 Old 03-16-2009, 03:58 PM   #1
thabigo's Avatar
Posts: 167   (View Stats)
thabigo is a splendid one to beholdthabigo is a splendid one to beholdthabigo is a splendid one to beholdthabigo is a splendid one to beholdthabigo is a splendid one to beholdthabigo is a splendid one to beholdthabigo is a splendid one to beholdthabigo is a splendid one to behold
Default Oh No Check Engine Light!
Hey Guys, Just drove to the barber shop got a haircut. Got out of the barber shop, let the car warm up for a min. Then I got a check engine light, Scanned it with my dash hawk and read: P2119 (Throttle actuator control throttle body range/performance problem) I couldn't accelerate. Like I would almost have to floor it in order for it to rev, It was really weird!! Why would this happen?? I turned of the engine then turned it back on, Check Engine light was still on but i was able to drive home.
Thanks,
BigO
thabigo is offline   Reply With Quote
 Old 03-16-2009, 04:48 PM   #2
ms3guy22's Avatar
Posts: 530   (View Stats)
ms3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond repute
what hve you done to it recently, i had this code after i took after my intake mani
I hate my mazdaspeed3 more than anything else in this world!
ms3guy22 is offline   Reply With Quote
 Old 03-16-2009, 05:10 PM   #3
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
i never had this code, but i've had the same problem. my codes were a bit different. they had to do with the voltage at one of the throttle position sensors. apparently, i fried one. did you by chance hook up a map clamp?
are you phillyb v2.01?
 Old 03-16-2009, 05:24 PM   #4
fbpem1's Avatar
Posts: 1,159   (View Stats)
fbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the worldfbpem1 is the leader of the world
Groaned at 47 Times in 40 Posts
t/b or ecm two possible causes.
a built motor is not a built motor without being sleeved
fbpem1 is offline   Reply With Quote
 Old 03-31-2009, 10:01 AM   #5
miguelbates's Avatar
Posts: 689   (View Stats)
miguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the worldmiguelbates is the leader of the world
found these; see attached..any luck with the issue btw?
miguelbates is offline   Reply With Quote
 Old 04-01-2009, 11:53 AM   #6
holmstar's Avatar
Posts: 11   (View Stats)
holmstar is a jewel in the roughholmstar is a jewel in the roughholmstar is a jewel in the roughholmstar is a jewel in the rough
Thanks,
BigO
You haven't by chance done the throttle body coolant bypass have you? Was it significantly below freezing outside when this happened?
holmstar is offline   Reply With Quote
 Old 04-03-2009, 11:25 AM   #7
thabigo's Avatar
its was kinda cold out side maybe like 25- 35 degrees but i didnt drive the car for a couple of days. It started up fine drove to the barber shop which was like .02 miles away got a haircut 30mins then got back in my car to drive home and thats when it happend....
Update- I did clear the code and it hasn't come back on now. I am running a Sb it that makes a difference.
 Old 04-03-2009, 11:37 AM   #8
kingpin748's Avatar
Posts: 2,611   (View Stats)
Groans: 78
Could be a fluke. I wouldn't worry unless it starts to pop up frequently.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 04-04-2009, 01:57 PM   #9
wassup61's Avatar
Posts: 1,232   (View Stats)
wassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the worldwassup61 is the leader of the world
Probably faulted due to low coolant temp (enough time for 1 drive cycle but never detected temp above 40F, sensor didn't reach op threshold). you should follow the 10 mile/10 minute rule for driving. Don't worry about it if it doesn't come back.
Jeff at PG
All wagon, No traction
wassup61 is offline   Reply With Quote
Check Egine Light... QKRTHNU MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 12-29-2008 05:45 AM
The MS3 AccessPORT and Check Engine Lights ElBartoRex MazdaSpeed 3/6 - ECU Computer Tuning 3 11-18-2008 12:09 PM
PLEASE HELP! Trouble with engine light and check oil! spd6rcr08 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 10-01-2008 10:00 AM
Check engine light??? supergoose MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-20-2008 07:42 AM
Page generated in 0.30834 seconds with 28 queries
