Like Tree8Likes
 Old 03-10-2012, 01:26 AM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Neutral  :  +3 score
Exclamation OEM MS6 engine part numbers
I dont know about you guys, but I am tired of looking up the same damn part numbers all the time. If you see any that are missing or are wrong let me know. This is for the MS6 only, alot of these part numbers do not work on the MS3 or CX-7. Everything is correct to the best of my knowledge, but as usual... use at your own risk.
ENGINE TIMING
Cam friction washers x1 for each cam sprocket - L3K912429
Cam sprocket bolt - LF1712428 ** New part # L32112428
Crank pully bolt x1 - LF0111406
Crank pully friction washers x3 - L3K911407 ** New part # L3H511407
Timing chain - L3K912201 ** New part # L3K912201A
Timing chain tensioner - L3K912500A
Timing chain tensioner bolt x2 - LF1712717A
Timing chain guide (tensioner side) - L3K912671
Timing chain guide - L3K912614
Bolts for timing chain guide x2 - 9XG036430L
VVT (new version) - L3K9124X0C ** New part # L3K9124X0C9U
Exhaust cam sprocket - L3K912425A
Crank timing sprocket - L3K911316A
Timing cover, locating pins, and a couple bolts - L3K910500A
Timing cover bolt above the oil seal - 9XF003007L
Timing cover bolt with threaded nut, without the nut - 9YA940604
Timing cover bolt above the oil pump - 9XF003207L
Timing cover bolt to the left of the engine mount - 9XF003287L
Timing cover regular bolts x16 - 9XF002157L
Timing cover engine mount studs x2 - 9YA90A201
Timing cover gasket - R2Y110431
Timing cover sealant (grey) - 852777739
Cam position sensor - L3K918230A
Crank position sensor - L3K918221A
Crank position sensor bolts x2 - 9XG012197L
Knock sensor - L80718921
Knock sensor bolt - 9XF000257L
ENGINE VALVETRAIN
Intake Valves x8 - L3K912111
Exhaust Valves x8 - L3K912121C ** New part # L3K912121D
Intake valve stem seals x8 - L3K910155A
Exhaust valve sten seals x8 - L3K9101F5A
Valve springs x16 - L3K912125
Valve spring retainers x16 - LF0112113
Valve spring locks x32 - LF0112114 ** New part # LF0212114
Lifter buckets x16
LF0112541 = 3.000mm ** New part # 1F2012300B
LF0112542 = 3.025mm
LF0112543 = 3.050mm ** New part # 1F2012305B
LF0112544 = 3.075mm
LF0112545 = 3.100mm ** New part # 1F2012310B
LF0112546 = 3.122mm
LF0112547 = 3.142mm ** New part # 1F2012314B
LF0112548 = 3.162mm
LF0112549 = 3.182mm ** New part # 1F2012318B
LF0112551 = 3.202mm
LF0112552 = 3.222mm ** New part # 1F2012322B
LF0112553 = 3.242mm
LF0112554 = 3.262mm ** New part # 1F2012326B
LF0112555 = 3.282mm
LF0112556 = 3.302mm ** New part # 1F2012330B
LF0112557 = 3.322mm
LF0112558 = 3.342mm ** New part # 1F7012334A
LF0112559 = 3.362mm
LF0112561 = 3.382mm ** New part # ZZC012561B
LF0112562 = 3.402mm
LF0112563 = 3.422mm ** New part # 1F2012342B
LF0112564 = 3.442mm
LF0112565 = 3.462mm ** New part # 1F2012346B
LF0112566 = 3.482mm
LF0112567 = 3.502mm ** New part # 1F2012350B
LF0112568 = 3.522mm
LF0112569 = 3.542mm ** New part # 1F2012354B
LF0112571 = 3.562mm
LF0112572 = 3.582mm ** New part # 1F2012358B
LF0112573 = 3.602mm
LF0112574 = 3.625mm ** New part # 1F2012362B
LF0112575 = 3.650mm
LF0112576 = 3.675mm ** New part # 1F2012367A
LF0112577 = 3.700mm
LF0112578 = 3.725mm ** New part # 1F2012372B
Intake camshaft - L3K912420
Exhaust camshaft - L30912441A
VVT oil control valve - L3K914420A
VVT oil control valve bolt - 9XF002117L
VVT oil control valve oil filter - L3G2143X2
1st intake cam cap, 3rd bolt by the oil control valve? - 9XF003020L
VVT oil control valve plug - 9XG104510L
Valve cover bolts/seals - L3K910237
ENGINE OILING
Oil pump chain sprocket - L3K914143
Oil pump sprocket bolt - 9XG043977L
Crank oil pump sprocket - L3K911314A
Oil pump chain - L3K914151
Oil pump chain guide (bottom) - L3K914614
Oil pump chain guide (bottom) bolts x2 - 9XG036510L
Oil pump chain guide (top) - 9XG036510L
Oil pump chain guide (top) bolt - 9XG036510L
Oil pump chain guide (top) spring bolt - 9XG062860L
Oil pump mounting bolt x4 - 9XG120220L
Oil pump - L31014100J
Oil pump pickup o-ring - L30914248
Oil pump pickup - L3G614240B
Oil pump pickup bolt x2? - 9XG062820L
Oil filter housing to block gasket - LF0114342
Oil pan, baffles + bolts, drain bolt + washer, dipstick tube mount - L3K910400D ** New part # L3K910400H
Dip stick tube + o-ring - L3K910440
Dip stick - L3K910450
Dip stick tube bolt - 9XF002117L ** New part # 9XF002119L
Rear oil seal - LF0111310 ** New part # LF0111310A
Rear oil seal cover plate - LF1710903
Rear oil seal bolts x6 - 9XF002127L
Front oil seal - L3G610602
Oil pressure sensor - LF0118501
ENGINE ROTATING ASSEMBLY
Crankshaft - L3K911300A
Rod bolts x8 - LF0111214A
Rod big end alignment pins x8 - J50111219
Connecting rod, pins, bolts x4 - L3K911210A ** New part # L33L11210A
Piston, pin x4 - L3Y011SA0
Piston ring set x4 - L3Y411SC0
Thrust bearing x1
L3Y211SJ0 = Standard
L3Y211SK0 = Oversize 0.25
L3Y211SKX = Oversize 0.50
Rod bearing x8
L3Y211SE0 = Standard ** New part # L3Y211SE0A
L3Y211SF0 = Oversize 0.25 ** New part # L3Y211SF0A
L3Y211SFX = Oversize 0.50
Main bearing x9
L3Y211SG0 = Standard
L3Y211SH0 = Oversize 0.25
L3Y211SHX = Oversize 0.50
Oil squirter bolt x4 - 9XF002117L ** New part # 9XF002119L
Oil squirter x4 - L3K910580
Cylinder sleeve - L3K910311A
GASKETS AND GASKET SETS
Head Gasket - L3K910271C
Valve cover gasket (inner and outer) - L3K910230
VVT oil control valve seal - L3K9102D5A
Turbo to manifold gasket - L3K913710
Turbo oil drain (block side) gasket - L3K914264
Turbo oil drain (turbo side) gasket - L3K914293
Water pump gasket - LF0115116A
Water manifold gasket - L3K915169
Intake manifold gasket - L3K913111
TB gasket - L3K913655
Cold pipe gasket - L3K9135G6
CDFP housing gasket - L3K910193
Exhaust manifold gasket - L38013490B
EGR valve gasket - L3K920305
Crankcase breather o-ring - LF01102C8
Full gasket set - 8LL610271
Intake valve stem seal x8
Exhaust valve stem seal x8
Cylinder head
Front oil seal
IM gasket
Blue injector o-ring x4
Oil pickup o-ring
Turbo oil drain gasket (block side)
Turbo oil drain gasket (turbo side)
EGR pipe gasket on water manifold
Water pump o-ring
Thermostat o-ring
CDFP housing gasket
Crankcase breather gasket
Oil filter to block gasket
EGR valve gasket
Partial gasket set - 8LL602310
IM Gasket
Water pump o-ring
CDFP housing gasket
EXHAUST/TURBO
Exhaust manifold - L3K913450
Exhaust manifold studs x10 - 9XG044747L
Exhaust manifold nuts x10 - JE1040355
Turbo oil feed line, bolts, washers - L3K914280A
Turbo to manifold studs x4 - L33E13146
Turbo to DP short studs x4 - L33E13146
Turbo to DP long stud x1 - L33E13146A
Turbo to DP gasket - L3F213490
Turbo to manifold nuts x4 - JE1040355
Turbo water inlet pipe - L3K913530
Turbo water inlet hose to water manifold - L3K913115
Turbo water inlet and outlet banjo bolt x2 - L3K913452
Turbo water inlet and outlet banjo bolt washer x4 - 995621400
Turbo water outlet pipe -
Turbo water outlet hose to water return pipe - L3K91353XA
Turbo oil drain pipe - L33E14290
Turbo oil drain (turbo side) bolts x2 - 9XF002127L
Turbo oil drain (block side) bolts x2 - 9XF002147L
WB o2 sensor - L3M6188G1D
NB o2 sensor - L3M718861C9U
COOLING SYSTEM
Radiator hose (upper) - L3K915186
Radiator hose (lower right) - LF1715184E
Radiator hose (lower left) - LF171518YE
Bypass hose from water manifold to thermostat - L3K915260A
TB coolant hose from water manifold - L3K913680A
Metal water return pipe - L3K915190B
Transfercase to water return pipe hose - L3K91554YB
Thermostat - L33615170
Thermostat bolts x3 - 9XF000157L
Water manifold bolts x4 - 9XF000157L
Water manifold - L3K91517ZB
Coolant sensor - L35G18840
Water pump bolts x3 - 9XF000157L
Water pump -
INTAKE
Intake manifold - L3BT13100
Intake manifold bolts x7 - 9XF003117L
TB - L3Y113640A
TB bolts x4 - 9XF003057L
Cold pipe - L3K913241B
Cold pipe bolts x4 - 997960614
Crankcase breather, pcv, o-ring - L3K913570
PCV - L3K913890
PCV retainer - LF0110509
PCV to intake manifold hose - L3K913895
EGR valve - L3K920300
EGR valve bolts x2 - 9XF001157L
FUEL SYSTEM
CDFP to rail pipe, bolts, seals - L3K913290A
CDFP - L3K91335ZC
CDFP bolts x3 - L3K913366B
CDFP cam bucket - L3K912615
CDFP housing - L3K910190A
CDFP housing bolts x4 - 9XF001167L
CDFP return hose - L3K91349YB
CDFP fuel feed hose - L3K91349XC
Rail, relief valve, pressure sensor - L3K913150B ** New part # L3K913150E
Rail bolts x5 - L3K913150A
Injectors, seals, o-ring - L3K913250A
Injector o-ring x4 - L3K913253
Injector seal x4 - L3K913252
Crowsfoot bolt x4 - L3K913180
Crowsfoot - L3K913279A
IGNITION SYSTEM
Coil x4 - L3G218100A ** New part # L3G218100B9U
Coil bolt x4 - 9XF002157L ** New part # 9XF00215X0
ACCESSORIES
Starter - L32718400R00
Starter bolt lower - RF2B12717
Starter bolt upper - 9YA941003
Alternator heat shield - L35C18325
Alternator - L3M618300A ** New part # L3M618300R0A
Alternator bolt (upper) - 9YA941006
Belt -
Tensioner assembly - LF1715980E
Tensioner bolt x2 - 997940840
Idler pully, bolt, washer, bearing - LFH115940 ** New part # LFH115940A
BPV - L3K918740A ** New part # L3K918740B
P/S Pump High Pressure Banjo Bolt - B25D32422A
P/S Pump Tank Cap (Tank on pump - 2006 MS6 Only) - GJ6A32691
P/S Pump Tank/Cap Combo (2006 MS6 Only) - GJ6A32690
P/S Pump Copper Washer for Banjo Bolt - 995621400
CLUTCH SYSTEM
Pilot bearing - YF0911303
Flywheel - L30416610E
Flywheel bolts - L30416311
Disc - L30416460C
Pressure plate - L30416410C
Release bearing - LF0116510
TCASE
Rear flange oil seal (This is the seal on the rear of the tcase where the driveshaft goes) - M05327165
Pass axle shaft seal on the tcase (This is the seal that the pass side axle slides through) - LN0127623
Tcase cooler o-ring - LN01273A3
Input shaft from trans oil seal (This is the seal that goes between the tcase and the transmission) - LN0127238
Pass side tcase shaft seal (This is the seal that the pass side tcase shaft assembly slides through and iirc is located on the main tcase body) - LN0127398
TRANS
Axle oil seal - A60127238
Tcase side oil seal - A60227238
Input shaft seal - A60116103
2006 Mazdaspeed 6
The Following 36 Users Say Thank You to 06Speed6 For This Useful Post:
Amnesiac (10-29-2012), batmsp3 (10-19-2015), Block8head (10-29-2012), BrianB6 (04-04-2012), Downmented (02-08-2013), GLORIFIEDBOZO (05-13-2012), impossible (01-09-2017), Ingle (04-06-2012), jaguar_mike (02-08-2016), jm211 (10-11-2013), jmhinkle (09-18-2012), jracer (03-10-2012), KevMS6 (08-18-2012), madspd6 (10-01-2012), MATT DAMOND (10-06-2012), mayer (03-10-2012), MazdaGaragePat (02-09-2013), meelo88 (04-12-2013), Mistersix (07-13-2015), Nataphen (03-10-2012), PapaSmurf (01-17-2014), paveltol (03-10-2012), phate (11-24-2012), Qwik6 (07-31-2013), rob ms6gt (03-10-2012), Rokusek (05-13-2014), scubasteve711 (03-10-2012), sidekick (02-08-2013), Sleepin6 (09-08-2017), SNOW_QN (11-26-2015), speed23 (07-06-2012), TexasSpeed3 (03-18-2012), thehead (04-28-2012), theschrum (10-14-2012), TiGraySpeed6 (03-10-2012), Tomas (04-04-2012)
 Old 03-10-2012, 01:33 AM   #2
leon78's Avatar
Posts: 2,595   (View Stats)
Good write up! Sticky this bitch!
2013 Scion FR-S (Whiteout)
Less parking more racing
 Old 03-10-2012, 07:11 AM   #3
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Fuck yeah ! Awesome job !!
Sticky for sure ! You deserve some MSF bucks for that I think ! @Raider
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
Raider (03-10-2012)
 Old 03-10-2012, 08:04 AM   #4
Yup. Good stuff. Will still have dumbasses ask for part #'s tho!
 Old 03-10-2012, 08:10 AM   #5
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
Groans: 70
Awesome!!!
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
 Old 03-10-2012, 08:13 AM   #6
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Excellent-
Thank you!
340hp / 371tq
 Old 04-04-2012, 06:14 PM   #7
BrianB6's Avatar
Posts: 400   (View Stats)
Just found this,
thanks for putting this together
2006 - MS6 - Dead RIP
 Old 04-04-2012, 06:29 PM   #8
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
Question: do any of the part numbers change when revisions of design or material are made?
 Old 04-05-2012, 04:45 PM   #9
Speeeeeed
06Speed6's Avatar
Some do yeah, the a b c d on the end changes
2006 Mazdaspeed 6
Tomas (04-05-2012)
 Old 04-06-2012, 09:23 PM   #10
Ingle's Avatar
Posts: 421   (View Stats)
This is great. Thanks a lot for this.
 Old 07-06-2012, 07:05 PM   #11
Speeeeeed
06Speed6's Avatar
added clutch stuff
2006 Mazdaspeed 6
paveltol (07-21-2012)
 Old 08-12-2012, 02:10 PM   #12
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Please add purge valve number. Just in case. L3K9-18-740A
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
The Following User Says Thank You to paveltol For This Useful Post:
06Speed6 (10-01-2012)
 Old 10-01-2012, 01:41 PM   #13
Speeeeeed
06Speed6's Avatar
Added BPV and updated part numbers
2006 Mazdaspeed 6
 Old 10-01-2012, 02:21 PM   #14
Speeeeeed
06Speed6's Avatar
@Tomas can you see if any of the lifter buckets you ordered came with any of those new part numbers? Just trying to make sure those are good part numbers.
Thanks
2006 Mazdaspeed 6
 Old 10-01-2012, 05:37 PM   #15
Bob Ross Fanclub
Tomas's Avatar
No. They came with the old part number. I looked the tappets on mazdaspeed developments and they have not changed them there yet for both the MS3 and MS6. Where did you get those new part numbers?
06Speed6 (10-06-2012)
 Old 10-06-2012, 04:51 PM   #16
Speeeeeed
06Speed6's Avatar
The mazda part number file and and discount mazda parts.
I think they are skyactiv buckets that happen to fit our motor, but I dont actually know that. Its weird that they only updated every other size.
I might order the new cam bolt to see what they changed.
2006 Mazdaspeed 6
 Old 10-12-2012, 05:10 AM   #17
paveltol's Avatar
Can anyone advise where I can source the weight for all the Mazda part numbers?
 Old 10-14-2012, 05:31 PM   #18
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Since we have most of the drive train in here can we add the rear diff components as well?
Skreets be calling...
The Following User Says Thank You to BobtailedSnail For This Useful Post:
06Speed6 (10-15-2012)
 Old 10-14-2012, 08:03 PM   #19
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
Here is the parts breakdown. Make a nice list out of it for him and he'll put it in the OP. Part numbers are under the prices.
BTW, I've gotten the best overall deals including shipping out of onlinemazdaparts.com in NC if anyone is purchasing stuff. If someone finds better post it up.
The Following User Says Thank You to jmhinkle For This Useful Post:
 Old 10-15-2012, 02:58 AM   #20
Speeeeeed
06Speed6's Avatar
Yeah it seriously takes alot of time to compile those parts lists.
2006 Mazdaspeed 6
 Old 10-25-2012, 03:38 PM   #21
aviator79's Avatar
Posts: 3,934   (View Stats)
I cannot find anything on on the starter gasket (seals housing around where it sits on trans). I guess they dont sell it? Sucks. Mine is shot.
onlinemazdaparts shows it as 5 in attached but 5 is:
stopper MazdaSpeed6 2.3L
MSRP Core ? Online Price
$8.90 $0.00 $6.94
5 also points to another thing. So could they actually be selling the housing and the other parts and the gasget for $7? doubt that.
 Old 10-25-2012, 04:42 PM   #22
aviator79's Avatar
No, cause on here it is L32718X00 which is BRACKET,FRONT
MSRP $117.18
Core $0.00
Online Price $91.39
Still no luck on this. Somone else has had this problem...all I found was this:
Start Motor/Solenoid Swap
new starter gasget was in wrong place or something.
 Old 10-25-2012, 04:43 PM   #23
Axle Breaker
jmhinkle's Avatar
Groans: 162
Wasn't it just a foam spacer? None of us reused them as they aren't really a gasket and they tore up when taking off the starter. You could also pick up some cut to size foam gasket to make your own.
 Old 10-25-2012, 04:55 PM   #24
aviator79's Avatar
Mine was so gunked up it seamed like more than foam, but looking at that pic of the new one I can tell that is all it is. Ya, I will just use some foam window sealer type stuff or something.
Did you replace any of the seals and or C clip on transfer case? Guess I need to search on this also, but what do you do to prevent it from seeping/weeping? also what is the case case made of? can it be welded? Have a bit of a hole in mine, but think if I take that part of the case off (I think it is just a cover really as everything bolts to the other half I think), clean it up and stuff it can just be welded (watch out mega size pics):
http://www.mazdaspeedforum.org/forum/foru...6/#post1699496
 Old 10-25-2012, 05:02 PM   #25
Axle Breaker
jmhinkle's Avatar
Groans: 162
I blew up my transfer case before I got to attempt to reseal it. The factory TSB was to split the case clean the edges and reseal it with grey RTV. Grey RTV isn't a great sealer if the surfaces aren't perfectly machined and have little to no airspace. I think the cases flex more than grey could handle or aren't machined good enough. Maybe use a better sealer if you do split it like black or red. I do replace the seal in the tranny that the transfer case goes into anytime I separate the two. I've seen them leak on my car and Dustin's as well.
Amnesiac (10-30-2012)
 Old 10-26-2012, 04:51 PM   #26
Speeeeeed
06Speed6's Avatar
I sealed mine with gear oil rated black rtv. It needs to be fairly thin or you will change the gear tooth mesh and maybe get some gear noise.
2006 Mazdaspeed 6
 Old 10-26-2012, 05:39 PM   #27
aviator79's Avatar
For clutch I beleive luk 10-064 is the OEM kit by LUK. Can be had for $250 on ebay now. A member got it for $155 not long ago but I do not know where. Autozone sells this as their duralast clutch also but it is overpiced at like $350. Piecing it together will cost more and will not include the alingment tool. Not sure if the kit comes with new bolts.
The Following 2 Users Say Thank You to aviator79 For This Useful Post:
06Speed6 (10-29-2012), TiGraySpeed6 (10-26-2012)
 Old 10-29-2012, 07:36 PM   #28
Speeeeeed
06Speed6's Avatar
For Transfer case:
these are the front driveshaft output seals:
LN03-27-397 Oil Seal 1 LH outer
LN02-27-238 Oil Seal 1 LH inner
LN01-27-398 Oil Seal 1 RH outer
LN03-27-514A Oil Seal 1 RH inner
and C-clip that holds the drive gear shaft to the big gear I am trying to get out...
LN01-27-394 Snap Ring 1 For drive gear shaft
That is NOT a mazdaspeed clutch, I bought it and had to return it.
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
Code Monkey (10-29-2012), jmhinkle (10-29-2012), TiGraySpeed6 (10-30-2012)
 Old 10-30-2012, 07:34 AM   #29
aviator79's Avatar
The one on ebay? Or the one at Autozone? Or the LUK 10-064 in general? I looked and my clutch says LUK on it. Others have bougth the LUK 10-064 and are using it. Someone also said they bougth the autozone one and it is the luk 10-064 even thou it is listed as duralast so not sure...So are you just saying the ones being sold on ebay are wrong?
 Old 10-30-2012, 08:50 AM   #30
Speeeeeed
06Speed6's Avatar
The luk rep kit 10-064 is for certain duratec and mzr engines, it is almost a inch too small to bolt to our flywheel.
2006 Mazdaspeed 6
 Old 10-30-2012, 09:11 AM   #31
aviator79's Avatar
For Transfer case:
FYI, I got these right off the TSB for leaky CX-7 T-case. I assumed they were the same, but seam they are not due to the differences in the cases/shafts.
I am going to use these part #s :
2700B - FRONT DIFFERENTIALS. Fits: 2006 Mazda MazdaSpeed6 | Jim Ellis Mazda
I am just geting the RH ones as those are the ones I removed to get the big gear out of the case cover:
RH inner
27238 SEAL, OIL
ILLUST. NO.3
LN0127398
RH outer (I had this wrong)
27514
SEAL, OIL - IDLE GEAR
LN0127514
Not buying this one as it is $15 and I did not remove it.
LH inner:
27238 SEAL, OIL
ILLUST. NO.2
LN0127238
im not sure what this is eaither
27622A SEAL, OIL
A61027397
$23.21
But it is not a LH outer as there is not LH outer. I think it is a seal for the TC to the trans but I do not think it is needed. I do not think it is the Trans seal to axel. I was told to get one of those, but probably not going to as mine was fine.
As you can see by the parts lists you can adjust preload on the bearings by getting different thickness of the spacers 27-355 #2. It feals like mine has too much preload on it, but I cannot measure endplay or anything so I am just going to leave it as is. The case is tapered where the LH 27-350 bearing goes into and thats why they must use diff thickness of the spaces to adjust preload on the bearings. That gear is really stiff to turn but maybe that is the way it is suposed to be.
06Speed6 (10-30-2012), TiGraySpeed6 (10-30-2012)
 Old 10-30-2012, 09:36 AM   #32
aviator79's Avatar
What is the part # for this seal?
 Old 10-30-2012, 04:30 PM   #33
Axle Breaker
jmhinkle's Avatar
Groans: 162
Seal for the Tranny where the PTO goes in is A60227238. Opposite side is the Drivers axle seal A60127238.
The Following 4 Users Say Thank You to jmhinkle For This Useful Post:
06Speed6 (10-30-2012), Amnesiac (10-30-2012), aviator79 (10-31-2012), TiGraySpeed6 (10-30-2012)
 Old 10-30-2012, 05:56 PM   #34
Amnesiac's Avatar
Posts: 315   (View Stats)
Amnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the world
Groaned at 6 Times in 4 Posts
@jmhinkle Any idea if you can replace that seal with the trans on the car and the PTO off? I have to replace mine and that would save a little work.
Amnesiac is offline   Reply With Quote
 Old 10-30-2012, 05:58 PM   #35
Axle Breaker
jmhinkle's Avatar
Groans: 162
Easily. It pops in out and back in without an issue when the PTO is out.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
 Old 10-31-2012, 02:36 PM   #36
aviator79's Avatar
Your wrong. I just got it. It is the correct part..cant attach pcs from phome for some reasom. Guess I need to get.tapatalk. Disc is 9 7/8". Bolt holes on clutch are 10.5", same as flywheel.
Not sure qhere u got it but the one on ebay is.the correct part
06Speed6 (10-31-2012)
 Old 10-31-2012, 06:43 PM   #37
Speeeeeed
06Speed6's Avatar
Damnit, it was definitely the wrong part when I got it.
2006 Mazdaspeed 6
 Old 11-02-2012, 08:43 AM   #38
aviator79's Avatar
Discount factory (OEM) Mazda parts and accessories at Park Mazda OEM Parts was cheaper when I would get free shipping. They have it now for orders over $200. Onlinemazdaparts has shipping of only $8 and then free for over $250.
I have to place another order as I ordered the spacer rather than the inner seal cause im a ratard. Going to order the seals you listed as well.
jmhinkle (11-06-2012)
 Old 02-08-2013, 12:13 PM   #39
paveltol's Avatar
Water pump p/n: L32715100A
06Speed6 (02-08-2013)
 Old 10-11-2013, 01:02 AM   #40
keefover's Avatar
Posts: 624   (View Stats)
keefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the worldkeefover is the leader of the world
Groans: 42
Groaned at 49 Times in 11 Posts
Stock head and main bolts?
Overspeed Motorsports
Southern California's only Mazdaspeed performance expert
keefover is offline   Reply With Quote
The Following User Says Thank You to keefover For This Useful Post:
06Speed6 (11-03-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/oem-mazdaspeed-6-engine-part-numbers-107606/
LN03-27-397 weight This thread Refback 05-15-2013 12:05 PM
Looking for part numbers help Necro_1015 Mazdaspeed3/6 General Discussion 1 03-28-2011 08:32 AM
Need help with part numbers Blackspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 02-21-2011 03:39 PM
Someone Hit my car need part numbers!! KoleDeRacer MazdaSpeed 3/6 - Appearance 7 06-02-2010 09:56 AM
Fuel pump part numbers tburton101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 04-03-2009 02:32 PM
Page generated in 0.63116 seconds with 35 queries
