 Old 08-22-2008, 01:32 PM   #1
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
Default MS6 Boost Controller - Info Thread
Hey guys. I installed my Defi BF 60mm amber boost gauge in my speed6 and have been watching how the boost comes in and spikes and holds etc.
What I was wondering was a few things that would possibly be a good compilation to have in one thread.
1. What MBC seems to reduce the spike (if there is one) and is preferred for the ms6?
2. What EBC seems to reduce the spike (if there is one) and is preferred for the ms6?
3. What is moderately safe level to hold boost? For example can this motor and fuel and timing setup handled spiking 20+ (if we can't get rid of the spike) and holding 17? Holding 18?
Thanks guys. I am guessing I'll need to accompany these parts with goodies like the bcd, map clamps, etc.
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 08-22-2008, 02:18 PM   #2
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
I've been using a GReddy Profec E-01 for 2 years now with no spikes, no creep, and no problems.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 08-22-2008, 02:48 PM   #3
jhershorin's Avatar
Groans: 31
Nice. What about the amount of boost?
So if you set it to 17psi you hit and hold 17psi?
Cost is also a factor as I don't really want to spend that much. I am leaning towards the AEM Boost Controller - AEM - Tru-Boost Gauge-Type Controller
It is reasonably priced. I just don't want to deal with spiking or creep. If I want to run 17psi I want it to hit 17-17.5 and hold and never go over it. MBC's aren't bad but I have always preferred having overboost protection etc.
-JEWBERT
 Old 08-22-2008, 02:59 PM   #4
ATE BALLER's Avatar
Well, It's not that simple. You have to set a 'set' value, 'gain' value, and 'start' value to get what you're looking for. Like PID input. It takes some getting used to, but I had it down in less than a week. You can set it up with low and hi boost settings and switch back and forth on the fly. And it logs your boost curve on a graph for you.
 Old 08-22-2008, 03:16 PM   #5
jhershorin's Avatar
Groans: 31
Definately. I had a Profec B Spec II on my turbo 3 at one point.
I am just not in the mood to drop 600+ on a boost controller. What are safe boost levels for this car considering rods, timing, and fuel.
-JEWBERT
 Old 08-22-2008, 03:18 PM   #6
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
I have a Hallman Pro RX with no spikes whatsoever and a very fast spool but I am tapping it off of the manifold instead of the compressor.
ElBartoRex is offline   Reply With Quote
 Old 08-22-2008, 03:32 PM   #7
ATE BALLER's Avatar
I usually keep it aroun 17-18psi. Enough to feel, but not enough to pop the turbo.
 Old 08-22-2008, 03:58 PM   #8
jhershorin's Avatar
Groans: 31
I am gonna order the AEM Tru Boost. I get a really good price on it. II will run 17psi. I just want to hit about 280-290whp and 300-310wtq.
-JEWBERT
 Old 08-22-2008, 07:54 PM   #9
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
That's what I'm running. I get some spike but not too bad. I like having the 2 boost settings and being able to switch on the fly.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 08-22-2008, 08:14 PM   #10
jhershorin's Avatar
Groans: 31
Can you elaborate on the setup and settings? Is it just hitting a button to increase and a button to decrease or do you have to set gain, pulse widths, anything?
Also - where are you tapping for all your pressure sources and how did you route it? I am looking to ultimately remove the spiking which some people say they have done - but maybe it's the way its setup for you?
-JEWBERT
 Old 08-23-2008, 11:02 AM   #11
kingpin748's Avatar
Groans: 78
I kind of do everything half assed. I'm running it of the BPV line. I have the solenoid mounted behind the battery box and everything is run behind the heatsheilds to the rubber gromet in behind the glove box.
You set everything up in the menus using 2 buttons which take some gettign use too. Once you have it all set up you just have to push and hold a button for 2 secs to change the PSI. You have two settings, plus you can just turn it off which will run what the wastegate does.
There is a setting that is suppose to control boost spikes but I haven't had a lot of luck with it. I'll be honest, the unit is not perfect but for what you pay I'm pretty happy with it. i would have liked a regular needle gauge, it would have been easier to read.
 Old 08-23-2008, 12:12 PM   #12
jhershorin's Avatar
Groans: 31
I have a boost gauge. This will be hidden. Can you send me your settings so I can start with those and adjust from there? I am going to tap off the manifold so hopefully I won't get spikes.
-JEWBERT
 Old 08-23-2008, 01:25 PM   #13
Colonel Speed's Avatar
Posts: 198   (View Stats)
Colonel Speed is just really niceColonel Speed is just really niceColonel Speed is just really niceColonel Speed is just really niceColonel Speed is just really nice
Well your power goals aren far off, you msy get more. You saw my 6 dyno 275hp and 295 tq ith not so many mods, I didnt even have a DP.
Welcome to the family Princess Leia.
Her current mods include; Exhaust depot FMIC, MM, SU Dual port.
Coming Soon; Secret Stuff.....
Colonel Speed is offline   Reply With Quote
 Old 09-01-2008, 02:11 AM   #14
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
I have the Turbosmart MBC with the ball and spring removed. NO spike at all. Goes to 17 and stays at 17 until it the throttle plate starts to shut and slowly tapers down from there.
Bought it used for $50 shipped
 Old 09-01-2008, 05:44 AM   #15
jhershorin's Avatar
Groans: 31
What's the purpose of removing the ball and spring. Can you send me a link to the one you are talking about so I know which one?
-JEWBERT
 Old 09-01-2008, 06:17 AM   #16
Axle Breaker
jmhinkle's Avatar
Groans: 162
The ball and spring "gate" is supposed to help it spool up faster, but can cause the spike before is settles to the setting you have it at. You remove the gate if you are having bad spiking. I pulled it out because this freaking stock turbo spools so quick anyway you can't possibly slow it down so I preferred having a more controlled setting.
Good reading
http://http://www.turbosmartonline.c...ownload&id=199
Model I have.
http://http://www.streetunit.com/Tur...fg-gbcv-bt.htm
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 05:41 PM
Dual stage boost controller TheDoc MazdaSpeed 3/6 - Turbo Induction 5 08-14-2008 03:04 PM
DVD NAV Screen info Torch MazdaSpeed 3/6 - Car Audio & Electronics 1 07-30-2008 09:11 AM
New Releases - Official Sony DualShock 3 Controller and Nyko Controller (PS3) w/ RUMBLE $44.99 Haltech Hot Deals Section 0 04-04-2008 07:31 PM
Page generated in 0.35412 seconds with 25 queries
