 Old 02-15-2020, 08:15 PM   #1
Jakephog's Avatar
Posts: 7   (View Stats)
Jakephog will become famous soon enough
Default Mazdaspeed 6 trans not engaging reverse
So my speed has developed a new issue. bought the car with broken shifter cables and swapped them out for the heavier midwest control cables and those broke too. narrowed it down to the rmm bring shot causing the motor to move too much while accelerating. mended the shifter linkage but now it wont go into reverse/ ive adjusted and adjusted but it just wont go. is it possible reverse has just shat the bed? can i fix that without pulling the motor and trans? im gonna check the fluid tomorrow and try adjusting the passenger side rod too to see if I can fix it.
fully built and bolted ms6 that's a total basket case.
Jakephog is offline   Reply With Quote
 Old 02-16-2020, 08:50 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Can you engage it manually at the transmission?
New Product Release!! JBR Reverse Lock-Out Gate Guide (07’-09’) MAZDASPEED 3 JBR JAMES BARONE RACING 60 05-26-2017 05:36 AM
Mazdaspeed trans Bmello Mazdaspeed3/6 General Discussion 8 01-08-2017 01:26 PM
Mazdaspeed 6 trans ciezczak1 MazdaSpeed 6 - Engine, Transmission & Driveline 21 06-11-2012 05:49 PM
clunk when engaging reverse SB.MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-04-2011 05:39 PM
Page generated in 0.22903 seconds with 21 queries
