(Thread Starter) | Not Ranked : 0 score Universal Aluminum Valve Cover Breather Tank This tank is a Must for High Boost Applications, Valve Cover oil normally leaks out, this tank collects the oil and also return back to the engine. Overall Size: 11" (L) x6.5" (W) x5.5" (H) Full Aluminum Construction 6 x AN10 Fitting 4 x Air filters Fit Standard size Battery Tray ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() Join Date: Nov 2008 Location: Monterrey / San Antonio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51
| Not Ranked : 0 score what the fuck
__________________ yes it's modded. |
![]() Join Date: Jan 2009 Location: Fort Worth, TX
Rep Power: 793 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 771
| Not Ranked : 0 score Frankencan.
__________________ Meet a giant fish. Fuck his brains out. |
![]() Join Date: Dec 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 358
Groaned at 49 Times in 36 Posts
| Not Ranked : 0 score where?? how??
__________________ Mazdaspeed6,2006, 46k miles. COBB AP* Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds. I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW |
![]() Join Date: Jun 2008 Location: New Port Richey, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,984
Groans: 88
| Not Ranked : 0 score 4 air filiters...I got a CC when PG was selling them with 1 filter and got +20 LTFTS.....so ricer math = (fill in here)
__________________ FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute JAM SESSION........US Amps (in Series w/ Stock Amp) using OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back) RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors - Acne Rear Bumper LED Reflectors |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
![]() Join Date: Jan 2010
| Not Ranked : 0 score huge, ugly, in France at mazda club we did a group buy Saikou Michi Stage 2 OCC
__________________ MFT : Mazda French Touch |
| ILL3ST ![]() Join Date: Jun 2008 Location: Ann Arbor, MI
Rep Power: 1317 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,292
| Not Ranked : 0 score It looks like decent construction / design, but i wouldn't want it in my engine bay lol.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
pass the fingers to change a light bulb is then put this galley equipment must remove the engine
__________________ MFT : Mazda French Touch | |
| The Following 3 Users Say Thank You to onyx5 For This Useful Post: |
| Banned ![]() Join Date: Jun 2008 Location: NY Baby!
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 48
| Not Ranked : 0 score wow, that is freaking huge. someone with a civic probably has it, lol |
| Not Ranked : 0 score I dunno but i thanked it cause he quoted me hahahaha.
| Not Ranked : 0 score ok cool bye
| The Following User Says Thank You to onyx5 For This Useful Post: | djuosnteisn (06-28-2010) |
| Not Ranked : 0 score See you around!
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score what the fuck is that guy saying.....and what the fuck......that box would really fuck up your airflow.... |
| catch can... and nothing | etant333 | MazdaSpeed 3 - Engine, Transmission & Driveline | 28 | 09-02-2012 02:12 AM |
| Oil Catch Can Kit | PDXImportRacer | MazdaSpeed 3 - Engine, Transmission & Driveline | 48 | 09-16-2009 09:18 PM |
| oil catch can? | nyghtryder | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 06-07-2009 07:17 PM |
| Oil Catch Can? | bova | Mazdaspeed3/6 General Discussion | 11 | 12-06-2008 09:04 PM |
