![]() Join Date: Jun 2010 Location: Elk River, MN
(Thread Starter) | Not Ranked : 0 score I am new to the forum and I bought the Hypertech tune, so now I am looking to see if the 70 Durometer Rear Motor Mount will be stiff enough to help the weak one? Or is the 88 Durometer a better bet? |
![]() Join Date: Sep 2009 Location: Dracut, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,024
| Not Ranked : 0 score If you have the stock mount now, anything would be better than that POS!!! If you don't mind the vibz I would get the TRZ dogbone, it's what I just picked up. At first the vibz were horrible, but now they are calming down. If you are worried about vibz I would look into the cp-e or streetunit mounts.
__________________ 2010 Mica black ms3 ~ cobb AP ~ cp-e nano/ AEM dryflow ~ TRZ rmm ~ 35% tint all around with 15% strip on top ~ 6k hid ~ nokya hyper yellow fogs ~ cp-e towplate |
| The Following User Says Thank You to bro2 For This Useful Post: | neotide87 (06-25-2010) |
![]() Join Date: Mar 2010 Location: Indy
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 840
| Not Ranked : 0 score I agree with bro2. I have the SU RMM on order for my ride and 60 duro or better and you be ok. what other mods you got?
__________________ 2007 Mazdaspeed 3 Sport SSM Corksport SRI / HPFP Internals / Front Arm Bar // Cp-e RMM 75d // JBR RSB / IM & TB Gaskets / Bypass Valve Hose // Cobb AP / Shifter Weight // SU Shifter Bushings // Sure TIP // Viper 5901 |
(Thread Starter) | Not Ranked : 0 score The TRZ Mount is only for the Mazda3 from what I can find... Just wondering if the AWR Rear Mount will be to stiff with 88 durometer My mods are Cobb SRI/TIP, J-Barone SSP, Hypertech Tuner, Base Bushings, Coil Stretch Mod) (On the way: Street Unit StiffDiff Mount) I just want a reliable car with the hypertech tune, which leads me to all the mounts |
![]() Join Date: Nov 2009 Location: College Station, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score The TRZ mount is for speed3 also... I don't have the poly TRZ mount but from what I read on here vibes aren't bad and it's a solid mount for a solid price
__________________ 08' BM MS3 GT- Cobb SRI + TIP, Magnaflow CBE, CP-E RMM, Forge BPV v2, JBR SSP + bushings |
What durometer do you have 88/70? Thanks, just need to know if the 88 will last longer. | |
![]() Join Date: Jun 2010 Location: West Jordan, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 91
Groaned at 27 Times in 12 Posts
| Not Ranked : 0 score Have the awr. Its worth the money. Sent from my T-Mobile myTouch 3G using Tapatalk
__________________ CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE. |
![]() Join Date: Jun 2010 Location: Burke, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| Not Ranked : 0 score Yikes I would go with a 65 Duro from CPE if your using it as a Daily driver, if your going to race it then go with 75 duro, otherwise have fun with the VIIIIIIBBBBBES!
__________________ 2008.5 Crystal White Pearl Mica MS3 GT 2010 Subaru Forester XT Cobb Catback, Cobb Shift Weight, CP-E Nano w/Green Filter, CP-E Rmm 65 Duro, CP-E Tow Plate, Dash Hawk V2, ETS 3.25 TMIC Silver Black PC, Hypertech Max Energy Sport Reflash, HKS Type 0 Turbo Timer, TWM Short Shifter, TWM Shifter Bushings, TurboSmart Dual Port BOV, Denso iridium ITV22 1 step colder plugs, Mazdaspeed 6 Rims w/ Hankook V12's, JDM Visor Rain Guards, 35% front/20% rear tint, 22pc Clear Bra kit, Home Made Chin Spoiler,Debaged, Side Molding Shaved, 4500k Purple Fogs |
![]() Join Date: Jun 2010 Location: Hartford, CT
Rep Power: 0 ![]() ![]() ![]() Thanks: 57
Groaned at 14 Times in 8 Posts
| Not Ranked : 0 score How is the awr rmm from PG for the ms6 on vibes |
(Thread Starter) | Not Ranked : 0 score Well I can post that the 88 AWR RMM for the MS6 is definitely a HUGE improvement but it does have some vibes. It has settled down since first installed but the vibes are still there. If the 70 durometer really reduces the motor whip flash then do that, but the 88 holds it tight. So it is a give or take.... 88 = feels better driving (swapping gears), worse at idle....
__________________ 2006 MazdaSpeed6 Sport | J-Barone SSP w/ Bushings | Cobb SRI | Cobb TIP | Hypertech Maxx Energy Sport | SU StiffDiff | AWR 88 RMM | AWR 88 Tran. Mount | AWR 88 Pass. Mount | TT Front Mount | GT0804 Stock Sub Swap | Defrost Gauge Pod | Prosport Pro | SURE Front Differential Mount |
| motor mounts | LiEast | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 06-13-2009 06:34 AM |
| cpe motor mounts | marcusdigi | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 04-24-2009 08:57 AM |
