Like Tree8Likes
 Old 02-17-2016, 10:12 AM   #81
MSP611's Avatar
Posts: 2,291   (View Stats)
i would check everything else out see wat it needs on it... and base price off tht knowing pretty much u need an engine already.. check brakes closely... look at suspension play.. do a really thorough inspection
In progress:
 Old 02-17-2016, 10:14 AM   #82
rodger14s's Avatar
Posts: 13   (View Stats)
rodger14s is an unknown quantity at this point
Ive never had to take anything to a shop or dealership for repair, therefore I don't trust them much and think they are out to sell a new car or maybe the mechanic wanted it for himself. The car is entirely stock, other than replacement parts. E.G. Clutch, rear dif, timing etc. it runs stock boost and all. That's what i'm leaning towards, building it myself, only mild. I would know the engine, and would think I could trust it over a replacement from a salvage yard.
rodger14s is offline   Reply With Quote
 Old 02-17-2016, 10:22 AM   #83
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Good luck and let me know if you need any help!!!!
track weight 3220
street weight 3370
 Old 02-17-2016, 10:34 AM   #84
rodger14s's Avatar
Default the most informative "ENGINE REMOVAL HOW TO " ever!!!!
 Old 08-02-2016, 03:27 PM   #85
roburrito's Avatar
Posts: 31   (View Stats)
roburrito will become famous soon enoughroburrito will become famous soon enough
Noob question:
first take the front control arm off ONLY on both sides
Which is the control arm? I have no idea what I'm looking at in the two pictures for that step.
Can someone point out which arm is supposed to be removed from the diagram? I've got everything else disconnected following the workshop manual.
roburrito is offline   Reply With Quote
 Old 08-02-2016, 06:29 PM   #86
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
I have not read the instructions, but when I hear front control arm I think item 6.
-Wetz
QFT
 Old 08-02-2016, 10:35 PM   #87
roburrito's Avatar
Still confused. Every guide or manual I read seems to use different terminology. I've got everything else removed and I'm stuck on this step.
 Old 08-02-2016, 10:38 PM   #88
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
Not that hard. 5 & 6 are the lower control arms. The front control arm is the one closest to the front of the car.
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
qkrthnu2 is offline   Reply With Quote
 Old 08-02-2016, 10:44 PM   #89
roburrito's Avatar
So it is #6 then? So I remove the 23mm nut, knock out the ball joint, and then remove the 17mm nut on the fork? Sorry if I'm being dense, I don't know why this step is confusing me so much.
 Old 08-02-2016, 11:22 PM   #90
qkrthnu2's Avatar
Yep, sounds right. I think I disconnected both, but I didn't really follow directions. You basically just need to be able to freely move the hub to have enough movement to get the axle out.
The others:
 Old 08-03-2016, 07:10 AM   #91
xfeejayx's Avatar
Groans: 78
Are you sure you should be trying an engine swap?
-Wetz
QFT
The Following 4 Users Say Thank You to xfeejayx For This Useful Post:
anavrinIV (08-03-2016), muffhugger (08-03-2016), qtrmile beast (08-04-2016), WetzMS3 (08-03-2016)
 Old 08-03-2016, 08:32 AM   #92
roburrito's Avatar
Nope! But its a project car I got for dirt cheap.
I think I figured out what he was showing in that picture was the back side of the control arm where it connects to the subframe (?) and not the knuckle.
(I'm a mechanical engineer high on technical knowledge low on practical)
 Old 08-03-2016, 09:38 AM   #93
xfeejayx's Avatar
Groans: 78
Might as well learn on a cheap car, I guess.
Not sure why you are stuck on the picture. You have two people telling you what it is on the parts diagram.
-Wetz
QFT
 Old 08-03-2016, 10:00 AM   #94
It's a motor swap. Keep pulling nuts, bolts, and wires off until the motor comes out.
That simple really.
DingoDave (08-04-2016)
 Old 08-03-2016, 10:31 AM   #95
xfeejayx's Avatar
Groans: 78
That simple really.
Don't forget the hoes.
-Wetz
QFT
 Old 08-03-2016, 10:36 AM   #96
Strippers tend to slow the swap down, I'd recommend skipping the hoes. Do disconnect hoses though.
qkrthnu2 and Mandinca like this.
monkey.bones.007 (08-03-2016)
 Old 08-04-2016, 03:38 PM   #97
WAIT WAIT WAIT.....
Drivers side...
Passenger side
Then take the lower bolt out of the fork for the strut. Both the control arm and the lower fork are 17mm...
17mm is on the side with the rubber donut is and the 19mm is on opposite side..
Do this procedure on both side of the car..
No need to take the 23mm bolt at all just pull the two 17 pictured in 1 and 2 pics which is on either side of the car. Then take a 19mm and 17mm to get the bolt that goes through the bottom of the fork out. Once you have these disconnected then you can just pull the control arm out of the subframe....These bolts are really long so it is suggested that you use a really long extension and an air gun to get it off faster. Do you need an air gun no... just suggested.
All was stated in post #3 ....
track weight 3220
street weight 3370
 Old 08-04-2016, 03:48 PM   #98
roburrito's Avatar
:thumbsup: That's what I did. Way easier than popping the ball joint. Engine is out of the car. In the middle of transferring stuff to the new (to me) engine. Thanks for the guide, saved me a lot of time!
The Following User Says Thank You to roburrito For This Useful Post:
qtrmile beast (08-05-2016)
 Old 08-05-2016, 06:45 AM   #99
Mandinca's Avatar
Posts: 1,700   (View Stats)
Mandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the worldMandinca is the leader of the world
Groaned at 7 Times in 5 Posts
Remove PTO from transmission and put new seals in both the transmission and the PTO.
Do it now, save major ass burning headache later.
Also put a new throw out bearing on the clutch fork.
Tadeusz likes this.
Black 2006 MS6 GT with Navigation // Cobb AP V2 // Cobb SRI // M2 Catless DP // Autotech internals // JBR 80 Duro RMM
Mandinca is offline   Reply With Quote
The Following User Says Thank You to Mandinca For This Useful Post:
WetzMS3 (08-05-2016)
 Old 08-05-2016, 08:06 PM   #100
roburrito's Avatar
Any tips for getting the passenger side front drive shaft back in? I got the drivers side in. And I got the driver side onto the splines up to the c clip and i cant push the damn thing past it.
 Old 08-05-2016, 09:15 PM   #101
qkrthnu2's Avatar
I had problems with the drivers side axle. The C clips are just a bitch. Grease it then line it up as straight as possible and slam it in there as hard as you can.
The others:
 Old 08-08-2016, 11:39 AM   #102
Take a rubber mallet and make sure the axle is straight and then beat it in that way. Dont do it with a regular hammer because you can mess up the threads on the axle.
Also make sure the C clip is is the groove inside the axle and has not popped out and blocking the driveshaft from sliding in.
track weight 3220
street weight 3370
 Old 08-11-2016, 02:23 PM   #103
droflow's Avatar
Posts: 114   (View Stats)
droflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond reputedroflow has a reputation beyond repute
like someone said before, most people have seemed to use a crane to remove the engine, but i plan to use a lift. How much easier is it to use a lift to pull the engine? i plan to just pull the engine and trans out all as one, and then install back in all as one. also with the AC lines, someone said just leave the AC lines alone and put the AC pump to the side?
2007 Cosmic Blue Mica Mazdaspeed3 GT
Mazdaspeed CAI, Autotech HPFP, Corksport TMIC, E-cutout, corksport test pipe, stratified tune
In the works:
Built engine- Bored .020 over, Eagle Rods, Wiseco 88mm pistons, Damond PCV plate, corksport injector seals, ported IM
droflow is offline   Reply With Quote
 Old 08-11-2016, 03:19 PM   #104
Unless you just WANT to put new Freon in your car i suggest just moving it to the side...
track weight 3220
street weight 3370
 Old 07-19-2017, 05:33 PM   #105
Austinshedler's Avatar
Posts: 1   (View Stats)
Austinshedler is an unknown quantity at this point
Is it just me or can no one view any photos unless you pay photobucket $400?
Austinshedler is offline   Reply With Quote
 Old 07-21-2017, 02:19 PM   #106
seem like everyone is in that boat.. Have to find a new free host
track weight 3220
street weight 3370
 Old 07-21-2017, 04:00 PM   #107
roburrito's Avatar
You can still view his photo's on photobuckets page, not sure which album they are in:
Charles Pettus's Library | Photobucket
I'd recommend imgur.com as an image host for future threads.
 Old 07-21-2017, 04:36 PM   #108
Look in the "ENGINE PULL" folder
PS you will not be able to zoom in or see the picture individually..
track weight 3220
street weight 3370
 Old 12-19-2017, 01:15 PM   #109
aviator79's Avatar
Posts: 3,934   (View Stats)
just fyi
I never finished my thread either but did save many pics from hear and upload to MSF so not lost due to PB...
How to Remove Engine
EG99 (10-21-2019)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/most-informative-engine-removal-how-ever-62397/
Engine removal guide This thread Pingback 03-14-2012 07:56 PM
Chrysler kicks off production of Pentastar V6 engine, formerly known as "Phoenix" Haltech Automotive News 0 03-19-2010 05:00 PM
Spy Shots: Ford's new "Coyote" 5.0L V8 caught in F150 engine bay Haltech Automotive News 2 09-30-2009 06:19 PM
Page generated in 0.46996 seconds with 31 queries
