![]() | | #81 | ![]() |
![]() Join Date: Nov 2010 Location: Benbrook, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,325
Groaned at 18 Times in 14 Posts
| Not Ranked : 0 score
Sent from my XT926
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch | |
| The Following 2 Users Say Thank You to aggierandy For This Useful Post: | Code Monkey (04-16-2014), qtrmile beast (04-15-2014) |
![]() | | #82 | ![]() |
| Banned ![]() ![]() Join Date: Jun 2011 Location: Boston, MA
Groaned at 212 Times in 84 Posts
| Not Ranked : 0 score im planning on doing it, if its worth it...who knows... i want to shed 300 pounds off her and each step along the way may not seem worth it individually but i think when its all said and done it will be worth it that being said any tips or advice as to how i would go about this, and does anyone want to buy a moonroof lmao |
![]() | | #83 | ![]() |
As far as removing the sunroof, I'd try to find a metal shop that can build a custom plug. http://www.lighterfaster.com/index2.html Here is a company that makes carbon fiber ones for Hondas. Not sure if the fit is similar but I wouldn't be surprised if it is. Sent from my XT926
| The Following User Says Thank You to aggierandy For This Useful Post: | Code Monkey (04-16-2014) |
![]() | | #84 | ![]() |
| Not Ranked : 0 score thank you for the input, but i think you might have missed it, i like the sunroof but i dont care if it opens, id rather save the weight id like something like that carbon fiber but in lexan so i can have the sunroof for the light and the fact that its kinda cool and keeps the stock look but not have the 50 pounds it adds to the worst part of the car i think this reduction along with maybe (illegal) lexan glass,carbon fiber hood and trunk (which i have sitting around) and some really light seats could drop about 150-225 even with out the lexan glass i think 125-150 pounds off the car is a safe bet, all from practially unnoticeable places all from pretty high points dramatically increasing handling, my goal is to keep the car looking like a street car(because it is) i dont want a gutted caged track car reductions that would lower center of gravity in order from most effective to least sunroof delete carbon fiber roof skin lexan windows carbonfiber hood/trunk racing seats/ remove rear seats ( which i would never do) these items are all the the top half of the car also many of these items sit over the front half of the car which we can all agree will help this heavy ass bitch handle much better anyone know the weight dist on the 6/3? or both, stock anyone know if a good rear crash bar replacement or if removing this is safe/matters, i already learned a shit ton and got super flamed for asking about the front in a different post lol cheers! |
![]() | | #85 | ![]() |
![]() Join Date: Nov 2009 Location: Sterling Heights, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score Honestly removing my girlfriend was the best weight savings I've done in a while. Car is quieter, too, with less droning.
__________________ 2012 BMW 135i M-Sport |
| The Following 9 Users Say Thank You to Dark Lightning For This Useful Post: | Code Monkey (04-20-2014), EvoFire (05-12-2014), ItsNox (05-26-2014), Jh8909 (04-20-2014), Micha (12-07-2014), phate (05-06-2014), rbflurry (05-05-2014), RedDevil13 (07-18-2014), xliquidx (07-13-2014) |
![]() | | #86 | ![]() |
![]() Join Date: Jul 2011 Location: Minneapolis, MN
Groaned at 7 Times in 1 Post
| Not Ranked : 0 score Not sure any of this will ever be useful but I love data so while I tore my engine apart I weighed everything (on my super accurate bathroom scale) Crank: 45lbs Oil Pan: 11.6lbs Bare short block: 60lbs Both cams w/timing gears 11.4lbs 1st gen valve cover: 7.4 lbs Complete head (minus cams and VC): 35lbs
__________________ 2006 Speed6 | GT3071 | VersaTuner | Lots of supporting mods |
| The Following User Says Thank You to jdeves For This Useful Post: | MY DICK IS SMALL-beautfpowers@gmail.com (05-05-2014) |
![]() | | #87 | ![]() |
| Not Ranked : 0 score Just pulled the front apart so here's two more data points: front crash bar -- 20.8 lbs a/c compressor -- 13.4 lbs alternator -- 15.0 lbs This makes the whole a/c system (compressor, condenser, refrigerant lines, shit inside the cabin) a measly 38.2 lbs, maybe 39 lbs if you add random brackets and bolts.
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned Last edited by Code Monkey; 05-22-2014 at 05:58 PM. |
![]() | | #88 | ![]() |
| Not Ranked : 0 score Stock suspension weights: Front struts + springs + dust boots + bump stops -- 25.6 lbs springs only -- 14.4 lbs Rear shocks -- 8.2 lbs springs with rubber seats -- 10.6 lbs springs only -- 9.2 lbs
![]() | | #89 | ![]() |
![]() Join Date: Jan 2010 Location: charles co, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,295
(Thread Starter) | Not Ranked : 0 score Thanks guys and i will try and get the stuff posted ASAP!!! Keep it coming....
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport |
![]() | | #90 | ![]() |
![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 3780 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,647
Groans: 493
| Not Ranked : 0 score Thread revival, because i can.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3, TUNED BY THE SUPERSKATER// 700HP CLUB Former World Record Mazdaspeed 60' 1.603 11.479@124mph 10second car with an 11second driver #DIX -Builds 700hp MS6, buys miata, sells said MS6! |
![]() | | #91 | ![]() |
| Not Ranked : 0 score Moved the question here so it will be easy to search in the future. Biggest weight reducers (approximate weights): Rear seats + belts, 65 lbs Trunk spare etc, 53 Front seats, 45 a/c + heater, 39 Dashboard, 22 Battery, 22 ------------ Total 246 After that you have to chip away at smaller stuff but it adds up quick to a substantive number, you have another 250 lbs there.
| The Following 4 Users Say Thank You to Code Monkey For This Useful Post: |
![]() | | #92 | ![]() |
![]() Join Date: Aug 2010 Location: Salina, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
| Not Ranked : 0 score @qtrmile beast; what does your interior look like on a regular day? Do you roll around with a full interior or a semi-stripped?
__________________ Need more parts. |
![]() | | #93 | ![]() |
![]() Join Date: Sep 2011 Location: Rockville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,554
Groans: 130
Groaned at 8 Times in 7 Posts
I still have he regular seat belt hooked up. The noise is definitely intensified especially with all 3 motor mounts in the highest duro, however I got used to it.
__________________ 06 Black Cherry Mica MS6 GT: Speed Perf6rmanc3 built motor, GT3076r EWG, ACT 6 puck Clutch kit, HTP 3.5" full intake, M2 downpipe, XS Power Exhaust Manifold, CP-E austenite 3" exhaust, Whiteline 24mm rear sway bar, Injector RX Cleaned injectors, JBR trilogy motor mounts, JBR EGR Block off plate, Ported and ceramic coated intake manifold, 3 bar MAP, 3 port EBCS, Cobb AP, CX racing piping with Treadstone TR8, CP-E SAFEseals, MD OCC, Step Colder spark plugs, Turbo XS RFL BOV, AT fp internals, CP-E rear diff mount, Turbine Tech Front rear diff mount, DSS 500hp rear drivers side axle, Wilwood 4 Pot Calipers, Team Dynamics 18"x8" Pro Race 1.2s +38, SPC front ball joints, H&R springs, Morimoto clear projector retrofits. | |
| The Following 2 Users Say Thank You to Jh8909 For This Useful Post: | Poohster (12-07-2014), stanley0910 (12-01-2014) |
![]() | | #94 | ![]() |
| Not Ranked : 0 score Then @Jh8909; do you know your daily weight?
![]() | | #95 | ![]() |
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport | |
| The Following User Says Thank You to qtrmile beast For This Useful Post: | stanley0910 (12-08-2014) |
![]() | | #96 | ![]() |
![]() | | #97 | ![]() |
Groans: 130
Yeah I wish lol
![]() | | #98 | ![]() |
![]() Join Date: Feb 2009 Location: Atlanta Ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,123
| Not Ranked : 0 score Bringing sexy back.... anyone know the weight of the driveshaft? |
![]() | | #99 | ![]() |
| Not Ranked : 0 score @Code Monkey;, do you happen to know steering wheel weight or how much you saved going to a different one? I see airbag weight, but not wheel weight. Thanks!
![]() | | #100 | ![]() |
__________________ 2006 Mazdaspeed6 EFR 7163|FMIC|South Bend|FCM coilovers|Powerbrake BBK|RPF1 18x10.5|Nitto NT01 stripped|caged|freektuned 2017 Subaru BRZ MCS TT1 coilovers|Brembo BBK|6UL 17x9|RE-71R|ACE 350|flex fuel|Delicious tuned | |
| The Following User Says Thank You to Code Monkey For This Useful Post: | phate (06-03-2016) |
![]() | | #101 | ![]() |
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
| Not Ranked : 0 score @Jh8909; @qtrmile beast; @Code Monkey;. Are you guys running chrome Moley or mild steel cages? I was planning to turn my ms6 into my next track car, but the weight has me a little iffy. With my low 400s hp build I'd need to get this slug closer to 2800 to be worth the investment. Sent from my iPad using Tapatalk
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... Last edited by SofaKingAwesome; 06-06-2016 at 09:20 PM. |
| The Following User Says Thank You to GroceryGtr For This Useful Post: | Code Monkey (06-07-2016) |
![]() | | #102 | ![]() |
| Not Ranked : 0 score What kind of racing are you doing? My cage is 1.75" DOM with .120 wall tubing, most likely mild steel. You can see my cage build process here. For road racing I am about 300 whp and wtq and this is plenty of power.
![]() | | #103 | ![]() |
| Not Ranked : 0 score HPDE and private track events. Im usually on the track with 458 challenge cars, vipers, mclarens, and other gt3 level cars so I need something at or above a t1 setup corvette ratio otherwise I just get run over all day, which is the problem in my current car(abarth challenge car 250whp/2100lbs) |
![]() | | #104 | ![]() |
| Not Ranked : 0 score We estimated the weight of my cage at 170 lbs IIRC, the cage is a bit overbuilt, so I can see it being 150 lbs if needed. Chromoly is like 25% lighter, I think, so you could have a cage that is closer to 110 lbs. Still, I do not see how you plan on dropping the weight to 2,800 lbs, you would have to remove all the windows except the windscreen go get under 3,000 lbs, maybe 2,900 lbs. My car now sits at 3,156 lbs, no driver, no fuel, so: Code: 3,156 - 15 BSD - 60 lighter cage - 30 passenger seat + harness - 10 misc 3,041 - ? windows - ? fuel cell
![]() | | #105 | ![]() |
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | Code Monkey (06-07-2016) |
![]() | | #106 | ![]() |
If the car does stay below 3,000 lbs, the cage wall tubing can be .095" instead of the required .120" wall tubing for cars over 3,000 lbs, this should shave off another few lbs.
![]() | | #107 | ![]() |
![]() | | #108 | ![]() |
Not running a cage currently.. still full interior So is this a stripped interior with a cage or full interior?
__________________ Best time is 12.28@112 with a 1.68 60ft "GONE HUNTING BE BACK IN 11 SECS" 365HP and 333 TQ AT 20Psi gt3076 7 blade track weight 3220 street weight 3370 fully built motor//carrilo rods//cp pistons//ACT 6 puck//all mounts//gt3582 turbo//CPE manifold//ported intake//h&r coils//brembo brakes//tr10 I/C//accessport Last edited by qtrmile beast; 06-07-2016 at 07:29 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #109 | ![]() |
| Not Ranked : 0 score Stripped interior with the cage.
| The Following User Says Thank You to Code Monkey For This Useful Post: | qtrmile beast (06-08-2016) |
![]() | | #110 | ![]() |
![]() Join Date: Nov 2016 Location: Kansas City, Kansas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31
Groaned at 9 Times in 6 Posts
| Not Ranked : 0 score https://youtu.be/qSnxFEQOrzM Think this dude has got you guys all beat. Sent from my XT1254 using Tapatalk |
| The Following User Says Thank You to turbskies For This Useful Post: | Code Monkey (07-13-2017) |
![]() | | #111 | ![]() |
| Not Ranked : 0 score 70/30 weight distribution.
![]() | | #112 | ![]() |
![]() | | #113 | ![]() |
(Thread Starter) | Not Ranked : 0 score 850 duel friction clutch 38 lbs and act 6 puck clutch 30lbs all with flywheels
| The Following 2 Users Say Thank You to qtrmile beast For This Useful Post: | Code Monkey (07-29-2019), Tomas (08-01-2019) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/official-weight-reduction-thread-mazdaspeed-6-a-62615/ | ||||
| Weight Reduction Guide | This thread | Pingback | 04-23-2012 05:22 PM | |
| Mazdaspeed? Manifold - ??????? | This thread | Refback | 02-24-2011 06:09 AM | |
| MS3 Weight Reduction-Ideas and Who's Lightest? | Speedy3 | Mazdaspeed3/6 General Discussion | 31 | 06-05-2013 03:03 AM |
| weight reduction in a speed3 | quickspeed6 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 19 | 05-31-2009 05:31 AM |
