![]() Join Date: Nov 2016 Location: Kansas City, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
Groaned at 9 Times in 6 Posts
![]() Join Date: Jan 2017
Rep Power: 0 ![]() Thanks: 1
No tune needed for a muffler delete. All you'll need is a good set of ear plugs ![]() Sent from my iPhone using Tapatalk | |
| The Following User Says NO Thank You to turbskies For This Un-useful Post: | MSMS3 (03-25-2017) |
I have friends that have that same exact set up, works just fine. It's loud as hell but no, it will not shorten the life of anything. Sent from my iPhone using Tapatalk | |
(Thread Starter) | Not Ranked : 0 score No intro post about yourself? |
| Not Ranked : 0 score How do I make an intro thread? Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score Don't think I got it Sent from my iPhone using Tapatalk |
| Not Ranked : 0 score Thanks man! Sent from my iPhone using Tapatalk |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score It will sound just like a John Deere farm tractor. Four bangers are naturally very nasty sounding engines. They need high flow resos and mufflers (which lose very little power if any on our cars) or they really do sound like farm tractors.
| The Following 2 Users Say Thank You to MSMS3 For This Useful Post: | Mlindy98 (03-25-2017), Thor Hammer (03-27-2017) |
(Thread Starter) | Not Ranked : 0 score Well this will have to do since I'm still in high school and I just dropped a lot on SURE rear diff mounts and a whiteline rsb. Low on cash. |
![]() Join Date: Oct 2016
| Not Ranked : 0 score Lol I actually like the sound of muffler delete, it goes from a quite sedan, to a loud monster, might not sound the best but it does turn heads. |
| Not Ranked : 0 score I must like the sound a John Deere makes. Love my cat-less, 3 in straight pipe. I've always thought the turbo acts enough like a muffler, plus all that other stuff just adds weight, because..... wait for it......racecar
__________________ Max Bolted and Built Stock K04 |
![]() | | #19 | ![]() |
We've all been young and new to performance cars. We often are influenced by people who don't know shit. My main concern is the sheer lack of search effort on the effect of exhaust mods and ignorance of the reputation of SURE with this community. I bought one of their mounts years ago when they first came out before we knew. Never again. Mine, surprisingly, held up. Most don't. Reading the threads here while low on cash will save you grief with your next purchase. Save your mufflers. You might end up putting them back on when the headaches become too much or you tire of getting pulled over. Loud is not fast. FWIW, I'm running a 3" catless dp/rp, but am stock from the rp back. The main restrictions are upstream of the CBE.
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
Groans: 211
And the Sure products have a bad rep. Mostly on motor mounts. For those stick with JBR, AWR, etc. But the Sure rear diff mount is probably ok. Just don't launch the car and expect everything else to hold up. Do you have an upgraded rear motor mount yet? That should be your next purchase. I have a Catted CPE 3" downpipe mated to a CPE 3" Stainless Steel Full Exhaust (Austenite) and its loud! I could'nt imagine not having the mufflers in there. They don't muffle much but straight pipe? I've heard muffler delete and straight pipe MS6's. Sounds raspy and obnoxious IMHO. To each their own.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
![]() | | #22 | ![]() |
I have a corksport rmm. My exhaust is fully stock and I'm not looking to upgrade power that much, for reliability reasons. I just want something louder. | |
![]() | | #23 | ![]() |
![]() Join Date: Jul 2011 Location: Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 218
| Not Ranked : 0 score I just replaced my SURE RMM, with a Damond this past weekend. SURE was on there for 5, close to 6 years if I recall correctly. I was afraid of what I was going to find after reading everything here, but surprisingly, there wasn't a scratch on it.
__________________ 2011 MS3 - Tech Package SURE - SRI / TIP AUTOTECH - HPFP Internals Cobb - AP - FREEKTUNE 50/50 E85 Mix CNT Racing - Catted Downpipe Damond - RMM |
![]() | | #24 | ![]() |
![]() Join Date: Jan 2015 Location: Holden Louisiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 182
| Not Ranked : 0 score My tractor
__________________ 2012 MS3 VRM/w Tech Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom 1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather Plugs-NGK LTR7IX-11(6510) Oil-RP 10/30 Tires-235 40 18 Federal 595 rsrr Brakes-EBC Yellow pads with ATE 200 fluid Check out my wheelwell page here. If your a member hit me up. https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/ |
| The Following User Says Thank You to voodoo2crue For This Useful Post: | turbskies (06-12-2017) |
![]() | | #25 | ![]() |
![]() Join Date: Jul 2017 Location: Kansas for now, Soon to be Idaho
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Just graduated highschool and i only chopped off one muffler cause i wanted more noise. Still isn't loud enough haha. Need catless. |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
| Not Ranked : 0 score I went to one cars and coffee. There is a kansas city facebook group for speed3's and 6's. KCMS if you arn't in it. I just blew my motor a could weeks ago and i think i'm going to build it up. If you ever see a red lowered miata blast by with a tall dude in it... thats me. |
![]() | | #28 | ![]() |
Groans: 438
| Not Ranked : 0 score Here we see the new speed owners in their natural habitat. "my car isn't loud enough" "I want a BOV so people hear my turbo" "I don't need internals because my car runs fine" "I don't need to pay for a tune, because I just graduated hs and vaping is more important" "my engine blew"
| The Following User Says Thank You to g00s3y For This Useful Post: | JSmith (07-09-2017) |
![]() | | #29 | ![]() |
![]() Join Date: Sep 2015 Location: Monongahela PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score Dont do it. I have a 3" catless dp with 3" catback (Corksport), no mufflers and one little resonator. Sum bitch is loud, i have a flowmaster muffler ready to weld in Sent from my LG-H820 using Tapatalk |
![]() | | #30 | ![]() |
I'm gonna go join that Facebook rn. Sent from my XT1254 using Tapatalk Last edited by turbskies; 07-09-2017 at 08:48 AM. Reason: Phone spazzed out. | |
![]() | | #31 | ![]() |
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I went to quest auto in overland Park yesterday and had them check out the exhaust to see how much they would charge for a 3 inch catback. $700, short story don't go there unless you wanna get ripped off. Sent from my XT1254 using Tapatalk |
![]() | | #35 | ![]() |
Sent from my LG-H820 using Tapatalk | |
![]() | | #36 | ![]() |
![]() | | #37 | ![]() |
| Drugs.
![]() | | #38 | ![]() |
![]() | | #39 | ![]() |
![]() | | #40 | ![]() |
| Muffler delete without any aftermarket tune? | turbskies | Mazdaspeed3/6 General Discussion | 3 | 04-27-2017 07:55 AM |
| Muffler delete | IPuOnU | 2010 MS3 - Engine, Transmission & Driveline | 14 | 06-11-2015 07:57 PM |
| Muffler Delete Map | coltonbarrier | 2010 MS3 - ECU Computer Tuning | 13 | 07-23-2014 04:28 PM |
| Res AND Muffler delete? | clowncar | 2010 MS3 - Engine, Transmission & Driveline | 33 | 03-09-2011 08:53 PM |
