BMW 335i and Mercedes C350 Sport Haltech Automotive News 1 11-25-2012 04:13 AM
leaky, leaky wette460 MazdaSpeed 3/6 - Turbo Induction 16 09-09-2011 04:12 PM
Is my leaky DP the cause of this? Fatguy729 MazdaSpeed 3 - Engine, Transmission & Driveline 3 07-27-2011 09:02 AM
Leaky stock bpv LiEast MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 10-20-2009 05:25 PM
Page generated in 0.27336 seconds with 22 queries
