 Old 03-13-2010, 06:17 PM   #1
kore2000's Avatar
Posts: 448   (View Stats)
kore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the worldkore2000 is the leader of the world
Groans: 90
Groaned at 69 Times in 21 Posts
Default Negative Crankcase Pressure
Is there any way to achieve negative crankcase pressure at WOT without the use of a pump? I've read that turbo inlet can provide some vac but not really that much. I've also read about using the exhaust to achieve some vac in the crankcase but this is all new to me.
Anyone have any insight on the subject?
kore2000 is offline   Reply With Quote
 Old 03-13-2010, 06:38 PM   #2
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I have done just a bit of research on this.....CrankCase Evacuation System
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 03-15-2010, 03:43 PM   #3
shpankey's Avatar
Posts: 496   (View Stats)
shpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the worldshpankey is the leader of the world
Something like this...
PCV bypass for VW 2.0 FSI Description/DIY (long) - Bob Is The Oil Guy
09 Speed 3 GT
shpankey is offline   Reply With Quote
 Old 03-16-2010, 07:56 AM   #4
boardjnky4's Avatar
Posts: 402   (View Stats)
boardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the worldboardjnky4 is the leader of the world
Groaned at 40 Times in 22 Posts
The exhaust vacuum setup was successfully done by a member here. Something that is worth trying is to simply put a check valve between the IM -> Crankcase vacuum line. It's the simplest thing to try first.
boardjnky4 is offline   Reply With Quote
CrankCase Evacuation System SilverDemon MazdaSpeed 3 - How-To's 402 01-29-2012 03:16 PM
Chevy Volt and 230 mpg: Negative reactions abound, but not from Bob Lutz Haltech Automotive News 0 08-12-2009 01:00 PM
What do my negative ltft's mean? Addikted To Boost MazdaSpeed 3/6 - Turbo Induction 13 06-23-2009 07:57 PM
to roll or more negative camber bova MazdaSpeed 3/6 - Wheels & Tires 15 03-31-2009 10:02 AM
From Cow to Crankcase: Synthetic oil from animal fat Haltech Automotive News 0 12-03-2008 03:50 PM
Page generated in 0.24863 seconds with 23 queries
